    MMM-Scenes2
    31 Posts 4 Posters 10.8k Views 4 Watching
      ric
      Hi
      I’m currently building my first mirror and experimenting with third-party modules.
      For example MMM-Scenes2. I don’t know if the behaviour is correct. The scenes change as desired. After a certain time, the loop stops at the first scene. I want the cycle to be endless.
      Is this behaviour intended? Do I need to adjust my configuration? Does anyone have any tips?
      My configuration
                              module: "MMM-Scenes2",
                              position: 'bottom_bar', // Position of indicator
                                      activeIndicator: " ^|^s",
                                      inactiveIndicator: " ^|^w",
                                      defaultEnter: {
                                              animation:  "bounceInUp", /* "zoomInUp" */
                                      defaultExit: {
                                              animation: "hinge",
                                      scenario: [ // `scenario` is REQUIRED
                                              { // First scene definition
                                                      exit: [
        role: "role_date",
        animation: "bounceOutDown",
        role: "role_germanclock",
                                                      enter: ["role_alert",
                                                              "role_notification",
                                                              "role_clock",
                                                              "role_calendar",
                                                              "role_weather_current",
                                                              "role_weather_forecast"
                                              { // Second scene definition
                                                      exit: ["role_alert",
                                                              "role_clock",
                                                              "role_calendar",
                                                      enter: [
        role: "role_date",
        animation: "zoomInUp",
        MMRIZE @ric
        @ric
        Hmmm weird. It should restart unless you set the life as 0. Let me check.
          MMRIZE @ric
          @ric
          Can you send me your config? (eouia0819@gmail.com) (You may need to rename it as config.txt to attach it to the mail.)
            ric
            I have sent it
              MMRIZE @ric
              @ric has not reached yet.
              Anyway,
              • did it stop after the first cycle?
              • or did it work for a while, but after many cycles, did it suddenly stop? In that case, maybe some javascript error from this or other modules prevents the working. I need the front-end log error also.
                ric @MMRIZE
                @MMRIZE
                it ran for several hours. now it seems to be blocked again.
                Where can I find front-end log ?
                  MMRIZE @ric
                  @ric
                  Install MMM-LogExt; that module would help deliver your front-end log to the backend log. If you are using pm2, you can see the log in ~/.pm2/logs or somewhere. (I’m not sure about your environment.)
                  Or, you can run MM as debug mode; Instead of pm2(stop pm2 first), you can run your MM with debug mode by npm run start:dev, It will open MM with dev-console. Wait until your error happens. When you find the issue, See the console tab, there would be some suspicious messages or errors.
                  S R 2 Replies Last reply Reply Quote 0
                    sdetweil @MMRIZE
                    @MMRIZE said in MMM-Scenes2:
                    @ric
                    pm2 only captures backend log,
                    nothing captures front end log unless your LogExt is installed.
                      ric @MMRIZE
                      @MMRIZE
                      Thank you for your patience.
                      Now magicmirror is running in debug mode. So far it runs as it should.
                      pi@magicmirror:~/MagicMirror $ npm run start:dev
                      > magicmirror@2.25.0 start:dev
                      > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js dev
                      [13.12.2023 23:20.19.284] [LOG]   Starting MagicMirror: v2.25.0
                      [13.12.2023 23:20.19.289] [LOG]   Loading config ...
                      [13.12.2023 23:20.19.293] [DEBUG] config template file not exists, no envsubst
                      [13.12.2023 23:20.19.298] [LOG]   Loading module helpers ...
                      [13.12.2023 23:20.19.300] [LOG]   No helper found for module: alert.
                      [13.12.2023 23:20.19.325] [LOG]   Initializing new module helper ...
                      [13.12.2023 23:20.19.326] [LOG]   Module helper loaded: updatenotification
                      [13.12.2023 23:20.19.327] [LOG]   No helper found for module: clock.
                      [13.12.2023 23:20.19.399] [LOG]   Initializing new module helper ...
                      [13.12.2023 23:20.19.400] [LOG]   Module helper loaded: MMM-text-clock
                      [13.12.2023 23:20.19.627] [LOG]   Initializing new module helper ...
                      [13.12.2023 23:20.19.628] [LOG]   Module helper loaded: calendar
                      [13.12.2023 23:20.19.628] [LOG]   No helper found for module: weather.
                      [13.12.2023 23:20.19.643] [LOG]   Initializing new module helper ...
                      [13.12.2023 23:20.19.643] [LOG]   Module helper loaded: MMM-Scenes2
                      [13.12.2023 23:20.19.643] [LOG]   All module helpers loaded.
                      [13.12.2023 23:20.19.651] [LOG]   Starting server on port 8080 ...
                      [13.12.2023 23:20.20.122] [LOG]   Server started ...
                      [13.12.2023 23:20.20.122] [LOG]   Connecting socket for: updatenotification
                      [13.12.2023 23:20.20.123] [LOG]   Starting module helper: updatenotification
                      [13.12.2023 23:20.20.123] [LOG]   Connecting socket for: MMM-text-clock
                      [13.12.2023 23:20.20.124] [LOG]   Starting module helper: MMM-text-clock
                      [13.12.2023 23:20.20.124] [LOG]   Connecting socket for: calendar
                      [13.12.2023 23:20.20.125] [LOG]   Starting node helper for: calendar
                      [13.12.2023 23:20.20.125] [LOG]   Connecting socket for: MMM-Scenes2
                      [13.12.2023 23:20.20.425] [LOG]   Sockets connected & modules started ...
                      [13.12.2023 23:20.20.576] [LOG]   Launching application.
                      [5658:1213/232023.441362:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [5658:1213/232023.441848:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [5658:1213/232023.442182:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [5658:1213/232023.442478:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [5658:1213/232023.442771:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [5658:1213/232023.443062:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [5658:1213/232023.443344:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [5658:1213/232023.444865:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [5658:1213/232023.445175:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [5658:1213/232023.445471:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [5658:1213/232023.445828:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [5658:1213/232023.446143:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [5658:1213/232023.446421:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [5658:1213/232023.446686:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [13.12.2023 23:20.25.506] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/xxxxxxxxxxxxx/basic.ics - Interval: 3600000
                      [13.12.2023 23:20.25.672] [LOG]   Create new calendarfetcher for url: https://onlinekalender.info/feiertage/schweiz.ics - Interval: 3600000
                      [13.12.2023 23:20.25.678] [INFO]  Checking git for module: MMM-text-clock
                      [13.12.2023 23:20.26.283] [INFO]  Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics.
                      [13.12.2023 23:20.26.344] [INFO]  Checking git for module: MMM-Scenes2
                      [13.12.2023 23:20.26.553] [INFO]  Checking git for module: MagicMirror
                      [13.12.2023 23:20.28.191] [INFO]  Calendar-Fetcher: Broadcasting 3 events from https://calendar.google.com/xxxxxxxxxxxxx/basic.ics.
                      [5658:1213/232033.074222:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
                      [5658:1213/232037.073720:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
                      [5658:1213/232039.081014:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
                      I’ll let it run until something suspicious is output and then report back.
                      Thank you very much
                      R M 2 Replies Last reply Reply Quote 0
                        ric @ric
                        After several hours, the loop is blocked again.
                        But there is not much to see in the log.
                        I have deleted the log ~/.pm2/logs and started it again. I can also post this afterwards.
                        [13.12.2023 23:55.22.997] [LOG]   Starting MagicMirror: v2.25.0
                        [13.12.2023 23:55.23.002] [LOG]   Loading config ...
                        [13.12.2023 23:55.23.005] [DEBUG] config template file not exists, no envsubst
                        [13.12.2023 23:55.23.010] [LOG]   Loading module helpers ...
                        [13.12.2023 23:55.23.012] [LOG]   No helper found for module: alert.
                        [13.12.2023 23:55.23.037] [LOG]   Initializing new module helper ...
                        [13.12.2023 23:55.23.038] [LOG]   Module helper loaded: updatenotification
                        [13.12.2023 23:55.23.039] [LOG]   No helper found for module: clock.
                        [13.12.2023 23:55.23.109] [LOG]   Initializing new module helper ...
                        [13.12.2023 23:55.23.110] [LOG]   Module helper loaded: MMM-text-clock
                        [13.12.2023 23:55.23.336] [LOG]   Initializing new module helper ...
                        [13.12.2023 23:55.23.336] [LOG]   Module helper loaded: calendar
                        [13.12.2023 23:55.23.337] [LOG]   No helper found for module: weather.
                        [13.12.2023 23:55.23.351] [LOG]   Initializing new module helper ...
                        [13.12.2023 23:55.23.352] [LOG]   Module helper loaded: MMM-Scenes2
                        [13.12.2023 23:55.23.352] [LOG]   All module helpers loaded.
                        [13.12.2023 23:55.23.360] [LOG]   Starting server on port 8080 ...
                        [13.12.2023 23:55.23.755] [LOG]   Server started ...
                        [13.12.2023 23:55.23.756] [LOG]   Connecting socket for: updatenotification
                        [13.12.2023 23:55.23.757] [LOG]   Starting module helper: updatenotification
                        [13.12.2023 23:55.23.757] [LOG]   Connecting socket for: MMM-text-clock
                        [13.12.2023 23:55.23.758] [LOG]   Starting module helper: MMM-text-clock
                        [13.12.2023 23:55.23.758] [LOG]   Connecting socket for: calendar
                        [13.12.2023 23:55.23.759] [LOG]   Starting node helper for: calendar
                        [13.12.2023 23:55.23.759] [LOG]   Connecting socket for: MMM-Scenes2
                        [13.12.2023 23:55.24.018] [LOG]   Sockets connected & modules started ...
                        [13.12.2023 23:55.24.126] [LOG]   Launching application.
                        [6004:1213/235525.303520:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [6004:1213/235525.304075:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [6004:1213/235525.304482:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [6004:1213/235525.304869:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [6004:1213/235525.305244:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [6004:1213/235525.305713:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [6004:1213/235525.306098:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [6004:1213/235525.307820:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [6004:1213/235525.308207:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [6004:1213/235525.308576:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [6004:1213/235525.308928:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [6004:1213/235525.309269:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [6004:1213/235525.309644:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [6004:1213/235525.310007:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [13.12.2023 23:55.27.245] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics - Interval: 3600000
                        [13.12.2023 23:55.27.382] [LOG]   Create new calendarfetcher for url: https://onlinekalender.info/feiertage/schweiz.ics - Interval: 3600000
                        [13.12.2023 23:55.27.389] [INFO]  Checking git for module: MMM-text-clock
                        [13.12.2023 23:55.28.161] [INFO]  Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics.
                        [13.12.2023 23:55.28.195] [INFO]  Checking git for module: MMM-Scenes2
                        [13.12.2023 23:55.28.616] [INFO]  Checking git for module: MagicMirror
                        [13.12.2023 23:55.30.046] [INFO]  Calendar-Fetcher: Broadcasting 3 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics.
                        [6004:1213/235535.089417:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
                        [6004:1213/235537.084669:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
                        [6004:1213/235540.087744:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
                        [14.12.2023 00:55.28.404] [INFO]  Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics.
                        [14.12.2023 00:55.30.993] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics.
                        [14.12.2023 01:55.28.639] [INFO]  Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics.
                        [14.12.2023 01:55.31.758] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics.
                        [14.12.2023 02:55.28.843] [INFO]  Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics.
                        [14.12.2023 02:55.32.503] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics.
                        [14.12.2023 03:55.29.056] [INFO]  Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics.
                        [14.12.2023 03:55.33.226] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics.
                        [14.12.2023 04:55.29.269] [INFO]  Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics.
                        [14.12.2023 04:55.33.880] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics.
                        [14.12.2023 05:55.29.449] [INFO]  Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics.
                        [14.12.2023 05:55.34.466] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics.
                        [14.12.2023 06:55.29.648] [INFO]  Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics.
                        [14.12.2023 06:55.35.144] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics.
                        [14.12.2023 07:55.29.860] [INFO]  Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics.
                        [14.12.2023 07:55.35.877] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics.
                          MMRIZE @ric
                          @ric said in MMM-Scenes2:
                          I’m not sure whether this error is related to your symptom but refer to this.
                          https://forum.magicmirror.builders/topic/18076/failed-to-export-buffer-to-dma_buf-no-such-file-or-directory
                          And for ;
                          It also seems related to the GPU/GL issue of electron/chromium.
                          https://github.com/electron/electron/issues/32760
                          Hmmm, for those issues, I cannot help.
                          If you find something other from the log, report it again.
                            MMRIZE @ric
                            @ric
                            Maybe there would be some memory leaks on the chromium.
                            Can you test it again with more simple animations?(Just fadeIn, fadeOut) Some version of Chromium is known for possible memory leaking on transitions.
                              MMRIZE @ric
                              @ric
                              And, your log is just backend log, I need front-end log.
                              You can see front-end log by;
                              • installing MMM-LogExt
                              • Or, dev-console of your MM screen, not terminal. (with npm run start:dev, you can see dev-console panel on your MM screen.)
                                ric @MMRIZE
                                  ric @MMRIZE
                                  @MMRIZE
                                  I have changed the animations. New: fadeIn/fadeOut
                                  I have installed MMM-LogExt.
                                  MagicMirror is running and I will keep an eye on it. As soon as it stops running correctly, I will post the logs.
                                  Thank you
                                  Current log entry
                                  pi@magicmirror:~/MagicMirror $ pm2 logs MagicMirror
                                  [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
                                  /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                                  0|MagicMir | [29109:1214/163910.531720:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                  0|MagicMir | [29109:1214/163910.534010:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                  0|MagicMir | [29109:1214/163910.535596:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                  0|MagicMir | [29109:1214/163910.536560:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                  0|MagicMir | [29109:1214/163910.537412:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                  0|MagicMir | [29109:1214/163910.539776:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                  0|MagicMir | [29109:1214/163910.540617:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                  0|MagicMir | [29109:1214/163910.541337:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                  0|MagicMir | [29109:1214/163910.542083:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                  0|MagicMir | [29109:1214/163910.542859:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                  0|MagicMir | [29109:1214/163910.543568:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                  0|MagicMir | [29109:1214/163910.544310:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                  0|MagicMir | [29109:1214/163912.238616:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
                                  0|MagicMir | [29109:1214/163912.240892:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
                                  0|MagicMir | [29109:1214/163923.075684:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
                                  /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                                  0|MagicMirror  | [14.12.2023 16:56.57.386] [LOG]   [library.mjs:174:9] [SCENE] Scene transition starts: scene_2
                                  0|MagicMirror  | [14.12.2023 16:57.00.007] [LOG]   [library.mjs:178:9] [SCENE] Scene will live: scene_2 60000
                                  0|MagicMirror  | [14.12.2023 16:58.00.036] [LOG]   [library.mjs:174:9] [SCENE] Scene transition starts: scene_1
                                  0|MagicMirror  | [14.12.2023 16:58.02.697] [LOG]   [library.mjs:178:9] [SCENE] Scene will live: scene_1 60000
                                  0|MagicMirror  | [14.12.2023 16:59.02.696] [LOG]   [library.mjs:174:9] [SCENE] Scene transition starts: scene_2
                                  0|MagicMirror  | [14.12.2023 16:59.05.324] [LOG]   [library.mjs:178:9] [SCENE] Scene will live: scene_2 60000
                                  0|MagicMirror  | [14.12.2023 16:59.15.816] [LOG]   [weather.js:166:7] New weather information available.
                                  0|MagicMirror  | [14.12.2023 16:59.15.952] [LOG]   [weather.js:166:7] New weather information available.
                                  0|MagicMirror  | [14.12.2023 17:00.05.325] [LOG]   [library.mjs:174:9] [SCENE] Scene transition starts: scene_1
                                  0|MagicMirror  | [14.12.2023 17:00.07.959] [LOG]   [library.mjs:178:9] [SCENE] Scene will live: scene_1 60000
                                  0|MagicMirror  | [14.12.2023 17:01.07.968] [LOG]   [library.mjs:174:9] [SCENE] Scene transition starts: scene_2
                                  0|MagicMirror  | [14.12.2023 17:01.10.602] [LOG]   [library.mjs:178:9] [SCENE] Scene will live: scene_2 60000
                                  0|MagicMirror  | [14.12.2023 17:02.10.614] [LOG]   [library.mjs:174:9] [SCENE] Scene transition starts: scene_1
                                  0|MagicMirror  | [14.12.2023 17:02.13.263] [LOG]   [library.mjs:178:9] [SCENE] Scene will live: scene_1 60000
                                  Is MMM-LogExt working correctly or do I need to adjust something?
                                    MMRIZE @ric
                                    @ric
                                    Log says nothing suspicious. I suspect Chromium graphic memory leak issues due to last parts of error-log.
                                    In that case, I have nothing to help. Sorry.
                                      ric @MMRIZE
                                      @MMRIZE
                                      Thanks anyway.
                                      Would you say it’s the Pi version? Software/hardware version? Could this be fixed with a Chromium update in the future?
                                        ric @ric
                                        Very strange. I have created a third scene. Now it is already running for several hours.
                                          Babene1 Project Sponsor
                                          I have the same problem, after about 1 hour there is no change of modules.
                                          I also want a constant change of MMM-iframeReload and MMM-iframeReload2 module
                                          MagicMirror Version 2.27, Rapsberry PI 4 – 4 GB
                                          My Config:
                                          /* MagicMirror² Config Sample
                                           * By Michael Teeuw https://michaelteeuw.nl
                                           * MIT Licensed.
                                           * see https://docs.magicmirror.builders/configuration/introduction.html
                                           * and https://docs.magicmirror.builders/modules/configuration.html
                                           * You can use environment variables using a `config.js.template` file instead of `config.js`
                                           * which will be converted to `config.js` while starting. For more information
                                           * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
                                          let config = {
                                          	address: "0.0.0.0",	// Address to listen on, can be:
                                          	port: 8080,
                                          	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                                          	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.178.249", "192.168.178.49"], // Set [] to allow all IP addresses
                                          	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
                                          	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
                                          	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
                                          	language: "de",
                                          	locale: "de-DE",
                                          	timeFormat: 24,
                                          	units: "metric",
                                          	electronOptions: {
                                          		webPreferences: {
                                          		  webviewTag: true,
                                          			module: "alert",
                                          			module: "clock",
                                          			position: "top_left"
                                          		// https://github.com/TheBogueRat/MMM-iFrameReload
                                          		module: 'MMM-iFrameReload',
                                          		position: 'top_left',	// This can be any of the regions.
                                          		classes: "SEITE_ZWEI",
                                          		//header: 'Rezept des Tages',
                                          				url: http://test/Anzeigetafeln/Anzeige1.html,
                                          				width: "1900px", // Optional. Default: 100%
                                          				height: "1080px", //Optional. Default: 100px
                                          				refreshInterval: 100
                                          			module: 'MMM-iFrameReload2',
                                          			classes: "Welcome SEITE_EINS",
                                          					url: http://test/Anzeigetafeln/Logo.html,
                                          					refreshInterval: 3600
                                          				// https://github.com/MMRIZE/MMM-Scenes2
                                          				position: "bottom_bar",
                                          					life: 1000 * 10,
                                          					activeIndicator: ' ',
                                          					inactiveIndicator: ' ',
                                          					scenario: [
                                          							exit: ["SEITE_ZWEI"],
                                          							enter: ["SEITE_EINS"],
                                          							life: 1000 * 10,
                                          							exit: ["SEITE_EINS"],
                                          							enter: ["SEITE_ZWEI"],
                                          							life: 1000 * 45,
                                          			// https://github.com/Jopyth/MMM-Remote-Control
                                          			module: 'MMM-Remote-Control',
                                          			// position: 'bottom_left',
                                          				customCommand: {
                                          					//monitorStatusCommand: 'rm -rf .config/Electron',
                                          					monitorStatusCommand: '~pi/restartBrowsercache.sh'
                                          				},  // Optional, See "Using Custom Commands" below
                                          				showModuleApiMenu: false, // Optional, Enable the Module Controls menu
                                          				secureEndpoints: true, // Optional, See API/README.md
                                          				// uncomment any of the lines below if you're gonna use it
                                          				customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                                          				// apiKey: "", // Optional, See API/README.md for details
                                          				// classes: {} // Optional, See "Custom Classes" below
                                          I insert the line in my mm.sh:
                                          export ELECTRON_DISABLE_GPU=1
                                          pm2 Log:
                                          [1965:0521/220109.925300:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                                          [1965:0521/220109.925398:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                                          uname -a
                                          Linux raspberryanzeige1 6.1.0-rpi8-rpi-v8 #1 SMP PREEMPT Debian 1:6.1.73-1+rpt1 (2024-01-25) aarch64 GNU/Linux
                                          file /bin/bash
                                          /bin/bash: ELF 64-bit LSB pie executable, ARM aarch64, version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-aarch64.so.1, BuildID[sha1]=198ac6b0cc01bf774c5746a36a6fd31dead9bda5, for GNU/Linux 3.7.0, stripped
                                          Does anyone have any idea what I can do? Thanks
                                            MMRIZE @Babene1
                                            @Babene1
                                            I researched about that error message.
                                            The error messages seemed not to be the module or logic issue but the GPU/System issue. (Usually in -nix machines about graphic drivers.)
                                            However, I’m not sure the error message is related to your symptom actually. There is a chance these two things could be independent.
                                            What I suggest for the test is;
                                            • use simpler animation effects or no animation.
                                            • give a longer life for the scene.
                                            • Remove all other 3rd party modules, except default modules (clock, …)
                                            If it helps, we can progress from it anyhow.
                                            But if not; I think I rarely have things to do.
