    Calendar not updating
    95 Posts 4 Posters 76.9k Views 6 Watching
      sdetweil @matt216
      @matt216 said in Calendar not updating:
      pi@magicmirror:~ $ npm start
      you need to be IN the MagicMirrror folder
      cd MagicMirror
      npm start
        matt216 @sdetweil
        @sdetweil Thank you!
        pi@magicmirror:~/MagicMirror $ npm start
        > magicmirror@2.26.0 start
        sh: 1: ./node_modules/.bin/electron: not found
          sdetweil @matt216
          @matt216 weird
          npm install electron@27.2.0
          then
          npm start
          again
            matt216 @sdetweil
            @sdetweil yep in between my previous 2 posts I thought I’d upgrade MagicMirror and it now won’t load with electron error.
            Will install and get back to you.
              matt216 @sdetweil
              @sdetweil ok it’s a big one…
              [01.01.2024 20:09.38.801] [LOG]   Starting MagicMirror: v2.26.0
              [01.01.2024 20:09.38.814] [LOG]   Loading config ...
              [01.01.2024 20:09.38.823] [DEBUG] config template file not exists, no envsubst
              [01.01.2024 20:09.38.834] [LOG]   Loading module helpers ...
              [01.01.2024 20:09.38.840] [LOG]   No helper found for module: alert.
              [01.01.2024 20:09.38.947] [LOG]   Initializing new module helper ...
              [01.01.2024 20:09.38.949] [LOG]   Module helper loaded: updatenotification
              [01.01.2024 20:09.38.951] [LOG]   No helper found for module: clock.
              [01.01.2024 20:09.39.477] [LOG]   Initializing new module helper ...
              [01.01.2024 20:09.39.480] [LOG]   Module helper loaded: calendar
              [01.01.2024 20:09.40.633] [LOG]   Initializing new module helper ...
              [01.01.2024 20:09.40.636] [LOG]   Module helper loaded: MMM-UKNationalRail
              [01.01.2024 20:09.41.573] [LOG]   Module helper loaded: MMM-Sonos
              [01.01.2024 20:09.41.575] [LOG]   No helper found for module: weather.
              [01.01.2024 20:09.41.585] [LOG]   Initializing new module helper ...
              [01.01.2024 20:09.41.587] [LOG]   Module helper loaded: MMM-MoonPhase
              [01.01.2024 20:09.42.084] [LOG]   Initializing new module helper ...
              [01.01.2024 20:09.42.085] [LOG]   Module helper loaded: newsfeed
              [01.01.2024 20:09.42.088] [LOG]   No helper found for module: MMM-WiFiPassword.
              [01.01.2024 20:09.43.354] [LOG]   Initializing new module helper ...
              [01.01.2024 20:09.43.355] [LOG]   Module helper loaded: MMM-MyCommute
              [01.01.2024 20:09.43.357] [LOG]   No helper found for module: MMM-EyeCandy.
              [01.01.2024 20:09.43.469] [LOG]   Initializing new module helper ...
              [01.01.2024 20:09.43.469] [LOG]   Module helper loaded: mmm-hue-lights
              [01.01.2024 20:09.44.432] [LOG]   Initializing new module helper ...
              [01.01.2024 20:09.44.433] [LOG]   Module helper loaded: MMM-HASS
              [01.01.2024 20:09.44.439] [LOG]   Initializing new module helper ...
              [01.01.2024 20:09.44.440] [LOG]   Check MagicMirror² version for node helper 'MMM-ip' - Minimum version: 2.15.0 - Current version: 2.26.0
              [01.01.2024 20:09.44.443] [LOG]   Version is ok!
              [01.01.2024 20:09.44.444] [LOG]   Module helper loaded: MMM-ip
              [01.01.2024 20:09.44.445] [LOG]   All module helpers loaded.
              [01.01.2024 20:09.44.466] [LOG]   Starting server on port 8080 ...
              [01.01.2024 20:09.44.489] [WARN]  You're using a full whitelist configuration to allow for all IPs
              [01.01.2024 20:09.44.518] [ERROR] Whoops! There was an uncaught exception...
              [01.01.2024 20:09.44.521] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                  at Server.setupListenHandle [as _listen2] (node:net:1751:16)
                  at listenInCluster (node:net:1799:12)
                  at doListen (node:net:1948:7)
                  at process.processTicksAndRejections (node:internal/process/task_queues:83:21) {
                code: 'EADDRINUSE',
                errno: -98,
                syscall: 'listen',
                address: '0.0.0.0',
                port: 8080
              [01.01.2024 20:09.44.522] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              [01.01.2024 20:09.44.523] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              Warning: vkCreateInstance: Found no drivers!
              Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
                  at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                  at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                  at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                  at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                  at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                sdetweil @matt216
                @matt216 pm2 stop all
                then npm start again
                no idea on the Vulcan driver issue…
                what os are u running on what hardware…
                uname -a
                lsb_release -a
                • A avano referenced this topic on
                  matt216 @sdetweil
                  pi@magicmirror:~ $ uname -a
                  Linux magicmirror 6.1.21-v7+ #1642 SMP Mon Apr  3 17:20:52 BST 2023 armv7l GNU/Linux
                  pi@magicmirror:~ $ lsb_release -a
                  No LSB modules are available.
                  Distributor ID:	Raspbian
                  Description:	Raspbian GNU/Linux 11 (bullseye)
                  Release:	11
                  Codename:	bullseye
                  Stopped and re-started npm… the npm start seems to generate a rolling log output (with some sensitive info), so I’ve selected what I think is relevant to the calendar for my reply. There are no errors/warning this time :)
                  [02.01.2024 09:15.55.833] [LOG]   Module helper loaded: calendar
                  [02.01.2024 09:15.58.013] [LOG]   Connecting socket for: calendar
                  [02.01.2024 09:15.58.014] [LOG]   Starting node helper for: calendar
                  [02.01.2024 09:16.02.605] [LOG]   Create new calendarfetcher for url: https://my.cal.url - Interval: 120000
                  [02.01.2024 09:16.27.480] [INFO]  Calendar-Fetcher: Broadcasting 380 events from https://my.cal.url.
                  [02.01.2024 09:16.47.441] [LOG]   Use existing calendarfetcher for url: https://my.cal.url
                  [02.01.2024 09:16.47.442] [INFO]  Calendar-Fetcher: Broadcasting 380 events from https://my.cal.url.
                  [02.01.2024 09:17.12.085] [INFO]  Calendar-Fetcher: Broadcasting 380 events from https://my.cal.url.
                  Mostly looks ok, but the “use existing calendarfetcher for url:…” concerns me.
                  Still, I have an event upcoming soon that should be displaying in my 5 entries that isn’t.
                    matt216 @matt216
                    I can also see in pm2 logs:
                    0|MagicMir | [02.01.2024 10:11.33.120] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
                    I wonder why.
                    Getting the calendar to show in the first place was achieved by changing my baikal calendar WebDAV authentication type to ‘basic’ and setting the same in the calendar module. I’ve confirmed this is still set.
                      sdetweil @matt216
                      @matt216 well the type error is the problem.
                      the calendar.module doesn’t recover after the error.
                      can you open an issue on the mm GitHub page, with that info
                      are there any errors above that?
                        matt216 @sdetweil
                        @sdetweil None that I can see.
                        pi@magicmirror:~/.pm2/logs $ tail --lines=1000 MagicMirror-error.log | grep calendar
                        [02.01.2024 10:29.43.758] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
                        [02.01.2024 10:31.53.769] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
                        Will open an issue. Thanks for assisting. I might have a play with a couple of the other calendar modules there are out there…
                        • 10
                        • 1 / 10
