    Calendar not updating
    95 Posts 4 Posters 95.3k Views 6 Watching
      matt216 @sdetweil
      @sdetweil yep in between my previous 2 posts I thought I’d upgrade MagicMirror and it now won’t load with electron error.
      Will install and get back to you.
        matt216 @sdetweil
        @sdetweil ok it’s a big one…
        pi@magicmirror:~/MagicMirror $ npm start
        > magicmirror@2.26.0 start
        [01.01.2024 20:09.38.801] [LOG]   Starting MagicMirror: v2.26.0
        [01.01.2024 20:09.38.814] [LOG]   Loading config ...
        [01.01.2024 20:09.38.823] [DEBUG] config template file not exists, no envsubst
        [01.01.2024 20:09.38.834] [LOG]   Loading module helpers ...
        [01.01.2024 20:09.38.840] [LOG]   No helper found for module: alert.
        [01.01.2024 20:09.38.947] [LOG]   Initializing new module helper ...
        [01.01.2024 20:09.38.949] [LOG]   Module helper loaded: updatenotification
        [01.01.2024 20:09.38.951] [LOG]   No helper found for module: clock.
        [01.01.2024 20:09.39.477] [LOG]   Initializing new module helper ...
        [01.01.2024 20:09.39.480] [LOG]   Module helper loaded: calendar
        [01.01.2024 20:09.40.633] [LOG]   Initializing new module helper ...
        [01.01.2024 20:09.40.636] [LOG]   Module helper loaded: MMM-UKNationalRail
        [01.01.2024 20:09.41.573] [LOG]   Module helper loaded: MMM-Sonos
        [01.01.2024 20:09.41.575] [LOG]   No helper found for module: weather.
        [01.01.2024 20:09.41.585] [LOG]   Initializing new module helper ...
        [01.01.2024 20:09.41.587] [LOG]   Module helper loaded: MMM-MoonPhase
        [01.01.2024 20:09.42.084] [LOG]   Initializing new module helper ...
        [01.01.2024 20:09.42.085] [LOG]   Module helper loaded: newsfeed
        [01.01.2024 20:09.42.088] [LOG]   No helper found for module: MMM-WiFiPassword.
        [01.01.2024 20:09.43.354] [LOG]   Initializing new module helper ...
        [01.01.2024 20:09.43.355] [LOG]   Module helper loaded: MMM-MyCommute
        [01.01.2024 20:09.43.357] [LOG]   No helper found for module: MMM-EyeCandy.
        [01.01.2024 20:09.43.469] [LOG]   Initializing new module helper ...
        [01.01.2024 20:09.43.469] [LOG]   Module helper loaded: mmm-hue-lights
        [01.01.2024 20:09.44.432] [LOG]   Initializing new module helper ...
        [01.01.2024 20:09.44.433] [LOG]   Module helper loaded: MMM-HASS
        [01.01.2024 20:09.44.439] [LOG]   Initializing new module helper ...
        [01.01.2024 20:09.44.440] [LOG]   Check MagicMirror² version for node helper 'MMM-ip' - Minimum version: 2.15.0 - Current version: 2.26.0
        [01.01.2024 20:09.44.443] [LOG]   Version is ok!
        [01.01.2024 20:09.44.444] [LOG]   Module helper loaded: MMM-ip
        [01.01.2024 20:09.44.445] [LOG]   All module helpers loaded.
        [01.01.2024 20:09.44.466] [LOG]   Starting server on port 8080 ...
        [01.01.2024 20:09.44.489] [WARN]  You're using a full whitelist configuration to allow for all IPs
        [01.01.2024 20:09.44.518] [ERROR] Whoops! There was an uncaught exception...
        [01.01.2024 20:09.44.521] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
            at Server.setupListenHandle [as _listen2] (node:net:1751:16)
            at listenInCluster (node:net:1799:12)
            at doListen (node:net:1948:7)
            at process.processTicksAndRejections (node:internal/process/task_queues:83:21) {
          code: 'EADDRINUSE',
          errno: -98,
          syscall: 'listen',
          address: '0.0.0.0',
          port: 8080
        [01.01.2024 20:09.44.522] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [01.01.2024 20:09.44.523] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        Warning: vkCreateInstance: Found no drivers!
        Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
            at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
            at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
            at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
            at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
            at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
          sdetweil @matt216
          @matt216 pm2 stop all
          then npm start again
          no idea on the Vulcan driver issue…
          what os are u running on what hardware…
          uname -a
          lsb_release -a
          M 1 Reply Last reply
          • A avano referenced this topic on
            matt216 @sdetweil
            pi@magicmirror:~ $ uname -a
            Linux magicmirror 6.1.21-v7+ #1642 SMP Mon Apr  3 17:20:52 BST 2023 armv7l GNU/Linux
            pi@magicmirror:~ $ lsb_release -a
            No LSB modules are available.
            Distributor ID:	Raspbian
            Description:	Raspbian GNU/Linux 11 (bullseye)
            Release:	11
            Codename:	bullseye
            Stopped and re-started npm… the npm start seems to generate a rolling log output (with some sensitive info), so I’ve selected what I think is relevant to the calendar for my reply. There are no errors/warning this time :)
            [02.01.2024 09:15.55.833] [LOG]   Module helper loaded: calendar
            [02.01.2024 09:15.58.013] [LOG]   Connecting socket for: calendar
            [02.01.2024 09:15.58.014] [LOG]   Starting node helper for: calendar
            [02.01.2024 09:16.02.605] [LOG]   Create new calendarfetcher for url: https://my.cal.url - Interval: 120000
            [02.01.2024 09:16.27.480] [INFO]  Calendar-Fetcher: Broadcasting 380 events from https://my.cal.url.
            [02.01.2024 09:16.47.441] [LOG]   Use existing calendarfetcher for url: https://my.cal.url
            [02.01.2024 09:16.47.442] [INFO]  Calendar-Fetcher: Broadcasting 380 events from https://my.cal.url.
            [02.01.2024 09:17.12.085] [INFO]  Calendar-Fetcher: Broadcasting 380 events from https://my.cal.url.
            Mostly looks ok, but the “use existing calendarfetcher for url:…” concerns me.
            Still, I have an event upcoming soon that should be displaying in my 5 entries that isn’t.
              matt216 @matt216
              I can also see in pm2 logs:
              0|MagicMir | [02.01.2024 10:11.33.120] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
              I wonder why.
              Getting the calendar to show in the first place was achieved by changing my baikal calendar WebDAV authentication type to ‘basic’ and setting the same in the calendar module. I’ve confirmed this is still set.
                sdetweil @matt216
                @matt216 well the type error is the problem.
                the calendar.module doesn’t recover after the error.
                can you open an issue on the mm GitHub page, with that info
                are there any errors above that?
                  matt216 @sdetweil
                  @sdetweil None that I can see.
                  pi@magicmirror:~/.pm2/logs $ tail --lines=1000 MagicMirror-error.log | grep calendar
                  [02.01.2024 10:29.43.758] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
                  [02.01.2024 10:31.53.769] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
                  Will open an issue. Thanks for assisting. I might have a play with a couple of the other calendar modules there are out there…
                    sdetweil @matt216
                    @matt216 generally there is a more specific error earlier in the log.
                    if you clear it
                    pm2 flush
                    the restart
                    pm2 restart all
                    you will have the smallest output to look at
                      matt216 @sdetweil
                      @sdetweil Can’t see any calendar errors in error.log now! :grinning_squinting_face:
                      But still my new events are not showing up when they should…
                        matt216
                        https://github.com/MagicMirrorOrg/MagicMirror/issues/3329
                          sdetweil @matt216
                          @matt216 thank you… i posted a an additional grep thru the log to the issue
                            sdetweil @matt216
                            @matt216 cant see any errors… well not with the grep search you do
                            can u do this
                            pm2 stop all
                            npm start >somefile.txt 2>&1
                            wait, til UI up with no issues, or no updates
                            ctrl-q on MM screen to end
                            edit the somefile.txt
                            loo at messages after “Starting server on port”
                              matt216 @sdetweil
                              pi@magicmirror:~/MagicMirror $ cat somefile.txt | grep calendar
                              [02.01.2024 14:56.40.510] [LOG]   Module helper loaded: calendar
                              [02.01.2024 14:56.42.557] [LOG]   Connecting socket for: calendar
                              [02.01.2024 14:56.42.558] [LOG]   Starting node helper for: calendar
                              [02.01.2024 14:56.46.986] [LOG]   Create new calendarfetcher for url: https://my.cal.url - Interval: 120000
                              [02.01.2024 14:57.13.099] [INFO]  Calendar-Fetcher: Broadcasting 379 events from https://my.cal.url.
                              [02.01.2024 14:59.23.139] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
                                matt216 @matt216
                                    at Object.fetch (node:internal/deps/undici/undici:11576:11)
                                    at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
                                  cause: ConnectTimeoutError: Connect Timeout Error
                                      at onConnectTimeout (node:internal/deps/undici/undici:8522:28)
                                      at node:internal/deps/undici/undici:8480:50
                                      at Immediate._onImmediate (node:internal/deps/undici/undici:8511:13)
                                      at process.processImmediate (node:internal/timers:476:21) {
                                    code: 'UND_ERR_CONNECT_TIMEOUT'
                                Timeout…
                                Let me know if the full somefile.txt by email is still wanted.
                                  sdetweil @matt216
                                  @matt216 no… not needed…
                                    matt216 @sdetweil
                                    @sdetweil If I enter my calendar URL in to a web browser I can download the ics file fine, FYI
                                    S 2 Replies Last reply
                                      sdetweil @matt216
                                      @matt216 yes, it was a momentary delay, which caused the timeout… trying to see why the catch() block didn’t
                                        sdetweil @matt216
                                        @matt216 can u try updating modules/default/calendar/calendarfetcher.js like this
                                        replace lines 58-84 with this . also added this to the issue
                                        		try {  /// new code here     // this will be the new line 58
                                        		fetch(url, { headers: headers, agent: httpsAgent })
                                        			.then(NodeHelper.checkFetchStatus)
                                        			.then((response) => response.text())
                                        			.then((responseData) => {
                                        				let data = [];
                                        				try {
                                        					data = ical.parseICS(responseData);
                                        					Log.debug(`parsed data=${JSON.stringify(data)}`);
                                        					events = CalendarFetcherUtils.filterEvents(data, {
                                        						excludedEvents,
                                        						includePastEvents,
                                        						maximumEntries,
                                        						maximumNumberOfDays
                                        				} catch (error) {
                                        					fetchFailedCallback(this, error);
                                        					scheduleTimer();
                                        					return;
                                        				this.broadcastEvents();
                                        				scheduleTimer();
                                        			.catch((error) => {
                                        				scheduleTimer();
                                        		}    // new code here =========
                                        		catch(error){
                                                             console.error( "fetch for calendar url" +url + "failed error="+error.code);
                                                            scheduleTimer();
                                        		}   // end new code =====
                                          matt216 @sdetweil
                                          @sdetweil Doesn’t like that - mirror won’t load. Got to pick up my little boy now, so reverted back (mirror loads ok again). Will try again and look at logs.
                                          S M 2 Replies Last reply
                                            sdetweil @matt216
                                            @matt216 u are replacing the whole block, right…
                                            replace lines 58-84 in original with that
                                            lmk
                                            • 1 / 5
