    Calendar not updating
    95 Posts 4 Posters 88.6k Views 6 Watching
      matt216 @sdetweil
      @sdetweil ok it’s a big one…
      pi@magicmirror:~/MagicMirror $ npm start
      > magicmirror@2.26.0 start
      [01.01.2024 20:09.38.801] [LOG]   Starting MagicMirror: v2.26.0
      [01.01.2024 20:09.38.814] [LOG]   Loading config ...
      [01.01.2024 20:09.38.823] [DEBUG] config template file not exists, no envsubst
      [01.01.2024 20:09.38.834] [LOG]   Loading module helpers ...
      [01.01.2024 20:09.38.840] [LOG]   No helper found for module: alert.
      [01.01.2024 20:09.38.947] [LOG]   Initializing new module helper ...
      [01.01.2024 20:09.38.949] [LOG]   Module helper loaded: updatenotification
      [01.01.2024 20:09.38.951] [LOG]   No helper found for module: clock.
      [01.01.2024 20:09.39.477] [LOG]   Initializing new module helper ...
      [01.01.2024 20:09.39.480] [LOG]   Module helper loaded: calendar
      [01.01.2024 20:09.40.633] [LOG]   Initializing new module helper ...
      [01.01.2024 20:09.40.636] [LOG]   Module helper loaded: MMM-UKNationalRail
      [01.01.2024 20:09.41.573] [LOG]   Module helper loaded: MMM-Sonos
      [01.01.2024 20:09.41.575] [LOG]   No helper found for module: weather.
      [01.01.2024 20:09.41.585] [LOG]   Initializing new module helper ...
      [01.01.2024 20:09.41.587] [LOG]   Module helper loaded: MMM-MoonPhase
      [01.01.2024 20:09.42.084] [LOG]   Initializing new module helper ...
      [01.01.2024 20:09.42.085] [LOG]   Module helper loaded: newsfeed
      [01.01.2024 20:09.42.088] [LOG]   No helper found for module: MMM-WiFiPassword.
      [01.01.2024 20:09.43.354] [LOG]   Initializing new module helper ...
      [01.01.2024 20:09.43.355] [LOG]   Module helper loaded: MMM-MyCommute
      [01.01.2024 20:09.43.357] [LOG]   No helper found for module: MMM-EyeCandy.
      [01.01.2024 20:09.43.469] [LOG]   Initializing new module helper ...
      [01.01.2024 20:09.43.469] [LOG]   Module helper loaded: mmm-hue-lights
      [01.01.2024 20:09.44.432] [LOG]   Initializing new module helper ...
      [01.01.2024 20:09.44.433] [LOG]   Module helper loaded: MMM-HASS
      [01.01.2024 20:09.44.439] [LOG]   Initializing new module helper ...
      [01.01.2024 20:09.44.440] [LOG]   Check MagicMirror² version for node helper 'MMM-ip' - Minimum version: 2.15.0 - Current version: 2.26.0
      [01.01.2024 20:09.44.443] [LOG]   Version is ok!
      [01.01.2024 20:09.44.444] [LOG]   Module helper loaded: MMM-ip
      [01.01.2024 20:09.44.445] [LOG]   All module helpers loaded.
      [01.01.2024 20:09.44.466] [LOG]   Starting server on port 8080 ...
      [01.01.2024 20:09.44.489] [WARN]  You're using a full whitelist configuration to allow for all IPs
      [01.01.2024 20:09.44.518] [ERROR] Whoops! There was an uncaught exception...
      [01.01.2024 20:09.44.521] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
          at Server.setupListenHandle [as _listen2] (node:net:1751:16)
          at listenInCluster (node:net:1799:12)
          at doListen (node:net:1948:7)
          at process.processTicksAndRejections (node:internal/process/task_queues:83:21) {
        code: 'EADDRINUSE',
        errno: -98,
        syscall: 'listen',
        address: '0.0.0.0',
        port: 8080
      [01.01.2024 20:09.44.522] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [01.01.2024 20:09.44.523] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      Warning: vkCreateInstance: Found no drivers!
      Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
          at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
          at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
          at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
          at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
          at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
        sdetweil @matt216
        @matt216 pm2 stop all
        then npm start again
        no idea on the Vulcan driver issue…
        what os are u running on what hardware…
        uname -a
        lsb_release -a
        • A avano referenced this topic on
          matt216 @sdetweil
          pi@magicmirror:~ $ uname -a
          Linux magicmirror 6.1.21-v7+ #1642 SMP Mon Apr  3 17:20:52 BST 2023 armv7l GNU/Linux
          pi@magicmirror:~ $ lsb_release -a
          No LSB modules are available.
          Distributor ID:	Raspbian
          Description:	Raspbian GNU/Linux 11 (bullseye)
          Release:	11
          Codename:	bullseye
          Stopped and re-started npm… the npm start seems to generate a rolling log output (with some sensitive info), so I’ve selected what I think is relevant to the calendar for my reply. There are no errors/warning this time :)
          [02.01.2024 09:15.55.833] [LOG]   Module helper loaded: calendar
          [02.01.2024 09:15.58.013] [LOG]   Connecting socket for: calendar
          [02.01.2024 09:15.58.014] [LOG]   Starting node helper for: calendar
          [02.01.2024 09:16.02.605] [LOG]   Create new calendarfetcher for url: https://my.cal.url - Interval: 120000
          [02.01.2024 09:16.27.480] [INFO]  Calendar-Fetcher: Broadcasting 380 events from https://my.cal.url.
          [02.01.2024 09:16.47.441] [LOG]   Use existing calendarfetcher for url: https://my.cal.url
          [02.01.2024 09:16.47.442] [INFO]  Calendar-Fetcher: Broadcasting 380 events from https://my.cal.url.
          [02.01.2024 09:17.12.085] [INFO]  Calendar-Fetcher: Broadcasting 380 events from https://my.cal.url.
          Mostly looks ok, but the “use existing calendarfetcher for url:…” concerns me.
          Still, I have an event upcoming soon that should be displaying in my 5 entries that isn’t.
            matt216 @matt216
            I can also see in pm2 logs:
            0|MagicMir | [02.01.2024 10:11.33.120] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
            I wonder why.
            Getting the calendar to show in the first place was achieved by changing my baikal calendar WebDAV authentication type to ‘basic’ and setting the same in the calendar module. I’ve confirmed this is still set.
              sdetweil @matt216
              @matt216 well the type error is the problem.
              the calendar.module doesn’t recover after the error.
              can you open an issue on the mm GitHub page, with that info
              are there any errors above that?
                matt216 @sdetweil
                @sdetweil None that I can see.
                pi@magicmirror:~/.pm2/logs $ tail --lines=1000 MagicMirror-error.log | grep calendar
                [02.01.2024 10:29.43.758] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
                [02.01.2024 10:31.53.769] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
                Will open an issue. Thanks for assisting. I might have a play with a couple of the other calendar modules there are out there…
                  sdetweil @matt216
                  @matt216 generally there is a more specific error earlier in the log.
                  if you clear it
                  pm2 flush
                  the restart
                  pm2 restart all
                  you will have the smallest output to look at
                    matt216 @sdetweil
                    @sdetweil Can’t see any calendar errors in error.log now! :grinning_squinting_face:
                    But still my new events are not showing up when they should…
                      matt216
                      https://github.com/MagicMirrorOrg/MagicMirror/issues/3329
                        sdetweil @matt216
                        @matt216 thank you… i posted a an additional grep thru the log to the issue
                          sdetweil @matt216
                          @matt216 cant see any errors… well not with the grep search you do
                          can u do this
                          pm2 stop all
                          npm start >somefile.txt 2>&1
                          wait, til UI up with no issues, or no updates
                          ctrl-q on MM screen to end
                          edit the somefile.txt
                          loo at messages after “Starting server on port”
                            matt216 @sdetweil
                            pi@magicmirror:~/MagicMirror $ cat somefile.txt | grep calendar
                            [02.01.2024 14:56.40.510] [LOG]   Module helper loaded: calendar
                            [02.01.2024 14:56.42.557] [LOG]   Connecting socket for: calendar
                            [02.01.2024 14:56.42.558] [LOG]   Starting node helper for: calendar
                            [02.01.2024 14:56.46.986] [LOG]   Create new calendarfetcher for url: https://my.cal.url - Interval: 120000
                            [02.01.2024 14:57.13.099] [INFO]  Calendar-Fetcher: Broadcasting 379 events from https://my.cal.url.
                            [02.01.2024 14:59.23.139] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
                              matt216 @matt216
                                  at Object.fetch (node:internal/deps/undici/undici:11576:11)
                                  at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
                                cause: ConnectTimeoutError: Connect Timeout Error
                                    at onConnectTimeout (node:internal/deps/undici/undici:8522:28)
                                    at node:internal/deps/undici/undici:8480:50
                                    at Immediate._onImmediate (node:internal/deps/undici/undici:8511:13)
                                    at process.processImmediate (node:internal/timers:476:21) {
                                  code: 'UND_ERR_CONNECT_TIMEOUT'
                              Timeout…
                              Let me know if the full somefile.txt by email is still wanted.
                                sdetweil @matt216
                                @matt216 no… not needed…
                                  matt216 @sdetweil
                                  @sdetweil If I enter my calendar URL in to a web browser I can download the ics file fine, FYI
                                    sdetweil @matt216
                                    @matt216 yes, it was a momentary delay, which caused the timeout… trying to see why the catch() block didn’t
                                      sdetweil @matt216
                                      @matt216 can u try updating modules/default/calendar/calendarfetcher.js like this
                                      replace lines 58-84 with this . also added this to the issue
                                      		try {  /// new code here     // this will be the new line 58
                                      		fetch(url, { headers: headers, agent: httpsAgent })
                                      			.then(NodeHelper.checkFetchStatus)
                                      			.then((response) => response.text())
                                      			.then((responseData) => {
                                      				let data = [];
                                      				try {
                                      					data = ical.parseICS(responseData);
                                      					Log.debug(`parsed data=${JSON.stringify(data)}`);
                                      					events = CalendarFetcherUtils.filterEvents(data, {
                                      						excludedEvents,
                                      						includePastEvents,
                                      						maximumEntries,
                                      						maximumNumberOfDays
                                      				} catch (error) {
                                      					fetchFailedCallback(this, error);
                                      					scheduleTimer();
                                      					return;
                                      				this.broadcastEvents();
                                      				scheduleTimer();
                                      			.catch((error) => {
                                      				scheduleTimer();
                                      		}    // new code here =========
                                      		catch(error){
                                                           console.error( "fetch for calendar url" +url + "failed error="+error.code);
                                                          scheduleTimer();
                                      		}   // end new code =====
                                        matt216 @sdetweil
                                        @sdetweil Doesn’t like that - mirror won’t load. Got to pick up my little boy now, so reverted back (mirror loads ok again). Will try again and look at logs.
                                          sdetweil @matt216
                                          @matt216 u are replacing the whole block, right…
                                          replace lines 58-84 in original with that
                                          lmk
                                            matt216 @matt216
                                            @sdetweil can you tell I’m not a developer…?!
                                            Ok, I’ve replaced the whole block, then pm2 stop all, cd ~/MagicMirror, npm start…
                                            Mirror starts but still no new calendar events are showing where I would expect to be. Interestingly I can see that edits to existing events that I’ve made are showing up on the mirror, so there is some communication. Just no new events are being picked up.
                                            Thanks again,
                                            Matt
                                            M S 2 Replies Last reply Reply Quote 0
                                            • 1 / 5
