    Calendar not updating
    95 Posts 4 Posters 95.3k Views 6 Watching
      sdetweil @matt216
      @matt216 show me the output where you do npm start
      M 1 Reply Last reply
        matt216 @sdetweil
        pi@magicmirror:~ $ npm start
        npm ERR! code ENOENT
        npm ERR! syscall open
        npm ERR! errno -2
        npm ERR! enoent Could not read package.json: Error: ENOENT: no such file or directory, open '/home/pi/package.json'
        npm ERR! enoent This is related to npm not being able to find a file.
        npm ERR! enoent
        Appreciate the support
          sdetweil @matt216
          @matt216 said in Calendar not updating:
          you need to be IN the MagicMirrror folder
          cd MagicMirror
          npm start
            matt216 @sdetweil
            @sdetweil Thank you!
            pi@magicmirror:~/MagicMirror $ npm start
            > magicmirror@2.26.0 start
            sh: 1: ./node_modules/.bin/electron: not found
              sdetweil @matt216
              @matt216 weird
              npm install electron@27.2.0
              then
              npm start
              again
              M 2 Replies Last reply
                matt216 @sdetweil
                @sdetweil yep in between my previous 2 posts I thought I’d upgrade MagicMirror and it now won’t load with electron error.
                Will install and get back to you.
                  matt216 @sdetweil
                  @sdetweil ok it’s a big one…
                  [01.01.2024 20:09.38.801] [LOG]   Starting MagicMirror: v2.26.0
                  [01.01.2024 20:09.38.814] [LOG]   Loading config ...
                  [01.01.2024 20:09.38.823] [DEBUG] config template file not exists, no envsubst
                  [01.01.2024 20:09.38.834] [LOG]   Loading module helpers ...
                  [01.01.2024 20:09.38.840] [LOG]   No helper found for module: alert.
                  [01.01.2024 20:09.38.947] [LOG]   Initializing new module helper ...
                  [01.01.2024 20:09.38.949] [LOG]   Module helper loaded: updatenotification
                  [01.01.2024 20:09.38.951] [LOG]   No helper found for module: clock.
                  [01.01.2024 20:09.39.477] [LOG]   Initializing new module helper ...
                  [01.01.2024 20:09.39.480] [LOG]   Module helper loaded: calendar
                  [01.01.2024 20:09.40.633] [LOG]   Initializing new module helper ...
                  [01.01.2024 20:09.40.636] [LOG]   Module helper loaded: MMM-UKNationalRail
                  [01.01.2024 20:09.41.573] [LOG]   Module helper loaded: MMM-Sonos
                  [01.01.2024 20:09.41.575] [LOG]   No helper found for module: weather.
                  [01.01.2024 20:09.41.585] [LOG]   Initializing new module helper ...
                  [01.01.2024 20:09.41.587] [LOG]   Module helper loaded: MMM-MoonPhase
                  [01.01.2024 20:09.42.084] [LOG]   Initializing new module helper ...
                  [01.01.2024 20:09.42.085] [LOG]   Module helper loaded: newsfeed
                  [01.01.2024 20:09.42.088] [LOG]   No helper found for module: MMM-WiFiPassword.
                  [01.01.2024 20:09.43.354] [LOG]   Initializing new module helper ...
                  [01.01.2024 20:09.43.355] [LOG]   Module helper loaded: MMM-MyCommute
                  [01.01.2024 20:09.43.357] [LOG]   No helper found for module: MMM-EyeCandy.
                  [01.01.2024 20:09.43.469] [LOG]   Initializing new module helper ...
                  [01.01.2024 20:09.43.469] [LOG]   Module helper loaded: mmm-hue-lights
                  [01.01.2024 20:09.44.432] [LOG]   Initializing new module helper ...
                  [01.01.2024 20:09.44.433] [LOG]   Module helper loaded: MMM-HASS
                  [01.01.2024 20:09.44.439] [LOG]   Initializing new module helper ...
                  [01.01.2024 20:09.44.440] [LOG]   Check MagicMirror² version for node helper 'MMM-ip' - Minimum version: 2.15.0 - Current version: 2.26.0
                  [01.01.2024 20:09.44.443] [LOG]   Version is ok!
                  [01.01.2024 20:09.44.444] [LOG]   Module helper loaded: MMM-ip
                  [01.01.2024 20:09.44.445] [LOG]   All module helpers loaded.
                  [01.01.2024 20:09.44.466] [LOG]   Starting server on port 8080 ...
                  [01.01.2024 20:09.44.489] [WARN]  You're using a full whitelist configuration to allow for all IPs
                  [01.01.2024 20:09.44.518] [ERROR] Whoops! There was an uncaught exception...
                  [01.01.2024 20:09.44.521] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                      at Server.setupListenHandle [as _listen2] (node:net:1751:16)
                      at listenInCluster (node:net:1799:12)
                      at doListen (node:net:1948:7)
                      at process.processTicksAndRejections (node:internal/process/task_queues:83:21) {
                    code: 'EADDRINUSE',
                    errno: -98,
                    syscall: 'listen',
                    address: '0.0.0.0',
                    port: 8080
                  [01.01.2024 20:09.44.522] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [01.01.2024 20:09.44.523] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  Warning: vkCreateInstance: Found no drivers!
                  Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
                      at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                      at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                      at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                      at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                      at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                    sdetweil @matt216
                    @matt216 pm2 stop all
                    then npm start again
                    no idea on the Vulcan driver issue…
                    what os are u running on what hardware…
                    uname -a
                    lsb_release -a
                    • A avano referenced this topic on
                      matt216 @sdetweil
                      pi@magicmirror:~ $ uname -a
                      Linux magicmirror 6.1.21-v7+ #1642 SMP Mon Apr  3 17:20:52 BST 2023 armv7l GNU/Linux
                      pi@magicmirror:~ $ lsb_release -a
                      No LSB modules are available.
                      Distributor ID:	Raspbian
                      Description:	Raspbian GNU/Linux 11 (bullseye)
                      Release:	11
                      Codename:	bullseye
                      Stopped and re-started npm… the npm start seems to generate a rolling log output (with some sensitive info), so I’ve selected what I think is relevant to the calendar for my reply. There are no errors/warning this time :)
                      [02.01.2024 09:15.55.833] [LOG]   Module helper loaded: calendar
                      [02.01.2024 09:15.58.013] [LOG]   Connecting socket for: calendar
                      [02.01.2024 09:15.58.014] [LOG]   Starting node helper for: calendar
                      [02.01.2024 09:16.02.605] [LOG]   Create new calendarfetcher for url: https://my.cal.url - Interval: 120000
                      [02.01.2024 09:16.27.480] [INFO]  Calendar-Fetcher: Broadcasting 380 events from https://my.cal.url.
                      [02.01.2024 09:16.47.441] [LOG]   Use existing calendarfetcher for url: https://my.cal.url
                      [02.01.2024 09:16.47.442] [INFO]  Calendar-Fetcher: Broadcasting 380 events from https://my.cal.url.
                      [02.01.2024 09:17.12.085] [INFO]  Calendar-Fetcher: Broadcasting 380 events from https://my.cal.url.
                      Mostly looks ok, but the “use existing calendarfetcher for url:…” concerns me.
                      Still, I have an event upcoming soon that should be displaying in my 5 entries that isn’t.
                        matt216 @matt216
                        I can also see in pm2 logs:
                        0|MagicMir | [02.01.2024 10:11.33.120] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
                        I wonder why.
                        Getting the calendar to show in the first place was achieved by changing my baikal calendar WebDAV authentication type to ‘basic’ and setting the same in the calendar module. I’ve confirmed this is still set.
                          sdetweil @matt216
                          @matt216 well the type error is the problem.
                          the calendar.module doesn’t recover after the error.
                          can you open an issue on the mm GitHub page, with that info
                          are there any errors above that?
                            matt216 @sdetweil
                            @sdetweil None that I can see.
                            pi@magicmirror:~/.pm2/logs $ tail --lines=1000 MagicMirror-error.log | grep calendar
                            [02.01.2024 10:29.43.758] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
                            [02.01.2024 10:31.53.769] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
                            Will open an issue. Thanks for assisting. I might have a play with a couple of the other calendar modules there are out there…
                              sdetweil @matt216
                              @matt216 generally there is a more specific error earlier in the log.
                              if you clear it
                              pm2 flush
                              the restart
                              pm2 restart all
                              you will have the smallest output to look at
                                matt216 @sdetweil
                                @sdetweil Can’t see any calendar errors in error.log now! :grinning_squinting_face:
                                But still my new events are not showing up when they should…
                                  matt216
                                  https://github.com/MagicMirrorOrg/MagicMirror/issues/3329
                                    sdetweil @matt216
                                    @matt216 thank you… i posted a an additional grep thru the log to the issue
                                      sdetweil @matt216
                                      @matt216 cant see any errors… well not with the grep search you do
                                      can u do this
                                      pm2 stop all
                                      npm start >somefile.txt 2>&1
                                      wait, til UI up with no issues, or no updates
                                      ctrl-q on MM screen to end
                                      edit the somefile.txt
                                      loo at messages after “Starting server on port”
                                        matt216 @sdetweil
                                        pi@magicmirror:~/MagicMirror $ cat somefile.txt | grep calendar
                                        [02.01.2024 14:56.40.510] [LOG]   Module helper loaded: calendar
                                        [02.01.2024 14:56.42.557] [LOG]   Connecting socket for: calendar
                                        [02.01.2024 14:56.42.558] [LOG]   Starting node helper for: calendar
                                        [02.01.2024 14:56.46.986] [LOG]   Create new calendarfetcher for url: https://my.cal.url - Interval: 120000
                                        [02.01.2024 14:57.13.099] [INFO]  Calendar-Fetcher: Broadcasting 379 events from https://my.cal.url.
                                        [02.01.2024 14:59.23.139] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
                                          matt216 @matt216
                                              at Object.fetch (node:internal/deps/undici/undici:11576:11)
                                              at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
                                            cause: ConnectTimeoutError: Connect Timeout Error
                                                at onConnectTimeout (node:internal/deps/undici/undici:8522:28)
                                                at node:internal/deps/undici/undici:8480:50
                                                at Immediate._onImmediate (node:internal/deps/undici/undici:8511:13)
                                                at process.processImmediate (node:internal/timers:476:21) {
                                              code: 'UND_ERR_CONNECT_TIMEOUT'
                                          Timeout…
                                          Let me know if the full somefile.txt by email is still wanted.
                                            sdetweil @matt216
                                            @matt216 no… not needed…
                                            • 1 / 5
