    Calendar not updating
    95 Posts 4 Posters 91.1k Views 6 Watching
      matt216
      Hi Sam. My test is to add a new event that would show up within the next 5 events i.e. in a couple of hours time. My expectation is that the mirror would refresh the events it displays every 2 minutes and my new event should show up. Not happening.
        sdetweil @matt216
        @matt216 show me the output where you do npm start
          matt216 @sdetweil
          pi@magicmirror:~ $ npm start
          npm ERR! code ENOENT
          npm ERR! syscall open
          npm ERR! errno -2
          npm ERR! enoent Could not read package.json: Error: ENOENT: no such file or directory, open '/home/pi/package.json'
          npm ERR! enoent This is related to npm not being able to find a file.
          npm ERR! enoent
          Appreciate the support
            sdetweil @matt216
            @matt216 said in Calendar not updating:
            you need to be IN the MagicMirrror folder
            cd MagicMirror
            npm start
              matt216 @sdetweil
              @sdetweil Thank you!
              pi@magicmirror:~/MagicMirror $ npm start
              > magicmirror@2.26.0 start
              sh: 1: ./node_modules/.bin/electron: not found
                sdetweil @matt216
                @matt216 weird
                npm install electron@27.2.0
                then
                npm start
                again
                  matt216 @sdetweil
                  @sdetweil yep in between my previous 2 posts I thought I’d upgrade MagicMirror and it now won’t load with electron error.
                  Will install and get back to you.
                    matt216 @sdetweil
                    @sdetweil ok it’s a big one…
                    [01.01.2024 20:09.38.801] [LOG]   Starting MagicMirror: v2.26.0
                    [01.01.2024 20:09.38.814] [LOG]   Loading config ...
                    [01.01.2024 20:09.38.823] [DEBUG] config template file not exists, no envsubst
                    [01.01.2024 20:09.38.834] [LOG]   Loading module helpers ...
                    [01.01.2024 20:09.38.840] [LOG]   No helper found for module: alert.
                    [01.01.2024 20:09.38.947] [LOG]   Initializing new module helper ...
                    [01.01.2024 20:09.38.949] [LOG]   Module helper loaded: updatenotification
                    [01.01.2024 20:09.38.951] [LOG]   No helper found for module: clock.
                    [01.01.2024 20:09.39.477] [LOG]   Initializing new module helper ...
                    [01.01.2024 20:09.39.480] [LOG]   Module helper loaded: calendar
                    [01.01.2024 20:09.40.633] [LOG]   Initializing new module helper ...
                    [01.01.2024 20:09.40.636] [LOG]   Module helper loaded: MMM-UKNationalRail
                    [01.01.2024 20:09.41.573] [LOG]   Module helper loaded: MMM-Sonos
                    [01.01.2024 20:09.41.575] [LOG]   No helper found for module: weather.
                    [01.01.2024 20:09.41.585] [LOG]   Initializing new module helper ...
                    [01.01.2024 20:09.41.587] [LOG]   Module helper loaded: MMM-MoonPhase
                    [01.01.2024 20:09.42.084] [LOG]   Initializing new module helper ...
                    [01.01.2024 20:09.42.085] [LOG]   Module helper loaded: newsfeed
                    [01.01.2024 20:09.42.088] [LOG]   No helper found for module: MMM-WiFiPassword.
                    [01.01.2024 20:09.43.354] [LOG]   Initializing new module helper ...
                    [01.01.2024 20:09.43.355] [LOG]   Module helper loaded: MMM-MyCommute
                    [01.01.2024 20:09.43.357] [LOG]   No helper found for module: MMM-EyeCandy.
                    [01.01.2024 20:09.43.469] [LOG]   Initializing new module helper ...
                    [01.01.2024 20:09.43.469] [LOG]   Module helper loaded: mmm-hue-lights
                    [01.01.2024 20:09.44.432] [LOG]   Initializing new module helper ...
                    [01.01.2024 20:09.44.433] [LOG]   Module helper loaded: MMM-HASS
                    [01.01.2024 20:09.44.439] [LOG]   Initializing new module helper ...
                    [01.01.2024 20:09.44.440] [LOG]   Check MagicMirror² version for node helper 'MMM-ip' - Minimum version: 2.15.0 - Current version: 2.26.0
                    [01.01.2024 20:09.44.443] [LOG]   Version is ok!
                    [01.01.2024 20:09.44.444] [LOG]   Module helper loaded: MMM-ip
                    [01.01.2024 20:09.44.445] [LOG]   All module helpers loaded.
                    [01.01.2024 20:09.44.466] [LOG]   Starting server on port 8080 ...
                    [01.01.2024 20:09.44.489] [WARN]  You're using a full whitelist configuration to allow for all IPs
                    [01.01.2024 20:09.44.518] [ERROR] Whoops! There was an uncaught exception...
                    [01.01.2024 20:09.44.521] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                        at Server.setupListenHandle [as _listen2] (node:net:1751:16)
                        at listenInCluster (node:net:1799:12)
                        at doListen (node:net:1948:7)
                        at process.processTicksAndRejections (node:internal/process/task_queues:83:21) {
                      code: 'EADDRINUSE',
                      errno: -98,
                      syscall: 'listen',
                      address: '0.0.0.0',
                      port: 8080
                    [01.01.2024 20:09.44.522] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    [01.01.2024 20:09.44.523] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    Warning: vkCreateInstance: Found no drivers!
                    Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
                        at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                        at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                        at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                        at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                        at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                      sdetweil @matt216
                      @matt216 pm2 stop all
                      then npm start again
                      no idea on the Vulcan driver issue…
                      what os are u running on what hardware…
                      uname -a
                      lsb_release -a
                      • A avano referenced this topic on
                        matt216 @sdetweil
                        pi@magicmirror:~ $ uname -a
                        Linux magicmirror 6.1.21-v7+ #1642 SMP Mon Apr  3 17:20:52 BST 2023 armv7l GNU/Linux
                        pi@magicmirror:~ $ lsb_release -a
                        No LSB modules are available.
                        Distributor ID:	Raspbian
                        Description:	Raspbian GNU/Linux 11 (bullseye)
                        Release:	11
                        Codename:	bullseye
                        Stopped and re-started npm… the npm start seems to generate a rolling log output (with some sensitive info), so I’ve selected what I think is relevant to the calendar for my reply. There are no errors/warning this time :)
                        [02.01.2024 09:15.55.833] [LOG]   Module helper loaded: calendar
                        [02.01.2024 09:15.58.013] [LOG]   Connecting socket for: calendar
                        [02.01.2024 09:15.58.014] [LOG]   Starting node helper for: calendar
                        [02.01.2024 09:16.02.605] [LOG]   Create new calendarfetcher for url: https://my.cal.url - Interval: 120000
                        [02.01.2024 09:16.27.480] [INFO]  Calendar-Fetcher: Broadcasting 380 events from https://my.cal.url.
                        [02.01.2024 09:16.47.441] [LOG]   Use existing calendarfetcher for url: https://my.cal.url
                        [02.01.2024 09:16.47.442] [INFO]  Calendar-Fetcher: Broadcasting 380 events from https://my.cal.url.
                        [02.01.2024 09:17.12.085] [INFO]  Calendar-Fetcher: Broadcasting 380 events from https://my.cal.url.
                        Mostly looks ok, but the “use existing calendarfetcher for url:…” concerns me.
                        Still, I have an event upcoming soon that should be displaying in my 5 entries that isn’t.
                          matt216 @matt216
                          I can also see in pm2 logs:
                          0|MagicMir | [02.01.2024 10:11.33.120] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
                          I wonder why.
                          Getting the calendar to show in the first place was achieved by changing my baikal calendar WebDAV authentication type to ‘basic’ and setting the same in the calendar module. I’ve confirmed this is still set.
                            sdetweil @matt216
                            @matt216 well the type error is the problem.
                            the calendar.module doesn’t recover after the error.
                            can you open an issue on the mm GitHub page, with that info
                            are there any errors above that?
                              matt216 @sdetweil
                              @sdetweil None that I can see.
                              pi@magicmirror:~/.pm2/logs $ tail --lines=1000 MagicMirror-error.log | grep calendar
                              [02.01.2024 10:29.43.758] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
                              [02.01.2024 10:31.53.769] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
                              Will open an issue. Thanks for assisting. I might have a play with a couple of the other calendar modules there are out there…
                                sdetweil @matt216
                                @matt216 generally there is a more specific error earlier in the log.
                                if you clear it
                                pm2 flush
                                the restart
                                pm2 restart all
                                you will have the smallest output to look at
                                  matt216 @sdetweil
                                  @sdetweil Can’t see any calendar errors in error.log now! :grinning_squinting_face:
                                  But still my new events are not showing up when they should…
                                    matt216
                                    https://github.com/MagicMirrorOrg/MagicMirror/issues/3329
                                      sdetweil @matt216
                                      @matt216 thank you… i posted a an additional grep thru the log to the issue
                                        sdetweil @matt216
                                        @matt216 cant see any errors… well not with the grep search you do
                                        can u do this
                                        pm2 stop all
                                        npm start >somefile.txt 2>&1
                                        wait, til UI up with no issues, or no updates
                                        ctrl-q on MM screen to end
                                        edit the somefile.txt
                                        loo at messages after “Starting server on port”
                                          matt216 @sdetweil
                                          pi@magicmirror:~/MagicMirror $ cat somefile.txt | grep calendar
                                          [02.01.2024 14:56.40.510] [LOG]   Module helper loaded: calendar
                                          [02.01.2024 14:56.42.557] [LOG]   Connecting socket for: calendar
                                          [02.01.2024 14:56.42.558] [LOG]   Starting node helper for: calendar
                                          [02.01.2024 14:56.46.986] [LOG]   Create new calendarfetcher for url: https://my.cal.url - Interval: 120000
                                          [02.01.2024 14:57.13.099] [INFO]  Calendar-Fetcher: Broadcasting 379 events from https://my.cal.url.
                                          [02.01.2024 14:59.23.139] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
                                            matt216 @matt216
                                                at Object.fetch (node:internal/deps/undici/undici:11576:11)
                                                at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
                                              cause: ConnectTimeoutError: Connect Timeout Error
                                                  at onConnectTimeout (node:internal/deps/undici/undici:8522:28)
                                                  at node:internal/deps/undici/undici:8480:50
                                                  at Immediate._onImmediate (node:internal/deps/undici/undici:8511:13)
                                                  at process.processImmediate (node:internal/timers:476:21) {
                                                code: 'UND_ERR_CONNECT_TIMEOUT'
                                            Timeout…
                                            Let me know if the full somefile.txt by email is still wanted.
                                            • 1 / 5
