    Cannot find module 'node-fetch' error with MMM-SoccerLiveScore
    34 Posts 5 Posters 19.2k Views 5 Watching
      sdetweil @codac
      @codac then you didnt do the npm install in the correct module folder
      and I assume you have to restart MM of the container to pick up the change
        codac @sdetweil
        root@04492d039b9f:/opt/magic_mirror/modules# cd MMM-SoccerLiveScore
        root@04492d039b9f:/opt/magic_mirror/modules/MMM-SoccerLiveScore# npm install node
        -fetch@2
        up to date, audited 1 package in 1s
        found 0 vulnerabilities
        How would I restart MM of the container?
        pm2 is not set up.
        DISPLAY=:0 npm restart
        …results in
        > magicmirror@2.26.0 restart
        > npm stop --if-present && npm start
        > magicmirror@2.26.0 start
        sh: 1: ./node_modules/.bin/electron: not found
        S C 2 Replies Last reply Reply Quote 0
          sdetweil @codac
          @codac seen this happening more
          in the container again
          in the MagicMirror folder do
          npm install electron@27.2.0
            codac @sdetweil
            sorry for the hussle, but this seems to never end :anguished_face:
            after running
            I tried to restart MM:
            root@04492d039b9f:/opt/magic_mirror# DISPLAY=:0 npm restart
            /opt/magic_mirror/node_modules/electron/dist/electron: error while loading shared
             libraries: libgobject-2.0.so.0: cannot open shared object file: No such file or
            directory
              sdetweil @codac
              @codac yeh, seems that electron needs something from the container
              do you know which container you are using?
              @karsten13 can u look at this
              • karsten13K
                karsten13 @sdetweil
                he must restart the container, this cannot be done from inside the container
                so how was the container started? With docker compose oder docker run ... or?
                  sdetweil @karsten13
                  @karsten13 this
                  libgobject-2.0.so.0: cannot open shared object file: No such file or directory
                  will be fixed by container restart ?
                  karsten13K C 2 Replies Last reply Reply Quote 0
                  • karsten13K
                    karsten13 @sdetweil
                    I don’t now, the old electron process is still running
                    but we now nothing, how he started, in server only or with electron, which architecture, which host os, which hardware …
                      codac @karsten13
                      @karsten13
                      docker run
                        codac @sdetweil
                        This error only comes up when trying to restart MM inside the docker.
                        When restarting the docker, this error wont show up.
                          codac @karsten13
                          @karsten13
                          This is a server only setup. Docker runs on “Container Manager” of Synology. The Synology is a DS420+ running on an INTEL Celeron J4025. The OS is DSM of course.
                          • karsten13K
                            karsten13 @codac
                            @codac
                            and how do you start/stop the container? With a WebUI or per command line?
                              codac @karsten13
                              @karsten13 WebUI
                              S karsten13K 2 Replies Last reply Reply Quote 0
                                sdetweil @codac
                                @codac and I think the electron error is just noise, as you must be running server only mode, whcih doesn’t use electron
                                • karsten13K
                                  karsten13 @codac
                                  @codac
                                  I don’t know this WebUI, you have to restart the container or stop and start again, whatever the WebUI provides
                                  • karsten13K
                                    karsten13 @sdetweil
                                    yes, there is no electron installed
                                      codac @karsten13
                                      @karsten13 well restarting / stopping / starting is no problem. But the error just remains and doesnt go away…
                                        sdetweil @codac
                                        @codac which error? the node-fetch or the lib error?
                                        (@karsten13 we installed electron, my mistake… in docker, doah! )
                                          codac @sdetweil
                                          @sdetweil the node-fetch error
                                          • karsten13K
                                            karsten13 @codac
                                            @codac
                                            if you are using https://github.com/0m4r/MMM-SoccerLiveScore the module contains the missing node-fetch so you should do a git pull in the module folder and try again (which means restart the container)
