    Cannot find module 'node-fetch' error with MMM-SoccerLiveScore
    34 Posts 5 Posters 15.9k Views 5 Watching
      sdetweil @codac
      @codac seen this happening more
      in the container again
      in the MagicMirror folder do
      npm install electron@27.2.0
        codac @sdetweil
        sorry for the hussle, but this seems to never end :anguished_face:
        after running
        I tried to restart MM:
        root@04492d039b9f:/opt/magic_mirror# DISPLAY=:0 npm restart
        > magicmirror@2.26.0 restart
        > npm stop --if-present && npm start
        > magicmirror@2.26.0 start
        /opt/magic_mirror/node_modules/electron/dist/electron: error while loading shared
         libraries: libgobject-2.0.so.0: cannot open shared object file: No such file or
        directory
          sdetweil @codac
          @codac yeh, seems that electron needs something from the container
          do you know which container you are using?
          @karsten13 can u look at this
          • karsten13K Offline
            karsten13 @sdetweil
            he must restart the container, this cannot be done from inside the container
            so how was the container started? With docker compose oder docker run ... or?
            S C 2 Replies Last reply Reply Quote 0
              sdetweil @karsten13
              @karsten13 this
              libgobject-2.0.so.0: cannot open shared object file: No such file or directory
              will be fixed by container restart ?
              karsten13K C 2 Replies Last reply Reply Quote 0
                karsten13 @sdetweil
                I don’t now, the old electron process is still running
                but we now nothing, how he started, in server only or with electron, which architecture, which host os, which hardware …
                  codac @karsten13
                  @karsten13
                  docker run
                    codac @sdetweil
                    This error only comes up when trying to restart MM inside the docker.
                    When restarting the docker, this error wont show up.
                      codac @karsten13
                      @karsten13
                      This is a server only setup. Docker runs on “Container Manager” of Synology. The Synology is a DS420+ running on an INTEL Celeron J4025. The OS is DSM of course.
                        karsten13 @codac
                        @codac
                        and how do you start/stop the container? With a WebUI or per command line?
                        • 1 / 4
