    Cannot find module 'node-fetch' error with MMM-SoccerLiveScore
    34 Posts 5 Posters 18.2k Views 5 Watching
      sdetweil @codac
      @codac seen this happening more
      in the container again
      in the MagicMirror folder do
      npm install electron@27.2.0
        codac @sdetweil
        sorry for the hussle, but this seems to never end :anguished_face:
        after running
        I tried to restart MM:
        root@04492d039b9f:/opt/magic_mirror# DISPLAY=:0 npm restart
        > magicmirror@2.26.0 restart
        > npm stop --if-present && npm start
        > magicmirror@2.26.0 start
        /opt/magic_mirror/node_modules/electron/dist/electron: error while loading shared
         libraries: libgobject-2.0.so.0: cannot open shared object file: No such file or
        directory
          sdetweil @codac
          @codac yeh, seems that electron needs something from the container
          do you know which container you are using?
          @karsten13 can u look at this
          • karsten13K Offline
            karsten13 @sdetweil
            he must restart the container, this cannot be done from inside the container
            so how was the container started? With docker compose oder docker run ... or?
            S C 2 Replies Last reply Reply Quote 0
              sdetweil @karsten13
              @karsten13 this
              libgobject-2.0.so.0: cannot open shared object file: No such file or directory
              will be fixed by container restart ?
              karsten13K C 2 Replies Last reply Reply Quote 0
                karsten13 @sdetweil
                I don’t now, the old electron process is still running
                but we now nothing, how he started, in server only or with electron, which architecture, which host os, which hardware …
                  codac @karsten13
                  @karsten13
                  docker run
                    codac @sdetweil
                    This error only comes up when trying to restart MM inside the docker.
                    When restarting the docker, this error wont show up.
                      codac @karsten13
                      @karsten13
                      This is a server only setup. Docker runs on “Container Manager” of Synology. The Synology is a DS420+ running on an INTEL Celeron J4025. The OS is DSM of course.
                        karsten13 @codac
                        @codac
                        and how do you start/stop the container? With a WebUI or per command line?
                          codac @karsten13
                          @karsten13 WebUI
                          S karsten13K 2 Replies Last reply Reply Quote 0
                            sdetweil @codac
                            @codac and I think the electron error is just noise, as you must be running server only mode, whcih doesn’t use electron
                              karsten13 @codac
                              @codac
                              I don’t know this WebUI, you have to restart the container or stop and start again, whatever the WebUI provides
                                karsten13 @sdetweil
                                yes, there is no electron installed
                                  codac @karsten13
                                  @karsten13 well restarting / stopping / starting is no problem. But the error just remains and doesnt go away…
                                    sdetweil @codac
                                    @codac which error? the node-fetch or the lib error?
                                    (@karsten13 we installed electron, my mistake… in docker, doah! )
                                      codac @sdetweil
                                      @sdetweil the node-fetch error
                                        karsten13 @codac
                                        @codac
                                        if you are using https://github.com/0m4r/MMM-SoccerLiveScore the module contains the missing node-fetch so you should do a git pull in the module folder and try again (which means restart the container)
                                          sdetweil @karsten13
                                          @karsten13 did they fix the module? I didn’t check
                                            karsten13 @sdetweil
                                            you are right, they “fixed” it in devDependencies instead in dependencies …
                                            then git pull is useless, you have to install the missing library in the module folder as sam already explained above
