    Cannot find module 'node-fetch' error with MMM-SoccerLiveScore
    34 Posts 5 Posters 15.8k Views 5 Watching
      codac
      Running @karsten13 Docker karsten13/magicmirror with the module MMM-SoccerLiveScore from @0m4r results in an error “Cannot find module ‘node-fetch’”.
      2024/01/02 19:18:29	stderr	[02.01.2024 19:18.29.537] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      2024/01/02 19:18:29	stderr	[02.01.2024 19:18.29.537] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      2024/01/02 19:18:29	stderr	}
      2024/01/02 19:18:29	stderr	  ]
      2024/01/02 19:18:29	stderr	    '/opt/magic_mirror/serveronly/index.js'
      2024/01/02 19:18:29	stderr	    '/opt/magic_mirror/js/app.js',
      2024/01/02 19:18:29	stderr	    '/opt/magic_mirror/modules/MMM-SoccerLiveScore/node_helper.js',
      2024/01/02 19:18:29	stderr	  requireStack: [
      2024/01/02 19:18:29	stderr	  code: 'MODULE_NOT_FOUND',
      2024/01/02 19:18:29	stderr	    at async App.start (/opt/magic_mirror/js/app.js:259:3) {
      2024/01/02 19:18:29	stderr	    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      2024/01/02 19:18:29	stderr	    at loadModules (/opt/magic_mirror/js/app.js:211:10)
      2024/01/02 19:18:29	stderr	    at loadModule (/opt/magic_mirror/js/app.js:181:19)
      2024/01/02 19:18:29	stderr	    at require (node:internal/modules/helpers:176:18)
      2024/01/02 19:18:29	stderr	    at Module.require (node:internal/modules/cjs/loader:1235:19)
      2024/01/02 19:18:29	stderr	    at Module._load (node:internal/modules/cjs/loader:1023:12)
      2024/01/02 19:18:29	stderr	    at Module.load (node:internal/modules/cjs/loader:1207:32)
      2024/01/02 19:18:29	stderr	    at Module._extensions..js (node:internal/modules/cjs/loader:1435:10)
      2024/01/02 19:18:29	stderr	    at Module._compile (node:internal/modules/cjs/loader:1376:14)
      2024/01/02 19:18:29	stderr	    at Object.<anonymous> (/opt/magic_mirror/modules/MMM-SoccerLiveScore/node_helper.js:10:15)
      2024/01/02 19:18:29	stderr	    at Module._load (node:internal/modules/cjs/loader:985:27)
      2024/01/02 19:18:29	stderr	    at Module._resolveFilename (/opt/magic_mirror/node_modules/module-alias/index.js:49:29)
      2024/01/02 19:18:29	stderr	    at Module._resolveFilename (node:internal/modules/cjs/loader:1144:15)
      2024/01/02 19:18:29	stderr	- /opt/magic_mirror/serveronly/index.js
      2024/01/02 19:18:29	stderr	- /opt/magic_mirror/js/app.js
      2024/01/02 19:18:29	stderr	- /opt/magic_mirror/modules/MMM-SoccerLiveScore/node_helper.js
      2024/01/02 19:18:29	stderr	Require stack:
      2024/01/02 19:18:29	stderr	[02.01.2024 19:18.29.537] [ERROR] Error: Cannot find module 'node-fetch'
      2024/01/02 19:18:29	stderr	[02.01.2024 19:18.29.533] [ERROR] Whoops! There was an uncaught exception...
      Any ideas about how to fix this?
        codac @karsten13
        @karsten13 said in Cannot find module 'node-fetch' error with MMM-SoccerLiveScore:
        NODE_ENV=test npm install node-fetch@2
        I could see that this time node-fetch got installed (different than before running npm install node-fetch@2 only).
        But after restarting the docker container, the same error remained.
          sdetweil @codac
          @codac you have to go into the docker container, in the MM module folder and do
            codac @sdetweil
            Thank you for the quick reply.
            Found that solution already in the forum.
            Result is though:
            up to date, audited 1 package in 2s
            found 0 vulnerabilities
            After restarting the docker container, the error remains.
              sdetweil @codac
              @codac then you didnt do the npm install in the correct module folder
              and I assume you have to restart MM of the container to pick up the change
                codac @sdetweil
                root@04492d039b9f:/opt/magic_mirror/modules# cd MMM-SoccerLiveScore
                root@04492d039b9f:/opt/magic_mirror/modules/MMM-SoccerLiveScore# npm install node
                -fetch@2
                up to date, audited 1 package in 1s
                How would I restart MM of the container?
                pm2 is not set up.
                DISPLAY=:0 npm restart
                …results in
                > magicmirror@2.26.0 restart
                > npm stop --if-present && npm start
                > magicmirror@2.26.0 start
                sh: 1: ./node_modules/.bin/electron: not found
                S C 2 Replies Last reply Reply Quote 0
                  sdetweil @codac
                  @codac seen this happening more
                  in the container again
                  in the MagicMirror folder do
                  npm install electron@27.2.0
                    codac @sdetweil
                    sorry for the hussle, but this seems to never end :anguished_face:
                    after running
                    I tried to restart MM:
                    root@04492d039b9f:/opt/magic_mirror# DISPLAY=:0 npm restart
                    /opt/magic_mirror/node_modules/electron/dist/electron: error while loading shared
                     libraries: libgobject-2.0.so.0: cannot open shared object file: No such file or
                    directory
                      sdetweil @codac
                      @codac yeh, seems that electron needs something from the container
                      do you know which container you are using?
                      @karsten13 can u look at this
                      • karsten13K Offline
                        karsten13 @sdetweil
                        he must restart the container, this cannot be done from inside the container
                        so how was the container started? With docker compose oder docker run ... or?
                          sdetweil @karsten13
                          @karsten13 this
                          libgobject-2.0.so.0: cannot open shared object file: No such file or directory
                          will be fixed by container restart ?
                          karsten13K C 2 Replies Last reply Reply Quote 0
                          • 1 / 4
