    Cannot find module 'node-fetch' error with MMM-SoccerLiveScore
    34 Posts 5 Posters 19.5k Views 5 Watching
      sdetweil @karsten13
      @karsten13 this
      libgobject-2.0.so.0: cannot open shared object file: No such file or directory
      will be fixed by container restart ?
      karsten13K C 2 Replies Last reply
      • karsten13K
        karsten13 @sdetweil
        I don’t now, the old electron process is still running
        but we now nothing, how he started, in server only or with electron, which architecture, which host os, which hardware …
        C 1 Reply Last reply
          codac @karsten13
          @karsten13
          docker run
            codac @sdetweil
            This error only comes up when trying to restart MM inside the docker.
            When restarting the docker, this error wont show up.
              codac @karsten13
              @karsten13
              This is a server only setup. Docker runs on “Container Manager” of Synology. The Synology is a DS420+ running on an INTEL Celeron J4025. The OS is DSM of course.
              karsten13K 1 Reply Last reply
              • karsten13K
                karsten13 @codac
                @codac
                and how do you start/stop the container? With a WebUI or per command line?
                  codac @karsten13
                  @karsten13 WebUI
                  S karsten13K 2 Replies Last reply
                    sdetweil @codac
                    @codac and I think the electron error is just noise, as you must be running server only mode, whcih doesn’t use electron
                    • karsten13K
                      karsten13 @codac
                      @codac
                      I don’t know this WebUI, you have to restart the container or stop and start again, whatever the WebUI provides
                      • karsten13K
                        karsten13 @sdetweil
                        yes, there is no electron installed
                          codac @karsten13
                          @karsten13 well restarting / stopping / starting is no problem. But the error just remains and doesnt go away…
                            sdetweil @codac
                            @codac which error? the node-fetch or the lib error?
                            (@karsten13 we installed electron, my mistake… in docker, doah! )
                              codac @sdetweil
                              @sdetweil the node-fetch error
                              • karsten13K
                                karsten13 @codac
                                @codac
                                if you are using https://github.com/0m4r/MMM-SoccerLiveScore the module contains the missing node-fetch so you should do a git pull in the module folder and try again (which means restart the container)
                                  sdetweil @karsten13
                                  @karsten13 did they fix the module? I didn’t check
                                  • karsten13K
                                    karsten13 @sdetweil
                                    you are right, they “fixed” it in devDependencies instead in dependencies …
                                    then git pull is useless, you have to install the missing library in the module folder as sam already explained above
                                    KristjanESPERANTOK 1 Reply Last reply
                                    • KristjanESPERANTOK
                                      KristjanESPERANTO Module Developer @karsten13
                                      I created a PR to fix this, let’s see when @0m4r accept it.
                                      S 0m4r0 2 Replies Last reply
                                        sdetweil @KristjanESPERANTO
                                        @KristjanESPERANTO well, npm install would have installed the devDependencies too…
                                        KristjanESPERANTOK karsten13K 2 Replies Last reply
                                          @sdetweil Sure. But my PR removes node-fetch, so npm install is no longer necessary for this module.
                                          • karsten13K
                                            karsten13 @sdetweil
                                            This sentence clicked in my brain.
                                            I have NODE_ENV=production as default in my images (expect images I use for testing) and with this
                                            • npm install will install nothing
                                            • npm install node-fetch@2 will install nothing
                                            so @codac please go again in the folder of the module and run NODE_ENV=test npm install node-fetch@2
                                            this should hopefully solve the issue
