    Cannot find module 'node-fetch' error with MMM-SoccerLiveScore
    34 Posts 5 Posters 18.6k Views 5 Watching
      codac @sdetweil
      Thank you for the quick reply.
      Found that solution already in the forum.
      Result is though:
      up to date, audited 1 package in 2s
      found 0 vulnerabilities
      After restarting the docker container, the error remains.
        sdetweil @codac
        @codac then you didnt do the npm install in the correct module folder
        and I assume you have to restart MM of the container to pick up the change
          codac @sdetweil
          root@04492d039b9f:/opt/magic_mirror/modules# cd MMM-SoccerLiveScore
          root@04492d039b9f:/opt/magic_mirror/modules/MMM-SoccerLiveScore# npm install node
          -fetch@2
          up to date, audited 1 package in 1s
          How would I restart MM of the container?
          pm2 is not set up.
          DISPLAY=:0 npm restart
          …results in
          > magicmirror@2.26.0 restart
          > npm stop --if-present && npm start
          > magicmirror@2.26.0 start
          sh: 1: ./node_modules/.bin/electron: not found
          S C 2 Replies Last reply Reply Quote 0
            sdetweil @codac
            @codac seen this happening more
            in the container again
            in the MagicMirror folder do
            npm install electron@27.2.0
              codac @sdetweil
              sorry for the hussle, but this seems to never end :anguished_face:
              after running
              I tried to restart MM:
              root@04492d039b9f:/opt/magic_mirror# DISPLAY=:0 npm restart
              /opt/magic_mirror/node_modules/electron/dist/electron: error while loading shared
               libraries: libgobject-2.0.so.0: cannot open shared object file: No such file or
              directory
                sdetweil @codac
                @codac yeh, seems that electron needs something from the container
                do you know which container you are using?
                @karsten13 can u look at this
                • karsten13K Offline
                  karsten13 @sdetweil
                  he must restart the container, this cannot be done from inside the container
                  so how was the container started? With docker compose oder docker run ... or?
                    sdetweil @karsten13
                    @karsten13 this
                    libgobject-2.0.so.0: cannot open shared object file: No such file or directory
                    will be fixed by container restart ?
                    karsten13K C 2 Replies Last reply Reply Quote 0
                      karsten13 @sdetweil
                      I don’t now, the old electron process is still running
                      but we now nothing, how he started, in server only or with electron, which architecture, which host os, which hardware …
                        codac @karsten13
                        @karsten13
                        docker run
                          codac @sdetweil
                          This error only comes up when trying to restart MM inside the docker.
                          When restarting the docker, this error wont show up.
                            codac @karsten13
                            @karsten13
                            This is a server only setup. Docker runs on “Container Manager” of Synology. The Synology is a DS420+ running on an INTEL Celeron J4025. The OS is DSM of course.
                              karsten13 @codac
                              @codac
                              and how do you start/stop the container? With a WebUI or per command line?
                                codac @karsten13
                                @karsten13 WebUI
                                S karsten13K 2 Replies Last reply Reply Quote 0
                                  sdetweil @codac
                                  @codac and I think the electron error is just noise, as you must be running server only mode, whcih doesn’t use electron
                                    karsten13 @codac
                                    @codac
                                    I don’t know this WebUI, you have to restart the container or stop and start again, whatever the WebUI provides
                                      karsten13 @sdetweil
                                      yes, there is no electron installed
                                        codac @karsten13
                                        @karsten13 well restarting / stopping / starting is no problem. But the error just remains and doesnt go away…
                                          sdetweil @codac
                                          @codac which error? the node-fetch or the lib error?
                                          (@karsten13 we installed electron, my mistake… in docker, doah! )
                                            codac @sdetweil
                                            @sdetweil the node-fetch error
