    Cannot find module 'node-fetch' error with MMM-SoccerLiveScore
    34 Posts 5 Posters 18.6k Views 5 Watching
      codac @sdetweil
      root@04492d039b9f:/opt/magic_mirror/modules# cd MMM-SoccerLiveScore
      root@04492d039b9f:/opt/magic_mirror/modules/MMM-SoccerLiveScore# npm install node
      -fetch@2
      up to date, audited 1 package in 1s
      found 0 vulnerabilities
      How would I restart MM of the container?
      pm2 is not set up.
      DISPLAY=:0 npm restart
      …results in
      > magicmirror@2.26.0 restart
      > npm stop --if-present && npm start
      > magicmirror@2.26.0 start
      sh: 1: ./node_modules/.bin/electron: not found
      S C 2 Replies Last reply Reply Quote 0
        sdetweil @codac
        @codac seen this happening more
        in the container again
        in the MagicMirror folder do
        npm install electron@27.2.0
          codac @sdetweil
          sorry for the hussle, but this seems to never end :anguished_face:
          after running
          I tried to restart MM:
          root@04492d039b9f:/opt/magic_mirror# DISPLAY=:0 npm restart
          /opt/magic_mirror/node_modules/electron/dist/electron: error while loading shared
           libraries: libgobject-2.0.so.0: cannot open shared object file: No such file or
          directory
            sdetweil @codac
            @codac yeh, seems that electron needs something from the container
            do you know which container you are using?
            @karsten13 can u look at this
            • karsten13K Offline
              karsten13 @sdetweil
              he must restart the container, this cannot be done from inside the container
              so how was the container started? With docker compose oder docker run ... or?
                sdetweil @karsten13
                @karsten13 this
                libgobject-2.0.so.0: cannot open shared object file: No such file or directory
                will be fixed by container restart ?
                karsten13K C 2 Replies Last reply Reply Quote 0
                  karsten13 @sdetweil
                  I don’t now, the old electron process is still running
                  but we now nothing, how he started, in server only or with electron, which architecture, which host os, which hardware …
                    codac @karsten13
                    @karsten13
                    docker run
                      codac @sdetweil
                      This error only comes up when trying to restart MM inside the docker.
                      When restarting the docker, this error wont show up.
                        codac @karsten13
                        @karsten13
                        This is a server only setup. Docker runs on “Container Manager” of Synology. The Synology is a DS420+ running on an INTEL Celeron J4025. The OS is DSM of course.
                          karsten13 @codac
                          @codac
                          and how do you start/stop the container? With a WebUI or per command line?
                            codac @karsten13
                            @karsten13 WebUI
                            S karsten13K 2 Replies Last reply Reply Quote 0
                              sdetweil @codac
                              @codac and I think the electron error is just noise, as you must be running server only mode, whcih doesn’t use electron
                                karsten13 @codac
                                @codac
                                I don’t know this WebUI, you have to restart the container or stop and start again, whatever the WebUI provides
                                  karsten13 @sdetweil
                                  yes, there is no electron installed
                                    codac @karsten13
                                    @karsten13 well restarting / stopping / starting is no problem. But the error just remains and doesnt go away…
                                      sdetweil @codac
                                      @codac which error? the node-fetch or the lib error?
                                      (@karsten13 we installed electron, my mistake… in docker, doah! )
                                        codac @sdetweil
                                        @sdetweil the node-fetch error
                                          karsten13 @codac
                                          @codac
                                          if you are using https://github.com/0m4r/MMM-SoccerLiveScore the module contains the missing node-fetch so you should do a git pull in the module folder and try again (which means restart the container)
                                            sdetweil @karsten13
                                            @karsten13 did they fix the module? I didn’t check
