    MM current version on Raspberry Pi 5 cannot turn off monitor
    53 Posts 9 Posters 44.4k Views 9 Watching
      JohnGalt
      I’m having the same issues… I recently built a new MagicMirror instance using the latest Raspbian OS, and the commands I have used in prior instances don’t work in the new OS.
      None of the commands listed above work for me. I have also tried the following in the crontab. While it DOES turn off the monitor display, the display turns itself back on in about 10 seconds…
      display_off >/dev/null 2>&1
      Any help will be greatly appreciated, as the MagicMirror is in a location where running the display all night is disrupting people’s sleep, and having to manually turn it on and off is very inconvenient.
      J 2 Replies Last reply
        jbat66 @JohnGalt
        @JohnGalt I have a Pi 4, but have the latest OS, and I never have found a way to turn off the monitor. I have the same problem of the screen being too bright, so what I did was write a bash script, to turn off the background slide show, and to dim all the modules via the api into MMM-remote. I also have in my script just a hide all, and the screen goes blank, even tho the monitor is still on.
        Here is how you can hide all modules
        curl -X GET “$API_URL/api/module/all/hide” -H “accept: application/json”
        the $API_URL, is your IP address. I use “http://localhost:8080”
        I also wrote a script that will get the sunrise sunset times for the day and shut off my screen by hiding or diming all the modules at sunset, and then reverse that at sunrise.
        let me know if you are interested. I need to put some of my stuff up on github. I’m just getting familiar with github, and have fixed a couple of modules for folks in the last week.
        J 1 Reply Last reply
          jbat66 @JohnGalt
          @JohnGalt Side note, I will buy someone a pizza, if I can get working commands to actually turn off and turn on my HDMI display. I think I have tried everything on the internet with no luck. I’m serious about the pizza!
            sdetweil @jbat66
            @jbat66 you have to use the CEC client and have a CEC enabled display/monitor/tv.
            the energy star standard forces the big blue screen when u turn off the HDMI port output.
            all of the monitors since 2016 support the energy star std
            I can turn off my TV, but it won’t turn on. so the CEC support is broken.
            I hide all the modules. I use a web cam for motion detection
            I consider the glow to be the nightlight
            my pi3 doesn’t support using CEC client. nor odroid, Jetson nano, or my amd desktop or my Mac mini , or Chromebox running ubuntu
            pi 4 and 5 do
            haven’t tried on pi0w2
            HDMI port has to be bidirectional
            BKeyportB J 2 Replies Last reply
            • BKeyportB
              By the way - I do this with my monitors (One CEC, one not using bookworm):
              Off:
              pm2 stop all
              DISPLAY=:0 xrandr --output HDMI-1 --off
              DISPLAY=:0 xrandr --output HDMI-2 --off
              echo 'standby 0' | cec-client -s -d 1
              On:
              echo 'on 0' | cec-client -s -d 1
              sleep 20
              DISPLAY=:0 xrandr --output HDMI-1 --auto
              sleep 1
              DISPLAY=:0 xrandr --output HDMI-2 --auto --right-of HDMI-1
              sleep 1
              pm2 restart all
              I have to stop and start the mirror(s) because if I don’t, they’ll move on top of each other.
                jbat66 @sdetweil
                @sdetweil I’m just dimming all my modules and doing with the ‘nightlight’ effect. lol
                The Vilros Magic Mirror is using hdmi, but looks like CEC doesn’t work.
                https://www.amazon.com/gp/product/B0BJXD68JV
                  jbat66 @BKeyport
                  @BKeyport Thanks. I tried these on my Vilros Magic Mirror, and nothing happened, just errors. I tried them on my Raspberry PI 4 running older rasbian, and it work on there. except my monitor just went to flashing blue white pink. I guess that is the default no input screen. lol
                  I think turning off the monitors have more to do with the version of rasbian, than with the hardware. IMHO
                  S BKeyportB 2 Replies Last reply
                    sdetweil @jbat66
                    @jbat66 yeh, probably the monitor they use behind the glass doesn’t support CEC
                      sdetweil @jbat66
                      @jbat66 said in MM current version on Raspberry Pi 5 cannot turn off monitor:
                      just unlug the hdmi cable, then u should see the default no input screen
                      • BKeyportB
                        BKeyport Module Developer @jbat66
                        @jbat66 Oh, Wait, I just realized - I switched bookworm into X11 mode rather than Wayland - you may need to do that as well (I couldn’t get some operations I wanted to do to work in Wayland, yet - setting in raspi-config/advanced if you’re using RasOS)
                        If you don’t mind the monitor running but just want a blank screen, turn off the background picture, set the color to black, and remove the taskbar, then turn off MM and let it be. Might still get a mouse cursor, but there’s tools for that (Unclutter?)
                          jbat66 @BKeyport
                          @BKeyport Thanks, I’m already turning off my background pictures, and just dimming (could also just hide all) modules. The problem is that I want to turn off the screen but leave the pi running, because one of my MM will be in an RV and when boondocking (running on batteries) you want to use as little power as you can, so it is silly to run the screen at night.
                          I am using wayland, didn’t know I could goto X11, and not have a problem with MM. I may look into that, thanks!!
                          As a side note I couldn’t get unclutter to remove the mouse in wayland as it does in X, but I found ydotool using this command works well in wayland to move the mouse to the bottom right corner, so it only shows one pixel. :-)
                          ydotool mousemove -x 5000 -y 5000
                          right now, I have installed physical buttons, so I can shut the screen and pi down manually. I may crontab a shutdown of the pi, and then use yo-link (home automation switch) to kill the power after the crontab shutdown is done.
                            sdetweil @jbat66
                            @jbat66 the mouse pointer should not show on the mm screen by default.
                            the main.css sets cursor to display:none;
                            BKeyportB 1 Reply Last reply
                            • BKeyportB
                              @sdetweil Should is the key word. Some bug somewhere is causing the system to come up background to various things - sometimes mouse is on screen, sometimes the pi menubar is in front of the window (rare, but does happen). I had to use unclutter to fix one, and hide the menubar to fix the other. I know it’s not us, so it’s not reported to MM github issue.
                              • BKeyportB
                                @jbat66 not sure how much power the pi+power supply takes and if it would be worth it to shut it down overnight. Could rig a button to do a graceful shutdown, then use the power down button to shut down both the pi and the monitor. Interesting ideas here. Let me know what you come up with.
                                S J 2 Replies Last reply
                                  sdetweil @BKeyport
                                  @BKeyport i have been transitioning to Home Assistant for my home austomation platform.
                                  and interesting idea being described for integrating older devices, like washing machine, is to monitor the power consumption with a smart plug… (I don’t know which do that in the US)
                                  I wonder if the ps also has a lower consumption that can be measured and used as a trigger to turn off the smart switch when the power drops after pi shuts down…
                                  i’ll have to try to find one of these outlets
                                  maybe
                                  https://www.amazon.com/gp/product/B08TNF4835/ref=ox_sc_act_title_4?smid=ATVPDKIKX0DER&psc=1
                                    jbat66 @sdetweil
                                    @sdetweil Get a Yo-Link Plug. They have an API, you get your API key from an advanced menu in their app. Their plugs do grab usage, I have not used the API to grab usage, just to turn on and off, and to get temperatures from their sensors. I then use the API in MM to display the temperatures.
                                    https://www.amazon.com/s?k=yolink+smart+plug
                                    The whole Yo-Link echo system is great for DIY folks in home automation.
                                      sdetweil @jbat66
                                      @jbat66 trying to find devices without host connections… get more/all local
                                        jbat66 @BKeyport
                                        @BKeyport the physical Mirror’s Power supply is the only thing I plug in, and the PI gets its power from USB from the display, so no extra power source to monitor.
                                        I will probably just do a bash script to shut down the pi at some time say 10:00pm, then I will have Alexa shut down the mirror’s power (thus the pi as well) via a Yo-Link smart plug at 10:05pm. Then at sunrise via Amazon Alexa, I will just turn on mirror.
                                        I already do this for my RV Starlink, since I have cell modem as a backup, I can use the internet to turn on and off my internet. lol
                                          jbat66 @sdetweil
                                          @sdetweil said in MM current version on Raspberry Pi 5 cannot turn off monitor:
                                          While the Yo-Link is great it is cloud and you can’t do local yet. They have been talking about it in their forums, however.
                                            jbat66 @sdetweil
                                            I looked it up and you can get power readings via the API.
                                            http://doc.yosmart.com/docs/yolinkapi/Outlet
