    MMM-IPCam - Display images from your (foscam) ip camera
    17 Posts 9 Posters 19.8k Views 9 Watching
      Mitchfarino Module Developer
      Nice work!
      Could it be used in conjunction with this?
      http://projects.privateeyepi.com/
      I’m thinking of using a second Pi as a back up security system
        desq
        Not much more info…
        As seems as if the img url is still a xml-Object;
        Notification: GET_CAM Payload: [object Object]
        { undefined: 'undefined' }
          RedNax Module Developer @desq
          @desq What’s the entire content of img tag in your screenshot? Could it be that your cam’s not compatible maybe?
            desq
            seems to be the issue. (my Foscam FI9853EP)
            Here is content of the “Object”;
            404 - Not Found
            404 - Not Found
              Looks like your cam isn’t supported by https://github.com/fvdm/nodejs-foscam which is what i’m using in the module.
              Could you have a look here http://foscam.us/forum/how-to-get-jpg-pictures-and-mj-stream-on-fi9821w-fi9801-02w-t4328.html and see if you can get a jpeg from your cam? If so i could try to incorporate it…
                desq @RedNax
                @RedNax I´m using a mjpeg stream to view my camera on my small magic mirror.
                no need to tinker to support my “unsupported” cam.
                  binderth
                  I got a FOSCAM FI-9805W, which seems also not supported. I think, there are different FOSCAM APIs out there.
                  My camera returns a JPG after this call:
                  • http://192.168.x.x:8080/cgi-bin/CGIProxy.fcgi?usr=XXX&pwd=xxx&cmd=snapPicture2
                  I’m not sure, which one the library uses? the one of the foscam forum works with me.
                  • V Offline
                    Vitiate @desq
                    @desq How are you doing this?
                      desq
                      @Vitiate I´m using the mjpeg-Stream from my ipCam;
                      document.getElementById("foscam").src = "http://0.0.0.0:Port/cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=USER&pwd=PASS";
                      Mitch1138M 1 Reply Last reply Reply Quote 0
                      • Mitch1138M Offline
                        Mitch1138 @desq
                        I am new to MagicMirror but do have several modules working, but no success with IpCam. The module is in the MMM-IpCam folder in magicMirror/modules but on startup the entire screen is black. If I remove MM-IpCam from the config file, everything comes back. I can successfully stream images from by camera and a web browser with: http://0.0.0.0:port/cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=&pwd=. Any suggestions? Thanks.
                        • F Offline
                          fox @Mitchfarino
                          @Mitchfarino said in MMM-IPCam - Display images from your (foscam) ip camera:
                          Nice work!
                          i would appreciate this !
                          Issues With MMM-WatchDog known?
                          https://forum.magicmirror.builders/post/29827
                          Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                            bhepler Module Developer @Mitch1138
                            @Mitch1138 Usually a black screen indicates an error with the config.js file. It’s possible you made a minor mistake in the module’s configuration settings. If you post it here we can take a look at it and see if anything obvious shows up.
                              Mitch1138
                              Thanks for the help. All my other modules work fine. This is an F19831P and I can display a live stream by putting this address ina web browser: http://192.168.0.10:80/cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=username&pwd=pw&t
                              Here is the code I put in the config.js:
                                                   module: 'MMM-IPCam',
                                      		position: 'top_left',
                                          		invertColors: false,
                                          		updateInterval : 10000,
                                          		host: '192.168.0.10',
                                          		port: 80,
                                          		user: 'userpw',
                                          		pass: 'pw'
                              • O Offline
                                ooom416354
                                I have a night owl camera system and was wondering if this particular module would work with those? Me module was previously titled for only foscam but I am not sure if it would work with all IP camera systems.
                                Thanks.
