    MMM-IPCam - Display images from your (foscam) ip camera
    17 Posts 9 Posters 20.0k Views 9 Watching
      RedNax Module Developer
      [card:RedNax67/MMM-IPCam]
      Display ipcam (foscam and compatible) feed on MagicMirror
        desq
        Hi.
        doesn´t work for me. I just get “undefined” and an missing img symbol;
        Do you have hint?
        desq
        R 2 Replies Last reply
          RedNax Module Developer @desq
          @desq
          Could cou examine the pm2 logs for more information? ~/.pm2/logs
          The screenprint is not very helpful i’m afraid…
            Mitchfarino Module Developer
            Nice work!
            Could it be used in conjunction with this?
            http://projects.privateeyepi.com/
            I’m thinking of using a second Pi as a back up security system
            F 1 Reply Last reply
              desq
              Not much more info…
              As seems as if the img url is still a xml-Object;
              Notification: GET_CAM Payload: [object Object]
              { undefined: 'undefined' }
                @desq What’s the entire content of img tag in your screenshot? Could it be that your cam’s not compatible maybe?
                  desq
                  seems to be the issue. (my Foscam FI9853EP)
                  Here is content of the “Object”;
                  404 - Not Found
                  404 - Not Found
                    Looks like your cam isn’t supported by https://github.com/fvdm/nodejs-foscam which is what i’m using in the module.
                    Could you have a look here http://foscam.us/forum/how-to-get-jpg-pictures-and-mj-stream-on-fi9821w-fi9801-02w-t4328.html and see if you can get a jpeg from your cam? If so i could try to incorporate it…
                    D 1 Reply Last reply
                      desq @RedNax
                      @RedNax I´m using a mjpeg stream to view my camera on my small magic mirror.
                      no need to tinker to support my “unsupported” cam.
                      V 1 Reply Last reply
                        binderth
                        I got a FOSCAM FI-9805W, which seems also not supported. I think, there are different FOSCAM APIs out there.
                        My camera returns a JPG after this call:
                        • http://192.168.x.x:8080/cgi-bin/CGIProxy.fcgi?usr=XXX&pwd=xxx&cmd=snapPicture2
                        I’m not sure, which one the library uses? the one of the foscam forum works with me.
                        • V
                          Vitiate @desq
                          @desq How are you doing this?
                            desq
                            @Vitiate I´m using the mjpeg-Stream from my ipCam;
                            document.getElementById("foscam").src = "http://0.0.0.0:Port/cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=USER&pwd=PASS";
                            Mitch1138M 1 Reply Last reply
                            • Mitch1138M
                              Mitch1138 @desq
                              I am new to MagicMirror but do have several modules working, but no success with IpCam. The module is in the MMM-IpCam folder in magicMirror/modules but on startup the entire screen is black. If I remove MM-IpCam from the config file, everything comes back. I can successfully stream images from by camera and a web browser with: http://0.0.0.0:port/cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=&pwd=. Any suggestions? Thanks.
                              B 1 Reply Last reply
                              • F
                                fox @Mitchfarino
                                @Mitchfarino said in MMM-IPCam - Display images from your (foscam) ip camera:
                                Nice work!
                                i would appreciate this !
                                Issues With MMM-WatchDog known?
                                https://forum.magicmirror.builders/post/29827
                                Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                                  bhepler Module Developer @Mitch1138
                                  @Mitch1138 Usually a black screen indicates an error with the config.js file. It’s possible you made a minor mistake in the module’s configuration settings. If you post it here we can take a look at it and see if anything obvious shows up.
                                  • Mitch1138M
                                    Mitch1138
                                    Thanks for the help. All my other modules work fine. This is an F19831P and I can display a live stream by putting this address ina web browser: http://192.168.0.10:80/cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=username&pwd=pw&t
                                    Here is the code I put in the config.js:
                                                         module: 'MMM-IPCam',
                                            		position: 'top_left',
                                                		invertColors: false,
                                                		updateInterval : 10000,
                                                		host: '192.168.0.10',
                                                		port: 80,
                                                		user: 'userpw',
                                                		pass: 'pw'
                                    • O
                                      ooom416354
                                      I have a night owl camera system and was wondering if this particular module would work with those? Me module was previously titled for only foscam but I am not sure if it would work with all IP camera systems.
                                      Thanks.
