    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.6m Views 33 Watching
      sdetweil @Manu85
      @Manu85 it’s ok, none of us knew much when we started. so take your time.
      to use a code block in these messages
      • paste in your text (like from config.js)
      • then select all that text
      • and then push the button above the editor that looks like </>
      I copied your pasted text into my custom.css
      and the double quote marks became curved.
      this is a special word processing quote mark, which is different that text mode quote mark
      css needs the text type, straight up and down
      (this is because of the lack of the code block wrapper)
      this prevented the css from being processed correctly
        Manu85 @sdetweil
        @sdetweil thank you for your patience and for your help, I copied all the lines for the custom css and I pasted it into the “site text editor” sorry for the terms but they are probably not good, then I selected the text, I pressed the </> button and on the other window I had the modified text (see screen copy) then I copied this new text and I copied it into the custom css and the original weather icons have disappeared but I don’t have any new icons, see the other screenshot, I will get there thanks to you :-)
          sdetweil @Manu85
          @Manu85 the code block wrapper only matters here in the forums.
          don’t use it anywhere else
          I just wanted to tell you if you copied the css info from another place, to examine the shape of the double quotes. if they are curved
          and not straight
          then this will cause problems in the css file, it did for me.
            Manu85 @sdetweil
            @sdetweil I did the manipulation on this forum and the text that I copied into my custom css has this form:
            .weather .wi-day-sunny {
            content: url(“/css/icons/day.svg”);
              sdetweil @Manu85
              @Manu85 ok. if you zoom in on the double quotes in your last post, you will see they are curved
                Manu85 @sdetweil
                @sdetweil exactly right, but I no longer have weather icons :beaming_face_with_smiling_eyes:
                  sdetweil @Manu85
                  @Manu85 show me a couple entries from you custom.css now
                  remember to use the code block
                  and the icons ARE in the css/icons folder, correct?
                  mine are in css/icons/static , as I unzipped the zip file from your link into the css/icons folder
                  content: url("/css/icons/static/day.svg");
                  .weather .wi-day-cloudy {
                  content: url("/css/icons/static/cloudy-day-1.svg");
                    Manu85 @sdetweil
                    @sdetweil dans mon custom css j’ai fait ces entrées par exemple (je ne sais pas si c’est ce que vous voulez…):
                     * SONDE DHT 22 temperature interieur
                    #dht_temp {
                      font-size: 40px;
                     * TEMPERATURE CPU
                    #pi_temp {
                      font-size: 30px;
                     * CALENDRIER ICONES AGENDA
                    .fa.fa-male {
                      color: #2B60DE; /* Dodger Blue */
                    .fa.fa-birthday-cake {
                      color: #ff0000; /* Red */
                    .fa.fa-trash-o {
                      color: #00FF00; /* Green */
                    .fa.fa-calendar {
                      color: #F660AB; /* Hot Pink */
                      sdetweil @Manu85
                      @Manu85 well, I meant the css info for the icons for weather
                        Manu85 @sdetweil
                        @sdetweil ah ok here are the entries in my custom css file for the weather, is this what you want?
                        content: url(“/css/icons/cloudy-day-1.svg”);
                        .weather .wi-rain {
                        content: url(“/css/icons/rainy-6.svg”);
                        .weather .wi-night-clear {
                        content: url(“/css/icons/night.svg”);
                        .weather .wi-night-cloudy {
                        content: url(“/css/icons/cloudy-night-2.svg”);
                        padding-right: 15px;
                        padding-top: 10px;
                        .weather .wi-cloudy {
                        content: url(“/css/icons/cloudy.svg”);
                        .weather .wi-showers {
                        content: url(“/css/icons/rainy-7.svg”);
                        .weather .wi-thunderstorm {
                        content: url(“/css/icons/thunder.svg”);
                        .weather .wi-snow {
                        content: url(“/css/icons/snowy-6.svg”);
                        .weather .wi-cloudy-windy {
                        content: url(“/css/icons/cloudy-day-3.svg”);
                        .weather .wi-night-rain {
                        .weather .wi-night-snow {
                        .weather .wi-night-thunderstorm {
                        .weather .wi-night-showers {
                        .weather .wi-fog {
                        .weather .wi-night-alt-cloudy-windy {
                        content: url(“/css/icons/cloudy-night-1.svg”);
                        /* Aenderungen Wettervorhersage */
                        .weather .weathericon {
                        position: absolute;
                        left: 35px;
                        z-index: 1;
                        margin-top: -30px;
                        height: 60px;
                        padding-left: 6px;
                        padding-top: 5px;
                        height: 50px;
                        .weather .wi-rain {
                        padding-left: 8px;
                        padding-top: 5px;
                        height: 45px;
                        height: 50px;
                        padding-left: 5px;
                        padding-top: 7px;
                        .weather .wi-snow {
                        height: 45px;
                        padding-left: 8px;
                        padding-top: 7px;
                        padding-left: 8px;
                        padding-top: 5px;
                        height: 45px;
                        .weather .wi-fog {
                        height: 50px;
                        padding-left: 5px;
                        padding-top: 7px;
                          sdetweil @Manu85
                          @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
                          note that the quotes are leaning, not straight up and down
                          change like this
                          content: url("/css/icons/rainy-6.svg");
                            Manu85 @sdetweil
                            @sdetweil do they have to be like that? because that’s how they were before I modified them with </>
                            .currentweather .wi-day-sunny {
                            .currentweather .wi-day-cloudy {
                            .currentweather .wi-rain {
                              sdetweil @Manu85
                              @Manu85 they ALL must be straight up and down…
                              I was warning you that the copy you did originally had the wrong quote marks
                              they ALL MUST BE ONLY
                                Manu85 @sdetweil
                                @sdetweil like that ?
                                .currentweather .wi-night-clear {
                                content: url("/css/icons/night.svg");
                                  sdetweil @Manu85
                                  @Manu85 yes
                                  M 3 Replies Last reply Reply Quote 0
                                    Manu85 @sdetweil
                                    @sdetweil excuse me, I’ll do it right away
                                      Manu85 @sdetweil
                                      @sdetweil by putting them straight up and down my weather has the original icons
                                        Manu85 @sdetweil
                                        @sdetweil sorry for my mistakes
                                          Manu85
                                          Your precious help allowed me to succeed in having the icons on the mirror :-), I added a few lines in the custom to position each icon, for example:
                                          padding-left: 60px;
                                          padding-top: 7px;
                                          height: 50px;
                                          the last thing to do is how to manage the current day icon (position and size) because on the original file there was a part:.currentweather .weathericon { and another part:.weatherforecast .weathericon {
                                          Following your help I named everything: .weather .weathericon { so that it works and I think that now it no longer makes a difference between current and forecast and I cannot manage the icon of the current day. Do you have any ideas on how to handle this?
                                          Thank you for your valuable help
                                            sdetweil @Manu85
                                            @Manu85 yes the current/forecast are not unique modules now…but mm provides a way to differentiate between two of the same module
                                            you can add arbitrary names that are used in the class of the module in the html tree, and then use that class in your custom.css
                                            I wish I had thought of the sooner
                                            in the config.js for one of the weather modules, showing forecast for instance, after the module name line add
                                                module:"weather",
                                                classes:"forecast",
                                            then in the custom.css, for the icons used in forecast change the primary selector
                                            from
                                            .weather
                                            to
                                            .forecast
                                            if I had thought of this first, we would have just added the two classes lines in config.js
                                            one for currentweather and one for weatherforecast, each on the appropriate weather module instance
                                            M 2 Replies Last reply Reply Quote 1
                                            • 15
                                            • 16
                                            • 4 / 16
