    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      Manu85 @sdetweil
      @sdetweil hello, I waited this morning to read your response and have clear ideas, but I do not have the level of knowledge required to do what you are asking me :-( , I have never used "code block wrapper " etc. and I have never coded, you are really very nice but this is beyond my skills, I managed to install the MM on my raspberry pi 3b+, I know how to install modules from github, make some adaptations in the custom css file by following tutorials but my skills stop there, initially I just wanted to change the icons of the weather module, the module is very good because the icons are not very pretty but I realize that it is not is not as simple as I thought, I am really sorry to have wasted your time and I thank you again for your patience and your sharing of knowledge, I have the temperament of a winner but in this specific case I reach my limits :-)
        sdetweil @Manu85
        @Manu85 it’s ok, none of us knew much when we started. so take your time.
        to use a code block in these messages
        • paste in your text (like from config.js)
        • then select all that text
        • and then push the button above the editor that looks like </>
        I copied your pasted text into my custom.css
        and the double quote marks became curved.
        this is a special word processing quote mark, which is different that text mode quote mark
        css needs the text type, straight up and down
        (this is because of the lack of the code block wrapper)
        this prevented the css from being processed correctly
          Manu85 @sdetweil
          @sdetweil thank you for your patience and for your help, I copied all the lines for the custom css and I pasted it into the “site text editor” sorry for the terms but they are probably not good, then I selected the text, I pressed the </> button and on the other window I had the modified text (see screen copy) then I copied this new text and I copied it into the custom css and the original weather icons have disappeared but I don’t have any new icons, see the other screenshot, I will get there thanks to you :-)
            sdetweil @Manu85
            @Manu85 the code block wrapper only matters here in the forums.
            don’t use it anywhere else
            I just wanted to tell you if you copied the css info from another place, to examine the shape of the double quotes. if they are curved
            and not straight
            then this will cause problems in the css file, it did for me.
              Manu85 @sdetweil
              @sdetweil I did the manipulation on this forum and the text that I copied into my custom css has this form:
              .weather .wi-day-sunny {
              content: url(“/css/icons/day.svg”);
                sdetweil @Manu85
                @Manu85 ok. if you zoom in on the double quotes in your last post, you will see they are curved
                  Manu85 @sdetweil
                  @sdetweil exactly right, but I no longer have weather icons :beaming_face_with_smiling_eyes:
                    sdetweil @Manu85
                    @Manu85 show me a couple entries from you custom.css now
                    remember to use the code block
                    and the icons ARE in the css/icons folder, correct?
                    mine are in css/icons/static , as I unzipped the zip file from your link into the css/icons folder
                    content: url("/css/icons/static/day.svg");
                    .weather .wi-day-cloudy {
                    content: url("/css/icons/static/cloudy-day-1.svg");
                      Manu85 @sdetweil
                      @sdetweil dans mon custom css j’ai fait ces entrées par exemple (je ne sais pas si c’est ce que vous voulez…):
                       * SONDE DHT 22 temperature interieur
                      #dht_temp {
                        font-size: 40px;
                       * TEMPERATURE CPU
                      #pi_temp {
                        font-size: 30px;
                       * CALENDRIER ICONES AGENDA
                      .fa.fa-male {
                        color: #2B60DE; /* Dodger Blue */
                      .fa.fa-birthday-cake {
                        color: #ff0000; /* Red */
                      .fa.fa-trash-o {
                        color: #00FF00; /* Green */
                      .fa.fa-calendar {
                        color: #F660AB; /* Hot Pink */
                        sdetweil @Manu85
                        @Manu85 well, I meant the css info for the icons for weather
                          Manu85 @sdetweil
                          @sdetweil ah ok here are the entries in my custom css file for the weather, is this what you want?
                          content: url(“/css/icons/cloudy-day-1.svg”);
                          .weather .wi-rain {
                          content: url(“/css/icons/rainy-6.svg”);
                          .weather .wi-night-clear {
                          content: url(“/css/icons/night.svg”);
                          .weather .wi-night-cloudy {
                          content: url(“/css/icons/cloudy-night-2.svg”);
                          padding-right: 15px;
                          padding-top: 10px;
                          .weather .wi-cloudy {
                          content: url(“/css/icons/cloudy.svg”);
                          .weather .wi-showers {
                          content: url(“/css/icons/rainy-7.svg”);
                          .weather .wi-thunderstorm {
                          content: url(“/css/icons/thunder.svg”);
                          .weather .wi-snow {
                          content: url(“/css/icons/snowy-6.svg”);
                          .weather .wi-cloudy-windy {
                          content: url(“/css/icons/cloudy-day-3.svg”);
                          .weather .wi-night-rain {
                          .weather .wi-night-snow {
                          .weather .wi-night-thunderstorm {
                          .weather .wi-night-showers {
                          .weather .wi-fog {
                          .weather .wi-night-alt-cloudy-windy {
                          content: url(“/css/icons/cloudy-night-1.svg”);
                          /* Aenderungen Wettervorhersage */
                          .weather .weathericon {
                          position: absolute;
                          left: 35px;
                          z-index: 1;
                          margin-top: -30px;
                          height: 60px;
                          padding-left: 6px;
                          padding-top: 5px;
                          height: 50px;
                          .weather .wi-rain {
                          padding-left: 8px;
                          padding-top: 5px;
                          height: 45px;
                          height: 50px;
                          padding-left: 5px;
                          padding-top: 7px;
                          .weather .wi-snow {
                          height: 45px;
                          padding-left: 8px;
                          padding-top: 7px;
                          padding-left: 8px;
                          padding-top: 5px;
                          height: 45px;
                          .weather .wi-fog {
                          height: 50px;
                          padding-left: 5px;
                          padding-top: 7px;
                            sdetweil @Manu85
                            @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
                            note that the quotes are leaning, not straight up and down
                            change like this
                            content: url("/css/icons/rainy-6.svg");
                              Manu85 @sdetweil
                              @sdetweil do they have to be like that? because that’s how they were before I modified them with </>
                              .currentweather .wi-day-sunny {
                              .currentweather .wi-day-cloudy {
                              .currentweather .wi-rain {
                                sdetweil @Manu85
                                @Manu85 they ALL must be straight up and down…
                                I was warning you that the copy you did originally had the wrong quote marks
                                they ALL MUST BE ONLY
                                  Manu85 @sdetweil
                                  @sdetweil like that ?
                                  .currentweather .wi-night-clear {
                                  content: url("/css/icons/night.svg");
                                    sdetweil @Manu85
                                    @Manu85 yes
                                    M 3 Replies Last reply Reply Quote 0
                                      Manu85 @sdetweil
                                      @sdetweil excuse me, I’ll do it right away
                                        Manu85 @sdetweil
                                        @sdetweil by putting them straight up and down my weather has the original icons
                                          Manu85 @sdetweil
                                          @sdetweil sorry for my mistakes
                                            Manu85
                                            Your precious help allowed me to succeed in having the icons on the mirror :-), I added a few lines in the custom to position each icon, for example:
                                            padding-left: 60px;
                                            padding-top: 7px;
                                            height: 50px;
                                            the last thing to do is how to manage the current day icon (position and size) because on the original file there was a part:.currentweather .weathericon { and another part:.weatherforecast .weathericon {
                                            Following your help I named everything: .weather .weathericon { so that it works and I think that now it no longer makes a difference between current and forecast and I cannot manage the icon of the current day. Do you have any ideas on how to handle this?
                                            Thank you for your valuable help
                                            • 15
                                            • 16
                                            • 4 / 16
