    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      Manu85 @sdetweil
      @sdetweil my js config says that!
      fig = {
      	port: 8080,
        sdetweil @Manu85
        @Manu85 yes, that means only apps INSIDE the same machine can connect
        change
        address:"localhost",  // means only inside same machine
        to
        address:"0.0.0.0",  // alows any device on any network this machine is connected to to connect
        then also the whitelist
        comment out the current line
        // ipWhitelist: [ 127.....
        and add a new line
           ipWhitelist:[],  // don't filter any connecting client addresses
        then restart mm…
        if you know the ip address of the pi (and u had to use it for vnc)
        then open a tab on you pc browser and do
        http://MM_ip_address????:8080
          Manu85 @sdetweil
          @sdetweil ok it’s done and it’s actually much better
            Manu85 @sdetweil
            @sdetweil by doing ctrl shift i my window opened like this
              sdetweil @Manu85
              @Manu85 yes, it just has the developers window docked on the bottom…
              helps when trying to do layout… nothing changes
              if you want it docked on the right, use the … menu top right of the dev window and change it…
                Manu85 @sdetweil
                when I position myself on a weather icon, it gives this, I cannot choose several I have a “grid” which follows the mouse and which changes when I move
                  sdetweil @Manu85
                  @Manu85 yes, you have to drag the windows around/resize them in the developers window
                    Manu85 @sdetweil
                    @sdetweil like that ?
                      sdetweil @Manu85
                      @Manu85 yes, very good…
                      now, up two lines is the module entry in the content,
                      and you can see that the extra class name has been added
                      (in pink)
                      so, in custom.css
                      .current  xxx
                      will target (select) content in that element tree
                      if you move down to one of the spans of the content
                      in green, and expand that , you will see the icon line,
                      if you select that in the next pane to the right you will see where the info comes from
                        Manu85 @sdetweil
                        I do what you tell me, but I must admit that I’m lost :-) I actually saw the “current” in the lines so that means that the icon is in the custom css, it’s that right? if so why can’t I manage it? you are too strong
                          sdetweil @Manu85
                          @Manu85 so close…
                          you have to click on the element with the icon name
                          here you have to expand the span element (gold box)
                          (the one you expanded below the gold box only has text in it, not an icon)
                            Manu85 @sdetweil
                            there, am I on it? I’m going to get there, I’m going to get there !!!
                              sdetweil @Manu85
                              @Manu85 now in the second column of the dev windows you can see the icon info and where it came from, custom.css
                                Manu85 @sdetweil
                                @sdetweil I try to move forward on the folder, I changed the destination folder for the “current” part by directing to a folder in css/icons/animated, but nothing changes, the supported icon is that of css/icons, red square (which keeps the properties, size, positioning of weather) I have the impression that “css/icons/animated” is not supported, green square, I think I am not far from the solution, but without your help I don’t think I’ll get there
                                  Manu85 @sdetweil
                                  @sdetweil Thanks to you, I finally managed to configure the weather module with animated icons, I finally understood the advantages and the settings possible with the console (ctrl+shift+i) it also allowed me to make other settings on other modules, it’s been 5 years since I did this MM and I learned more with you in 3 days than in 5 years, a big thank you for your help
                                    sdetweil @Manu85
                                    @Manu85 awesome!! glad you got it.
                                    that dev window is amazing for what you can discover and try
                                      manu85340 @sdetweil
                                      I will actually look precisely at the possibilities of this window, a thousand thanks Sam
                                        sdetweil @manu85340
                                        @manu85340 the top right window allows you to set styles on the selected element
                                        any style supported by the browser… color, font, icon, padding, border, you name it…
                                        so, you can test out the effect you want and then copy/paste those to the entry for custom.css
                                        one other learning thing…
                                        in css
                                        the stuff before the {
                                        is called the selector clause… it ‘selects’ the elements that that the stuff INSIDE the {} will apply to…
                                        the selector clause will ALWAYS select ALL elements that match , ALWAYS ALL
                                        but you can make it very selective…, it can be quite complex…
                                        here I want to hide (display :none) an element generated by a library I used
                                        that didn’t apply to the output it generated
                                        .possibly-hidden-tab div:nth-child(2)  > div > div >div >ul >li:only-child >a[rel*="Item%201"] {
                                          display: none;
                                        I use this page to help me with the selector clause possibilities and syntax
                                        https://www.w3schools.com/cssref/css_selectors.php
                                        sometimes it helps to look at the selector clause from right to left , what element is it, and how does it fit in the content its in.
                                        this selector clause is trying to find an <a (action/link) element with a title of “Item 1”
                                          Manu85 @sdetweil
                                          @sdetweil It’s really nice of you to share all these elements, I’m going to look at it while taking my time, I feel like the possibilities are endless
                                            sdetweil @Manu85
                                            @Manu85 no rush… just wanted to give you some base info to use as you explore.
                                            also from the MM doc on css
                                            https://docs.magicmirror.builders/modules/customcss.html#target-a-specific-module
                                            target and select mean the same
                                            • 15
                                            • 16
                                            • 6 / 16
