    MMM-CalendarExt3 issue Loading / Showing the calendar on Windows
    22 Posts 3 Posters 6.7k Views 3 Watching
      JackHammer325
      hello, im very new to all of this and I’ve followed all the guides I have found and I’ve even looked at similar instances on my issue in the forum but i can’t for the life of me figure out what is going wrong.
      This is the forum I tried to follow along with and i still couldn’t get it going.
      https://forum.magicmirror.builders/topic/18012/problem-installing-new-module-beginner-calendarext3-not-displaying?lang=en-US&page=1
      on the other hand this forum showed me how to see in a general area where the problem might be coming from.
      Here is the current Config that I’m running.
      /* MagicMirror² Config
      	language: "en",
      	locale: "en-US",
      	timeFormat: 24,
      	units: "metric",
      			header: "Upcoming Events",
      			coloredText: true,
      				broadcastPastEvents: true, // <= IMPORTANT to see past events
      						url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics",
      						color: "#2a4d56",
      						symbol: false
      						url: "https://calendar.google.com/calendar/xxxx",
      						color: "#0872fc",
      						symbol: false
      			module: "MMM-CalendarExt3",
      			position: "bottom_bar",
      			title: "my calendars",
      				mode: "month",
      				locale: 'en-US',
      				maxEventLines: 5,
      				firstDayOfWeek: 0,
      				weekIndex: 0,
      				weeksInView: 4,
      				waitFetch: 10 * 1000,
      				refreshInterval: 10 * 60 * 1000,
      				glanceTime: 0 * 60 * 1000,
      				eventTimeOptions: {
      					timeStyle: "short"
      				//useSymbol: false,
      				calendarSet: [ 'Holiday1' ],
      after following along in the mentioned forum about locating the issue using dev (developer tools)
      I was able to see this - (im currently using “node serveronly” cause for some reason i cant get it to run on its own but anyway thats another topic for another time, so this is what i see in the consol of the web browser).
      Initializing MagicMirror².
      translator.js:122 Loading core translation file: translations/en.json
      translator.js:138 Loading core translation fallback file: translations/en.json
      loader.js:165 Load script: modules/default/calendar/calendar.js
      module.js:476 Check MagicMirror² version for module 'calendar' - Minimum version:  2.1.0 - Current version: 2.26.0
      module.js:478 Version is ok!
      module.js:484 Module registered: calendar
      loader.js:138 Bootstrapping module: calendar
      loader.js:165 Load script: modules/default/calendar/calendarutils.js
      loader.js:165 Load script: vendor/node_modules/moment/min/moment-with-locales.js
      loader.js:142 Scripts loaded for: calendar
      loader.js:180 Load stylesheet: modules/default/calendar/calendar.css
      loader.js:180 Load stylesheet: vendor/css/font-awesome.css
      loader.js:145 Styles loaded for: calendar
      loader.js:148 Translations loaded for: calendar
      loader.js:165 Load script: modules/MMM-CalendarExt3/MMM-CalendarExt3.js
      MMM-CalendarExt3.js:4 This browser doesn't support popover yet. Update your system.
      module.js:484 Module registered: MMM-CalendarExt3
      loader.js:138 Bootstrapping module: MMM-CalendarExt3
      loader.js:142 Scripts loaded for: MMM-CalendarExt3
      loader.js:180 Load stylesheet: modules/MMM-CalendarExt3/MMM-CalendarExt3.css
      loader.js:145 Styles loaded for: MMM-CalendarExt3
      loader.js:148 Translations loaded for: MMM-CalendarExt3
      loader.js:180 Load stylesheet: css/custom.css
      localhost/:1 Refused to apply style from 'http://localhost:8080/css/custom.css' because its MIME type ('text/html') is not a supported stylesheet MIME type, and strict MIME checking is enabled.
      loader.js:190 Error on loading stylesheet: css/custom.css
      calendar.js:97 Starting module: calendar
      main.js:608 All modules started!
      MMM-CalendarExt3.js:372 [CX3] Module is not prepared yet, wait a while.
      getDom	@	MMM-CalendarExt3.js:372
      (anonymous)	@	main.js:138
      updateDom	@	main.js:118
      (anonymous)	@	main.js:61
      createDomObjects	@	main.js:20
      modulesStarted	@	main.js:611
      startModules	@	loader.js:43
      await in startModules (async)
      loadNextModule	@	loader.js:222
      await in loadNextModule (async)
      loadNextModule	@	loader.js:215
      loadModules	@	loader.js:225
      init	@	main.js:595
      await in init (async)
      (anonymous)	@	main.js:738
      TypeError: original.map(...).toSorted is not a function
          at formatEvents (CX3_shared.mjs:341:6)
          at prepareEvents (CX3_shared.mjs:376:10)
          at Class.draw (MMM-CalendarExt3.js:658:26)
          at Class.getDom (MMM-CalendarExt3.js:375:16)
          at main.js:138:35
          at new Promise (<anonymous>)
          at updateDom (main.js:118:10)
          at Object.updateDom (main.js:676:4)
          at Class.updateDom (module.js:336:6)
          at Class.updateAnimate (MMM-CalendarExt3.js:681:10)
      Promise.catch (async)
      (anonymous)	@	main.js:151
      updateDom	@	main.js:676
      updateDom	@	module.js:336
      updateAnimate	@	MMM-CalendarExt3.js:681
      (anonymous)	@	MMM-CalendarExt3.js:166
      setTimeout (async)
      (anonymous)	@	MMM-CalendarExt3.js:165
      Promise.then (async)
      start	@	MMM-CalendarExt3.js:162
      startModules	@	loader.js:26
      init	@	main.js:595
      let me know if this is too much info or not enough or anything really.
        MMRIZE @JackHammer325
        @JackHammer325 said in MMM-CalendarExt3 issue Loading / Showing the calendar on Windows:
        TypeError: original.map(…).toSorted is not a function
        Sorry for the late reply.
        This error message is caused by using an old browser or not supported.
        If you are using Chrome or Chromium, it’s version should be newer than v110( - released, 2023-02-07, Current version is v120). Or for other browser, See above picture.
          sdetweil @JackHammer325
          @JackHammer325 did you do the npm install in the module folder?
          are you running the correct version of node js? version 18 or above
          what platform are you on, show output of
          uname -a
          lsb_release -a
          node -a
          npm -a
            JackHammer325
            yes, I did.
            i even double checked .
            cd ~/MagicMirror/modules
            git clone https://github.com/MMRIZE/MMM-CalendarExt3
            cd MMM-CalendarExt3
            npm install
            git submodule update --init --recursive
            i even ran the update just to be sure
            cd ~/MagicMirror/modules/MMM-CalendarExt3
            git pull
            npm update
            im currently on Node.js ver 18.16.0
            running on windows 8.1
            not entirely sure how to “show output of” that you are asking
              @JackHammer325 ok, windows
              node -v and npm -v
              from a command prompt (cmd.exe) window
              the others are linux only
                JackHammer325 @sdetweil
                node -v = v18.16.0
                npm -v = 9.5.1
                  @JackHammer325 are you using the native windows or running in the linux subsystem for windows?
                    native windows with program Git Bash
                      @JackHammer325 do not need git bash
                      just cmd.exe
                      npm start
                      or npm run server
                      of course u have to change package.json per the instructions due to the windows backslash for path
                        so i followed these instructions
                        "start:dev": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js dev",
                        and replace it with
                        "start": ".\\node_modules\\.bin\\electron js\\electron.js",
                        "start:dev": ".\\node_modules\\.bin\\electron js\\electron.js dev",
                        but it still goes back to
                        C:\magicmirror>
                        and does nothing.
                          PC@WST MINGW32 /c/magicmirror
                          $ npm start
                          > magicmirror@2.26.0 start
                          > .\node_modules\.bin\electron js\electron.js
