    MMM-CalendarExt3 issue Loading / Showing the calendar on Windows
    22 Posts 3 Posters 6.5k Views 3 Watching
      JackHammer325
      yes, I did.
      i even double checked .
      cd ~/MagicMirror/modules
      git clone https://github.com/MMRIZE/MMM-CalendarExt3
      cd MMM-CalendarExt3
      npm install
      git submodule update --init --recursive
      i even ran the update just to be sure
      cd ~/MagicMirror/modules/MMM-CalendarExt3
      git pull
      npm update
      im currently on Node.js ver 18.16.0
      running on windows 8.1
      not entirely sure how to “show output of” that you are asking
        @JackHammer325 ok, windows
        node -v and npm -v
        from a command prompt (cmd.exe) window
        the others are linux only
          JackHammer325 @sdetweil
          node -v = v18.16.0
          npm -v = 9.5.1
            sdetweil @JackHammer325
            @JackHammer325 are you using the native windows or running in the linux subsystem for windows?
              native windows with program Git Bash
                @JackHammer325 do not need git bash
                just cmd.exe
                npm start
                or npm run server
                of course u have to change package.json per the instructions due to the windows backslash for path
                  so i followed these instructions
                  "start:dev": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js dev",
                  and replace it with
                  "start": ".\\node_modules\\.bin\\electron js\\electron.js",
                  "start:dev": ".\\node_modules\\.bin\\electron js\\electron.js dev",
                  but it still goes back to
                  C:\magicmirror>
                  and does nothing.
                    PC@WST MINGW32 /c/magicmirror
                    $ npm start
                    > magicmirror@2.26.0 start
                    > .\node_modules\.bin\electron js\electron.js
                      @JackHammer325 dont use min
                      just install under cmd.exe , do the extra steps, then npm start
                      J 3 Replies Last reply Reply Quote 0
                        alright I will try that and let you know of the outcome!
