    MMM-CalendarExt3 issue Loading / Showing the calendar on Windows
    22 Posts 3 Posters 7.8k Views 3 Watching
      JackHammer325 @sdetweil
      PC@WST MINGW32 /c/magicmirror
      $ npm start
      > magicmirror@2.26.0 start
      > .\node_modules\.bin\electron js\electron.js
        sdetweil @JackHammer325
        @JackHammer325 dont use min
        just install under cmd.exe , do the extra steps, then npm start
        J 3 Replies Last reply Reply Quote 0
          alright I will try that and let you know of the outcome!
            just finished the install using cmd
            • made sure to install the fonts and vendor parts
            • as well as change the package.json file and then did run start.
            but it still did the same thing as before.
              C:\MagicMirror>npm start
              C:\MagicMirror>
                @JackHammer325 no .\ in front
                the doc is wrong. windows doesn’t like . for current directory
                  this is what i have in my package.json file. I removed the “.” like you recommended.
                  now i get “the system cannot find the path specified”
                  The system cannot find the path specified.
                  C:\MagicMirror>
                    @JackHammer325 you only removed the dot I said no .\
                    so remove the slashes too
                    "node_modules\\.bin\\....",
                      sorry guess i didn’t realize.
                      I’ve done that and it looks like it’s trying to start but then just goes back to this.
                      > node_modules\.bin\electron js\electron.js                 → sits here for about 8-10 seconds
        then does that
                      C:\MagicMirror>
                        MMRIZE @JackHammer325
                        @JackHammer325 said in MMM-CalendarExt3 issue Loading / Showing the calendar on Windows:
                        TypeError: original.map(…).toSorted is not a function
                        Sorry for the late reply.
                        This error message is caused by using an old browser or not supported.
                        If you are using Chrome or Chromium, it’s version should be newer than v110( - released, 2023-02-07, Current version is v120). Or for other browser, See above picture.
                          windows 8.1
                          yeh, missed that… That’s why the old browset
                            MMRIZE @sdetweil
                            I was happy to use a new feature toSorted but ppl may have trouble with compatibility issue. I’ll provide fallback codes in the next update.
                              sdetweil @MMRIZE
                              @MMRIZE we have this problem in general… mm used to display on TV’s and ipads/ android tablets… but as we’ve moved to ES6 level js, they no longer work… I find this a sad state for MM… (but I like the new ES6 support)
