    MMM-CalendarExt3 issue Loading / Showing the calendar on Windows
    22 Posts 3 Posters 8.2k Views 3 Watching
      JackHammer325
      yes, I did.
      i even double checked .
      cd ~/MagicMirror/modules
      git clone https://github.com/MMRIZE/MMM-CalendarExt3
      cd MMM-CalendarExt3
      npm install
      git submodule update --init --recursive
      i even ran the update just to be sure
      cd ~/MagicMirror/modules/MMM-CalendarExt3
      git pull
      npm update
      im currently on Node.js ver 18.16.0
      running on windows 8.1
      not entirely sure how to “show output of” that you are asking
        @JackHammer325 ok, windows
        node -v and npm -v
        from a command prompt (cmd.exe) window
        the others are linux only
          JackHammer325 @sdetweil
          node -v = v18.16.0
          npm -v = 9.5.1
            sdetweil @JackHammer325
            @JackHammer325 are you using the native windows or running in the linux subsystem for windows?
              native windows with program Git Bash
                @JackHammer325 do not need git bash
                just cmd.exe
                npm start
                or npm run server
                of course u have to change package.json per the instructions due to the windows backslash for path
                  so i followed these instructions
                  "start:dev": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js dev",
                  and replace it with
                  "start": ".\\node_modules\\.bin\\electron js\\electron.js",
                  "start:dev": ".\\node_modules\\.bin\\electron js\\electron.js dev",
                  but it still goes back to
                  C:\magicmirror>
                  and does nothing.
                    PC@WST MINGW32 /c/magicmirror
                    $ npm start
                    > magicmirror@2.26.0 start
                    > .\node_modules\.bin\electron js\electron.js
                      @JackHammer325 dont use min
                      just install under cmd.exe , do the extra steps, then npm start
                      J 3 Replies Last reply Reply Quote 0
                        alright I will try that and let you know of the outcome!
                          just finished the install using cmd
                          • made sure to install the fonts and vendor parts
                          • as well as change the package.json file and then did run start.
                          but it still did the same thing as before.
                            C:\MagicMirror>npm start
                            C:\MagicMirror>
                              @JackHammer325 no .\ in front
                              the doc is wrong. windows doesn’t like . for current directory
                                this is what i have in my package.json file. I removed the “.” like you recommended.
                                now i get “the system cannot find the path specified”
                                The system cannot find the path specified.
                                C:\MagicMirror>
                                  @JackHammer325 you only removed the dot I said no .\
                                  so remove the slashes too
                                  "node_modules\\.bin\\....",
                                    sorry guess i didn’t realize.
                                    I’ve done that and it looks like it’s trying to start but then just goes back to this.
                                    > node_modules\.bin\electron js\electron.js                 → sits here for about 8-10 seconds
        then does that
                                    C:\MagicMirror>
                                      MMRIZE @JackHammer325
                                      @JackHammer325 said in MMM-CalendarExt3 issue Loading / Showing the calendar on Windows:
                                      TypeError: original.map(…).toSorted is not a function
                                      Sorry for the late reply.
                                      This error message is caused by using an old browser or not supported.
                                      If you are using Chrome or Chromium, it’s version should be newer than v110( - released, 2023-02-07, Current version is v120). Or for other browser, See above picture.
                                        windows 8.1
                                        yeh, missed that… That’s why the old browset
                                          MMRIZE @sdetweil
                                          I was happy to use a new feature toSorted but ppl may have trouble with compatibility issue. I’ll provide fallback codes in the next update.
                                            sdetweil @MMRIZE
                                            @MMRIZE we have this problem in general… mm used to display on TV’s and ipads/ android tablets… but as we’ve moved to ES6 level js, they no longer work… I find this a sad state for MM… (but I like the new ES6 support)
