    MMM-OpenWeatherMapForecast Doesn't display imperial units
    21 Posts 6 Posters 8.9k Views 6 Watching
      sdetweil @rslohs
      @rslohs its not “Units”, its “units”
      this system is case sensitive, every letter matters
        rslohs @sdetweil
        @sdetweil that’s what I’m using in the config file.
        module: "MMM-OpenWeatherMapForecast",
        header: "Schoolcraft, MI Weather",
        classes: "default everyone",
        disabled: false,
        apikey: "aaaaaaaa",
        latitude: "aaaaaaa",
        longitude: "aaaaaa",
        iconset: "4c",
        concise: false,
        forecastLayout: "table",
        units: "imperial",
          scumbelly @rslohs
          @rslohs
          A little late to weigh in but I can verify that imperial setting does not affect the Pop amount. It remains metric. Everything else is imperial.
          Sorry.
            scumbelly @rslohs
            @rslohs
            Guess what? I was trying to troubleshoot an issue in this module re: scale and noticed the .js file has changed wind calculations and the following…
            units: {
            accumulationRain: {
            imperial: “mm”,
            metric: “mm”,
            “”: “mm”
            accumulationSnow: {
            imperial: “mm”,
            metric: “mm”,
            “”: “mm”
            windSpeed: {
            imperial: “mph”,
            metric: “m/s”,
            “”: “m/s”
            So it looks like imperial might work for you now. I’m not going to test because I need the older .js which I had to modify to get some calculations in kph to work .
            Cheers
              JohnGalt
              My instance of this module also displays rainfall in “mm”, even though I have set units = “imperial” for the MagicMirror system as a whole and also in the module configuration.
              I see that the Open Weather site has a page specifying “API response parameters with available units of measurement” (https://openweathermap.org/weather-data). There one finds a parameter table specifying Parameter and Description - as well as columns for “Standard”, “Metric” and “Imperial”.
              The interesting thing is this: the table specifies temperatures correctly (“Kelvin”, “Celsius”, “Fahrenheit”) but for rain it calls out “mm”, “mm”, “mm” - or other variants for different fields, e.g.: “mm/hr” and “mm/hour”.
              As such, I am inclined to just give up and accept the module’s behavior as a quirk of how Open Weather parses what it is getting from the NWS - but I thought i would see if anyone has a better idea.
              kayakbabeK 1 Reply Last reply Reply Quote 0
              • kayakbabeK Offline
                kayakbabe @JohnGalt
                @JohnGalt have you tried MMM-OpenWeatherForecast instead? It seems to work better for me adn it uses the OpenWeather Map api too.
                J 3 Replies Last reply Reply Quote 0
                  JohnGalt @kayakbabe
                  @kayakbabe - Thanks for the tip. Can you tell me which one you use? A quick web search shows several modules with the same name. These two look like top contenders:
                  https://github.com/jclarke0000/MMM-OpenWeatherForecast
                  https://github.com/themaxgoldman/MMM-OpenWeatherForecast
                    JohnGalt @kayakbabe
                    @kayakbabe PS: another issue with MMM-OpenWeatherMapForecast is that it doesn’t respect the “disabled: true” configuration. I had seen this before and ignored it since the module is active, but when I went in to disable it in preparation for trying one of the others, I am reminded that I cannot just disable it. I CAN put " /* and */ " around the whole thing of course, but that is just clunky, and more importantly may signal more serious coding issues.
                      JohnGalt @kayakbabe
                      @kayakbabe FWIW, i installed the jclarke0000 module, and so far it looks pretty good - thanks again!
                        sdetweil @JohnGalt
                        @JohnGalt disabled is an mm config option, not a module option. it goes not to the module line, outside the module config:{} section
                        here is the doc on all the mm config options for a module.
                        these are separate from the module config options inside the config:{} section
                        https://docs.magicmirror.builders/modules/configuration.html#example
