    MMM-OpenWeatherMapForecast Doesn't display imperial units
    21 Posts 6 Posters 9.0k Views 6 Watching
      Mykle1 Project Sponsor Module Developer @rslohs
      @rslohs
      Just a thought: At the top of your config.js file, what are your config units set to?
      Example:
      var config = {
          address: "0.0.0.0",
          port: 8080,
          ipWhitelist: [], // Set [] to allow all IP addresses
          language: "en",
          timeFormat: 12,
          units: "imperial",
        rslohs @Mykle1
        @mykle1 thanks for the suggestion, but that is set to imperial as well.
          sdetweil @rslohs
          @rslohs its not “Units”, its “units”
          this system is case sensitive, every letter matters
            rslohs @sdetweil
            @sdetweil that’s what I’m using in the config file.
            module: "MMM-OpenWeatherMapForecast",
            header: "Schoolcraft, MI Weather",
            classes: "default everyone",
            disabled: false,
            apikey: "aaaaaaaa",
            latitude: "aaaaaaa",
            longitude: "aaaaaa",
            iconset: "4c",
            concise: false,
            forecastLayout: "table",
            units: "imperial",
              scumbelly @rslohs
              @rslohs
              A little late to weigh in but I can verify that imperial setting does not affect the Pop amount. It remains metric. Everything else is imperial.
              Sorry.
                scumbelly @rslohs
                @rslohs
                Guess what? I was trying to troubleshoot an issue in this module re: scale and noticed the .js file has changed wind calculations and the following…
                units: {
                accumulationRain: {
                imperial: “mm”,
                metric: “mm”,
                “”: “mm”
                accumulationSnow: {
                imperial: “mm”,
                metric: “mm”,
                “”: “mm”
                windSpeed: {
                imperial: “mph”,
                metric: “m/s”,
                “”: “m/s”
                So it looks like imperial might work for you now. I’m not going to test because I need the older .js which I had to modify to get some calculations in kph to work .
                Cheers
                  JohnGalt
                  My instance of this module also displays rainfall in “mm”, even though I have set units = “imperial” for the MagicMirror system as a whole and also in the module configuration.
                  I see that the Open Weather site has a page specifying “API response parameters with available units of measurement” (https://openweathermap.org/weather-data). There one finds a parameter table specifying Parameter and Description - as well as columns for “Standard”, “Metric” and “Imperial”.
                  The interesting thing is this: the table specifies temperatures correctly (“Kelvin”, “Celsius”, “Fahrenheit”) but for rain it calls out “mm”, “mm”, “mm” - or other variants for different fields, e.g.: “mm/hr” and “mm/hour”.
                  As such, I am inclined to just give up and accept the module’s behavior as a quirk of how Open Weather parses what it is getting from the NWS - but I thought i would see if anyone has a better idea.
                  kayakbabeK 1 Reply Last reply Reply Quote 0
                  • kayakbabeK Offline
                    kayakbabe @JohnGalt
                    @JohnGalt have you tried MMM-OpenWeatherForecast instead? It seems to work better for me adn it uses the OpenWeather Map api too.
                    J 3 Replies Last reply Reply Quote 0
                      JohnGalt @kayakbabe
                      @kayakbabe - Thanks for the tip. Can you tell me which one you use? A quick web search shows several modules with the same name. These two look like top contenders:
                      https://github.com/jclarke0000/MMM-OpenWeatherForecast
                      https://github.com/themaxgoldman/MMM-OpenWeatherForecast
                        JohnGalt @kayakbabe
                        @kayakbabe PS: another issue with MMM-OpenWeatherMapForecast is that it doesn’t respect the “disabled: true” configuration. I had seen this before and ignored it since the module is active, but when I went in to disable it in preparation for trying one of the others, I am reminded that I cannot just disable it. I CAN put " /* and */ " around the whole thing of course, but that is just clunky, and more importantly may signal more serious coding issues.
