MMM-OpenWeatherMapForecast Doesn't display imperial units
21 Posts 6 Posters 5.3k Views 6 Watching
    rslohs
    Working on OpenWeatherMapForecast and so far have really liked it. One issue, for predicted precipitation I cannot get imperial units to show. I’ve tried changing it within config.js as well as the config file in the module as well. Any suggestions?
    module: “MMM-OpenWeatherMapForecast”,
    header: “Weather”,
    position: “bottom_right”,
    classes: “default everyone”,
    disabled: false,
    apikey: “KEY”,
    latitude: “444444”,
    longitude: “-4444444”,
    iconset: “4c”,
    concise: false,
    forecastLayout: “table”,
    units: “imperial”,
    S M 2 Replies Last reply Feb 19, 2021, 1:16 AM Reply Quote 0
      sdetweil @rslohs
      @rslohs the doc says the module config options is units
      from
      https://github.com/jharttech/MMM-weatherforecast
      R 1 Reply Last reply Feb 19, 2021, 1:48 AM Reply Quote 0
        rslohs @sdetweil
        @sdetweil I’m not quite sure what you’re saying. The ‘Units:“imperial”,’ is incorrect in the code I shared? What should I try differently?
        S 1 Reply Last reply Feb 19, 2021, 2:18 AM Reply Quote 0
          Mykle1 Project Sponsor Module Developer @rslohs
          @rslohs
          Just a thought: At the top of your config.js file, what are your config units set to?
          Example:
          var config = {
              address: "0.0.0.0",
              port: 8080,
              ipWhitelist: [], // Set [] to allow all IP addresses
              language: "en",
              timeFormat: 12,
              units: "imperial",
          R 1 Reply Last reply Feb 19, 2021, 2:02 AM Reply Quote 0
            rslohs @Mykle1
            @mykle1 thanks for the suggestion, but that is set to imperial as well.
            S 1 Reply Last reply May 28, 2021, 2:09 PM Reply Quote 0
              sdetweil @rslohs
              @rslohs its not “Units”, its “units”
              this system is case sensitive, every letter matters
              R 1 Reply Last reply Feb 19, 2021, 3:53 AM Reply Quote 0
                rslohs @sdetweil
                @sdetweil that’s what I’m using in the config file.
                module: "MMM-OpenWeatherMapForecast",
                header: "Schoolcraft, MI Weather",
                classes: "default everyone",
                disabled: false,
                apikey: "aaaaaaaa",
                latitude: "aaaaaaa",
                longitude: "aaaaaa",
                iconset: "4c",
                concise: false,
                forecastLayout: "table",
                units: "imperial",
                S 1 Reply Last reply May 28, 2021, 3:40 PM Reply Quote 0
                  scumbelly @rslohs
                  @rslohs
                  A little late to weigh in but I can verify that imperial setting does not affect the Pop amount. It remains metric. Everything else is imperial.
                  Sorry.
                    scumbelly @rslohs
                    @rslohs
                    Guess what? I was trying to troubleshoot an issue in this module re: scale and noticed the .js file has changed wind calculations and the following…
                    units: {
                    accumulationRain: {
                    imperial: “mm”,
                    metric: “mm”,
                    “”: “mm”
                    accumulationSnow: {
                    imperial: “mm”,
                    metric: “mm”,
                    “”: “mm”
                    windSpeed: {
                    imperial: “mph”,
                    metric: “m/s”,
                    “”: “m/s”
                    So it looks like imperial might work for you now. I’m not going to test because I need the older .js which I had to modify to get some calculations in kph to work .
                    Cheers
                      JohnGalt
                      My instance of this module also displays rainfall in “mm”, even though I have set units = “imperial” for the MagicMirror system as a whole and also in the module configuration.
                      I see that the Open Weather site has a page specifying “API response parameters with available units of measurement” (https://openweathermap.org/weather-data). There one finds a parameter table specifying Parameter and Description - as well as columns for “Standard”, “Metric” and “Imperial”.
                      The interesting thing is this: the table specifies temperatures correctly (“Kelvin”, “Celsius”, “Fahrenheit”) but for rain it calls out “mm”, “mm”, “mm” - or other variants for different fields, e.g.: “mm/hr” and “mm/hour”.
                      As such, I am inclined to just give up and accept the module’s behavior as a quirk of how Open Weather parses what it is getting from the NWS - but I thought i would see if anyone has a better idea.
                      kayakbabeK 1 Reply Last reply Feb 6, 2024, 4:49 AM Reply Quote 0
