    MMM-OpenWeatherMapForecast Doesn't display imperial units
    21 Posts 6 Posters 11.2k Views 6 Watching
      scumbelly @rslohs
      @rslohs
      A little late to weigh in but I can verify that imperial setting does not affect the Pop amount. It remains metric. Everything else is imperial.
      Sorry.
        scumbelly @rslohs
        @rslohs
        Guess what? I was trying to troubleshoot an issue in this module re: scale and noticed the .js file has changed wind calculations and the following…
        units: {
        accumulationRain: {
        imperial: “mm”,
        metric: “mm”,
        “”: “mm”
        accumulationSnow: {
        imperial: “mm”,
        metric: “mm”,
        “”: “mm”
        windSpeed: {
        imperial: “mph”,
        metric: “m/s”,
        “”: “m/s”
        So it looks like imperial might work for you now. I’m not going to test because I need the older .js which I had to modify to get some calculations in kph to work .
        Cheers
          JohnGalt
          My instance of this module also displays rainfall in “mm”, even though I have set units = “imperial” for the MagicMirror system as a whole and also in the module configuration.
          I see that the Open Weather site has a page specifying “API response parameters with available units of measurement” (https://openweathermap.org/weather-data). There one finds a parameter table specifying Parameter and Description - as well as columns for “Standard”, “Metric” and “Imperial”.
          The interesting thing is this: the table specifies temperatures correctly (“Kelvin”, “Celsius”, “Fahrenheit”) but for rain it calls out “mm”, “mm”, “mm” - or other variants for different fields, e.g.: “mm/hr” and “mm/hour”.
          As such, I am inclined to just give up and accept the module’s behavior as a quirk of how Open Weather parses what it is getting from the NWS - but I thought i would see if anyone has a better idea.
          kayakbabeK 1 Reply Last reply
          • kayakbabeK
            kayakbabe @JohnGalt
            @JohnGalt have you tried MMM-OpenWeatherForecast instead? It seems to work better for me adn it uses the OpenWeather Map api too.
            J 3 Replies Last reply
              JohnGalt @kayakbabe
              @kayakbabe - Thanks for the tip. Can you tell me which one you use? A quick web search shows several modules with the same name. These two look like top contenders:
              https://github.com/jclarke0000/MMM-OpenWeatherForecast
              https://github.com/themaxgoldman/MMM-OpenWeatherForecast
                JohnGalt @kayakbabe
                @kayakbabe PS: another issue with MMM-OpenWeatherMapForecast is that it doesn’t respect the “disabled: true” configuration. I had seen this before and ignored it since the module is active, but when I went in to disable it in preparation for trying one of the others, I am reminded that I cannot just disable it. I CAN put " /* and */ " around the whole thing of course, but that is just clunky, and more importantly may signal more serious coding issues.
                  JohnGalt @kayakbabe
                  @kayakbabe FWIW, i installed the jclarke0000 module, and so far it looks pretty good - thanks again!
                    sdetweil @JohnGalt
                    @JohnGalt disabled is an mm config option, not a module option. it goes not to the module line, outside the module config:{} section
                    here is the doc on all the mm config options for a module.
                    these are separate from the module config options inside the config:{} section
                    https://docs.magicmirror.builders/modules/configuration.html#example
                    J 1 Reply Last reply
                      JohnGalt @sdetweil
                      @sdetweil - Thanks Sam - I guess I was and am confused.
                      Below are two code snips showing the subject module and one other. Both are designated to be disabled with the “disabled: true” instruction outside the config section. The top one still operates, while the bottom one [and every other module I have edited this way] is disabled. So, it’s not a big deal and I will keep an eye out for how I do things. Thanks again.
                      {module: "MMM-OpenWeatherMapForecast", // https://github.com/MarcLandis/MMM-OpenWeatherMapForecast NOTE: See also https://github.com/sdetweil/MMM-OpenWeatherMapForecast
                        disabled: true,
                        header: "", // "Weather"
                        classes: "default everyone",
                        disabled: false,
                          apikey: "xxxxxxxxxxxxx",
                      {module: "MMM-Temperature", // https://github.com/Tom-Hirschberger/MMM-Temperature
                        disabled: true,
                        header: "Office Temp + Humidity",
                        position: "top_right", // bottom_right
                         sensors: [
                        sdetweil @JohnGalt
                        @JohnGalt I need to see the rest in between
                        top one has disabled twice, true and false
                          JohnGalt @sdetweil
                          @sdetweil - Ah crap, having both disabled: true AND disabled: false would do it!! :) I’m sure the system would execute the last command. Thanks for putting a second set of eyes on it.
                            sdetweil @JohnGalt
                            @JohnGalt yes, last occurrence wins
                            • kayakbabeK
                              kayakbabe @JohnGalt
                              @JohnGalt
                              I see you got your module choice working.
                              jclarke0000 is the one I’m using.
                                JohnGalt @kayakbabe
                                @kayakbabe - thanks for letting me know. I will keep an eye on the one I am using and if I see issues, will try the other one.
