    MMM-OpenWeatherMapForecast Doesn't display imperial units
    21 Posts 6 Posters 9.7k Views 6 Watching
      rslohs @Mykle1
      @mykle1 thanks for the suggestion, but that is set to imperial as well.
        sdetweil @rslohs
        @rslohs its not “Units”, its “units”
        this system is case sensitive, every letter matters
          rslohs @sdetweil
          @sdetweil that’s what I’m using in the config file.
          module: "MMM-OpenWeatherMapForecast",
          header: "Schoolcraft, MI Weather",
          classes: "default everyone",
          disabled: false,
          apikey: "aaaaaaaa",
          latitude: "aaaaaaa",
          longitude: "aaaaaa",
          iconset: "4c",
          concise: false,
          forecastLayout: "table",
          units: "imperial",
            scumbelly @rslohs
            @rslohs
            A little late to weigh in but I can verify that imperial setting does not affect the Pop amount. It remains metric. Everything else is imperial.
            Sorry.
              scumbelly @rslohs
              @rslohs
              Guess what? I was trying to troubleshoot an issue in this module re: scale and noticed the .js file has changed wind calculations and the following…
              units: {
              accumulationRain: {
              imperial: “mm”,
              metric: “mm”,
              “”: “mm”
              accumulationSnow: {
              imperial: “mm”,
              metric: “mm”,
              “”: “mm”
              windSpeed: {
              imperial: “mph”,
              metric: “m/s”,
              “”: “m/s”
              So it looks like imperial might work for you now. I’m not going to test because I need the older .js which I had to modify to get some calculations in kph to work .
              Cheers
                JohnGalt
                My instance of this module also displays rainfall in “mm”, even though I have set units = “imperial” for the MagicMirror system as a whole and also in the module configuration.
                I see that the Open Weather site has a page specifying “API response parameters with available units of measurement” (https://openweathermap.org/weather-data). There one finds a parameter table specifying Parameter and Description - as well as columns for “Standard”, “Metric” and “Imperial”.
                The interesting thing is this: the table specifies temperatures correctly (“Kelvin”, “Celsius”, “Fahrenheit”) but for rain it calls out “mm”, “mm”, “mm” - or other variants for different fields, e.g.: “mm/hr” and “mm/hour”.
                As such, I am inclined to just give up and accept the module’s behavior as a quirk of how Open Weather parses what it is getting from the NWS - but I thought i would see if anyone has a better idea.
                kayakbabeK 1 Reply Last reply Reply Quote 0
                • kayakbabeK Offline
                  kayakbabe @JohnGalt
                  @JohnGalt have you tried MMM-OpenWeatherForecast instead? It seems to work better for me adn it uses the OpenWeather Map api too.
                  J 3 Replies Last reply Reply Quote 0
                    JohnGalt @kayakbabe
                    @kayakbabe - Thanks for the tip. Can you tell me which one you use? A quick web search shows several modules with the same name. These two look like top contenders:
                    https://github.com/jclarke0000/MMM-OpenWeatherForecast
                    https://github.com/themaxgoldman/MMM-OpenWeatherForecast
                      JohnGalt @kayakbabe
                      @kayakbabe PS: another issue with MMM-OpenWeatherMapForecast is that it doesn’t respect the “disabled: true” configuration. I had seen this before and ignored it since the module is active, but when I went in to disable it in preparation for trying one of the others, I am reminded that I cannot just disable it. I CAN put " /* and */ " around the whole thing of course, but that is just clunky, and more importantly may signal more serious coding issues.
                        JohnGalt @kayakbabe
                        @kayakbabe FWIW, i installed the jclarke0000 module, and so far it looks pretty good - thanks again!
                          sdetweil @JohnGalt
                          @JohnGalt disabled is an mm config option, not a module option. it goes not to the module line, outside the module config:{} section
                          here is the doc on all the mm config options for a module.
                          these are separate from the module config options inside the config:{} section
                          https://docs.magicmirror.builders/modules/configuration.html#example
                            JohnGalt @sdetweil
                            @sdetweil - Thanks Sam - I guess I was and am confused.
                            Below are two code snips showing the subject module and one other. Both are designated to be disabled with the “disabled: true” instruction outside the config section. The top one still operates, while the bottom one [and every other module I have edited this way] is disabled. So, it’s not a big deal and I will keep an eye out for how I do things. Thanks again.
                            {module: "MMM-OpenWeatherMapForecast", // https://github.com/MarcLandis/MMM-OpenWeatherMapForecast NOTE: See also https://github.com/sdetweil/MMM-OpenWeatherMapForecast
                              disabled: true,
                              header: "", // "Weather"
                              disabled: false,
                                apikey: "xxxxxxxxxxxxx",
                            {module: "MMM-Temperature", // https://github.com/Tom-Hirschberger/MMM-Temperature
                              disabled: true,
                              header: "Office Temp + Humidity",
                              position: "top_right", // bottom_right
                               sensors: [
                              sdetweil @JohnGalt
                              @JohnGalt I need to see the rest in between
                              top one has disabled twice, true and false
                                JohnGalt @sdetweil
                                @sdetweil - Ah crap, having both disabled: true AND disabled: false would do it!! :) I’m sure the system would execute the last command. Thanks for putting a second set of eyes on it.
                                  sdetweil @JohnGalt
                                  @JohnGalt yes, last occurrence wins
                                    kayakbabe @JohnGalt
                                    @JohnGalt
                                    I see you got your module choice working.
                                    jclarke0000 is the one I’m using.
                                      JohnGalt @kayakbabe
                                      @kayakbabe - thanks for letting me know. I will keep an eye on the one I am using and if I see issues, will try the other one.
