    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
      MMRIZE @Lilleberg
      @Lilleberg Show us your config.
      • L
        Lilleberg @MMRIZE
        Here is my config- I have replaced the calendar urls under as I dont want to show them to the world.
        			module: 'MMM-Remote-Control',
        			// position: 'bottom_left',
                    apiKey: 'c92e9765778gh56h83f66fffd333c6a5'
        			module: "alert",
        			module: 'MMM-YrThen',
        			position: 'top_left',
        				showAll: "false",
        				details: "false",
        				title: "Været på Frekhaug neste uke",
        				header: "true",
        				windGust: "true",
        				windUnit: "m/s",
        			module: "clock",
        			dateFormat: "dddd, D. MMMM YYYY",
        			showSunTimes: "true",
        			lat: "60.520806",
        			lon: "5.237736",
        			module: 'MMM-YrNow',
        			position: 'top_right',
        				locationId: '1-107159',
        				showWeatherForecast: true
        			hiddenOnStartup: "true",
        				broadcastPastEvents: true, // <= IMPORTANT to see past events
        						symbol: "none",
        						url: "Google Calendar url",
        						color: "#8BD3E6", //Blå
        						symbol: "none",
        						color: "#800080", //Lilla
        						symbol: "none",
        						color: "#FF6D6A", //Rød
        						symbol: "none",
        						url: "hGoogle Calendar url",
        						color: "#E9EC6B", //Gul
        						symbol: "none",
        						color: "#77DD77", //Grønn
        						symbol: "none",
        						color: "#fffff", //Hvit
        			module: 'MMM-GoogleCalendar',
        					symbol: "none",
        					calendarID: "Google Calendar id"
        					color: "#000000", //Svart
        			module: "MMM-CalendarExt3",
        			position: "bottom_bar",
        			title: "",
        				mode: "week",
        				weekIndex: "0",
        				weeksInView: "4",
        				instanceId: "basicCalendar",
        				locale: 'nb',
        				maxEventLines: 10,
        				firstDayOfWeek: 1,
        				calendarSet: [],
        				eventHeight: "22px",
        				displayLegend: "true",
        				eventTransformer: (e) => {
        					e.startDate = new Date(e.start?.date || e.start?.dateTime).valueOf()
        					e.endDate = new Date(e.end?.date || e.end?.dateTime).valueOf()
        					e.title = e.summary
        					e.fulldayEvent = (e.start?.date) ? true : false
        					return e
          MMRIZE @Lilleberg
          @Lilleberg
          Check broadcastEvents:true in your MMM-GoogleCalendar’s config. Unlike the original calendar module, MMM-GoogleCalendar has this value as false by default.
          • L
            Lilleberg @MMRIZE
            @MMRIZE Tried adding this to the config, but still no result. The module broadcasts the events, but they wont show in the Ext3 module. Se attached image. I have removed the other calendars from the config, and only show the events from the Google Calendar module.20240312_183109.jpg
              MMRIZE @Lilleberg
              @Lilleberg If possible, can you share the copy of your calendar? (And the final config file also) (eouia0819@gmail.com)
              Without the real data I couldn’t catch what really happened in yours.
              L N 2 Replies Last reply Reply Quote 0
              • L
                Lilleberg @MMRIZE
                @MMRIZE I’m sending you an e-mail
                • N
                  nicmoly @MMRIZE
                  @MMRIZE Hi Im also having the exact same issue as @Lilleberg , I have however seen glimpses of this working as intended but it seems to be on a whim, either it restarts and works and then not again untill a further reboot or it just wont. I find it weird that using MMM-CalendarExt3Journal works perfect every time with similar settings. Any ideas on what may be going on? Weird thing is leaving the MMM running all the sudden it works like 20-30min later, so im wondering if theres some weirdness with how the data comes in from the GoogleCalendar module
                  Heres my config for refrence:
                     			header: "My Google Private Cal",
                    			position: "upper_third",
                  			hiddenOnStartup: true,
                  				broadcastEvents: true,
                  							symbol: "calendar-week",
                  							calendarID: "***",
                  							name: "1_cal", // <= RECOMMENDED to assign name
                  							color: "yellow" // <= RECOMMENDED to assign color
                  							calendarID: "***",
                  							name: "2_cal", // <= RECOMMENDED to assign name
                  							color: "red" // <= RECOMMENDED to assign color
                  							calendarID: "en.canadian#holiday@group.v.calendar.google.com",
                  							name: "holiday_cal", // <= RECOMMENDED to assign name
                  							color: "green" // <= RECOMMENDED to assign color
                    			position: "lower_third",
                  			title: "Family Calendar",
                  				mode: "month",
                  				instanceID: "I-calendar-month",
                  				maxEventLines: 5,
                  				firstDayOfWeek: 1,
                  				preProcessor: (e) => {
                  					if (e.start?.dateTime) {
                  				  		e.startDate = new Date(e.start.dateTime).valueOf()
                  					} else if (e.start?.date) {
                  				  		e.startDate = new Date(`${e.start.date}T00:00:00`).valueOf()
                  					if (e.end?.dateTime) {
                  				  		e.endDate = new Date(e.end.dateTime).valueOf()
                  					} else if (e.end?.date) {
                  				  		e.endDate = new Date(`${e.end.date}T00:00:00`).valueOf()
                  					e.title = e.summary
                  					e.fullDayEvent = (e.start?.date) ? true : false
                  					return e
                  //  			module: "MMM-CalendarExt3Journal",
                  //  			position: "bottom_bar",
                  //  			config: {
                  //				height: '50vh',
                  //   			 	width: '100%',
                  //				//locale: 'en-GB',
                  //				staticWeek: true,
                  //				staticTime: true,
                  //				hourLength: 14,
                  //				beginHour:  8,
                  //				preProcessor: (e) => {
                  //					if (e.start?.dateTime) {
                  //				  		e.startDate = new Date(e.start.dateTime).valueOf()
                  //					} else if (e.start?.date) {
                  //				  		e.startDate = new Date(`${e.start.date}T00:00:00`).valueOf()
                  //					if (e.end?.dateTime) {
                  //				  		e.endDate = new Date(e.end.dateTime).valueOf()
                  //					} else if (e.end?.date) {
                  //				  		e.endDate = new Date(`${e.end.date}T00:00:00`).valueOf()
                  //					e.title = e.summary
                  //					e.fullDayEvent = (e.start?.date) ? true : false
                  //					return e
                    MMRIZE @nicmoly
                    @nicmoly
                    Usually, your symptom happens by insufficient waitFetch. Give it more. (By default it would be 5_000 ms. Give it more like 10_000)
                      bobbylx
                      Had an issue with my monitor so I took that opportunity to reload Pi OS and MM. Unfortunately, I goofed and flashed over my config and css backups. So I’m starting fresh.
                      That went fine but I cannot figure out why my calendar is not loading. My MM loads in Midori, I get my date/time in the upper left but the rest of the page is blank, no config warnings or empty boxes, just a completely black page. Config check shows no issues. Can someone look at my config.js real quick and see if I’m missing something? I have not touched any other files at this point, I was just trying to get the calendar to load before I start really customizing.
                      let config = {
                              address: "localhost",   // Address to listen on, can be:
                              port: 8080,
                              basePath: "/",  // The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                              ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],  // Set [] to allow all IP addresses
                              useHttps: false,                        // Support HTTPS or not, default "false" will use HTTP
                              httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
                              httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
                              language: "en",
                              locale: "en-US",
                              timeFormat: 24,
                              units: "metric",
                                              module: "alert",
                                              module: "updatenotification",
                                              position: "top_bar"
                                              module: "clock",
                                              position: "top_left"
                                              header: "US Holidays",
                                              position: "",
        symbol: "calendar-check",
        url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
                                              module: "compliments",
                                              position: ""
                                              module: "weather",
                                                      type: "current",
                                                      locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                                      apiKey: "YOUR_OPENWEATHER_API_KEY"
                                              module: "weather",
                                              header: "Weather Forecast",
                                                      type: "forecast",
                                                position: "",
                                                      url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
                                                      name: "us_holiday", // <= RECOMMENDED to assign name
                                                 title: "",
                                                  mode: "month",
                                                  locale: 'en-EN',
                                                  maxEventLines: 5,
                                                  firstDayOfWeek: 1,
                                                  calendarSet: ['us_holiday'],
                        sdetweil @bobbylx
                        @bobbylx said in MMM-CalendarExt3:
                                            position: ""
                        must be a valid position if specified…
                        you can disable a module by adding
                        disabled: true,
                        after the module: line
                        you can also comment out the position
                        // position:“…”
                        this would be how you use the default calendar with Ext3…
                        it would work, but not be shown
                        backup, backup, backup…
                        see my scripts, backup to private repo on github… restore from there
                        versionable…
                        3 tiny files… and any keyfiles/token files…
                        https://github.com/sdetweil/MagicMirror-backup-restore
                          MMRIZE @bobbylx
                          @bobbylx
                          CX3* series may not work on MIDORI, sorry. It’s too old browser, doesn’t support advanced modern JavaScript technologies.
                            bobbylx @sdetweil
                            @sdetweil said in MMM-CalendarExt3:
                                                position: ""
                            disabled: true,
                            // position:“…”
                            versionable…
                            Thanks, just made that change, found a couple more that needed attention. I also checked my history in this thread, I’ve posted my config before asking other questions so I was able to borrow some lines. Getting close now.
                            @MMRIZE said in MMM-CalendarExt3:
                            @bobbylx
                            I had been using it with Midori until just a few days ago when I decided to reload. It wasn’t fast or always the best, but I’m using a Pi zero W so limited on browsers right now. I’ll be picking up a Pi 3 or 4 soon then I’ll do this all over again.
                            • A
                              aymen_a22
                              Unsure why, but I keep getting this error message.
                              Is anyone able to assist if possible please?
                              Warning: vkCreateInstance: Found no drivers!
                              Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
                              at CheckVkSuccessImpl (…/…/third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                              at CreateVkInstance (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                              at Initialize (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                              at Create (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                              at operator() (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                                sdetweil @aymen_a22
                                @aymen_a22 bug in electron , nothing we can do… ignore it
                                  princemaxwell
                                  Hello together,
                                  i have configured 8 calendars in the default calendar module. Three of them are from “i.cal.to” and five are my public iCloudcalendars.
                                  The default calendar app is loading them without errors, but MMM-CalendarExt3 has problems to view the iCloud entries.
                                  The mm-error.log shows:
                                  [19.03.2024 21:24.43.184] [ERROR] Calendar Error. Could not fetch calendar:  https://p63-caldav.icloud.com/published/2/MTA... TypeError: fetch failed
                                      at Object.fetch (node:internal/deps/undici/undici:11576:11) {
                                    cause: SocketError: other side closed
                                        at TLSSocket.onSocketEnd (node:internal/deps/undici/undici:9790:26)
                                        at TLSSocket.emit (node:events:526:35)
                                        at endReadableNT (node:internal/streams/readable:1359:12)
                                        at process.processTicksAndRejections (node:internal/process/task_queues:82:21) {
                                      code: 'UND_ERR_SOCKET',
                                      socket: {
                                        localAddress: '10.0.0.20',
                                        localPort: 37214,
                                        remoteAddress: undefined,
                                        remotePort: undefined,
                                        remoteFamily: undefined,
                                        timeout: undefined,
                                        bytesWritten: 639,
                                        bytesRead: 143898
                                  while the mm-out.log shows:
                                  [19.03.2024 21:23.35.168] [INFO]  Calendar-Fetcher: Broadcasting 5 events from https://p63-caldav.icloud.com/published/2/MTA....
                                  [19.03.2024 21:23.35.332] [INFO]  updatenotification: You are using pm2 with MagicMirror
                                  [19.03.2024 21:23.35.333] [INFO]  Checking git for module: MMM-soccer
                                  [19.03.2024 21:23.35.462] [INFO]  Checking git for module: MMM-Planetarium
                                  [19.03.2024 21:23.35.591] [INFO]  Checking git for module: MMM-Globe2
                                  [19.03.2024 21:23.36.450] [INFO]  Calendar-Fetcher: Broadcasting 0 events from https://p63-caldav.icloud.com/published/2/MTA....
                                  [19.03.2024 21:23.36.513] [INFO]  Checking git for module: MagicMirror
                                  [19.03.2024 21:23.36.963] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
                                  [19.03.2024 21:23.37.049] [INFO]  Newsfeed-Fetcher: Broadcasting 100 items.
                                  [19.03.2024 21:23.37.825] [INFO]  Calendar-Fetcher: Broadcasting 7 events from https://p63-caldav.icloud.com/published/2/MTA....
                                  [19.03.2024 21:24.03.308] [INFO]  Calendar-Fetcher: Broadcasting 8 events from https://p63-caldav.icloud.com/published/2/MTA....
                                  [19.03.2024 21:24.43.055] [INFO]  Calendar-Fetcher: Broadcasting 10 events from https://p29-caldav.icloud.com/published/2/ODA....
                                  [19.03.2024 21:24.43.503] [INFO]  Calendar-Fetcher: Broadcasting 1 events from https://i.cal.to/ical/77/....
                                  [19.03.2024 21:24.43.754] [INFO]  Calendar-Fetcher: Broadcasting 5 events from https://i.cal.to/ical/3/....
                                  [19.03.2024 21:24.43.781] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://i.cal.to/ical/61/....
                                  [19.03.2024 21:24.44.853] [INFO]  Calendar-Fetcher: Broadcasting 0 events from https://p63-caldav.icloud.com/published/2/MTA....
                                  [19.03.2024 21:24.45.665] [INFO]  Calendar-Fetcher: Broadcasting 7 events from https://p63-caldav.icloud.com/published/2/MTA....
                                  [19.03.2024 21:25.10.627] [INFO]  Calendar-Fetcher: Broadcasting 8 events from https://p63-caldav.icloud.com/published/2/MTA....
                                  I have increased the waitFetch, but it didn’t help.
                                  			position: "middle_center",
                                  			waitFetch: 32000,
                                  			disabled: false,
                                  Can someone help me?
                                  Max
                                  S M 3 Replies Last reply Reply Quote 0
                                    sdetweil @princemaxwell
                                    @princemaxwell the error log says problem w the default calendar as ext3 gets it’s events there
                                      princemaxwell @sdetweil
                                      @sdetweil when i disable the MMM-CalendarExt3 module, the errors are gone.
                                      All calendars are working fine and loading quickly in default calendar module.
                                        MMRIZE @princemaxwell
                                        @princemaxwell
                                        CX3 doesn’t connect or fetch calendar server. That error probably has been caused by default calendar module.
                                          @princemaxwell
                                          CX3*s do not use nodeJS at all, so they are not related to your error messages. The modules are executed on the browser level, not on the server-side node environment, so they could not affect server-side processes like calendar fetching.
                                          Your error message (UND_ERR_SOCKET) is caused by the undici node module; it may be used inside of the default calendar module to connect through HTTP/1.1. That error usually happens when the connection is closed by long waits or prior preemption.
                                          There is a weird thing. As far as I know, the default calendar module depends on node-ical, which uses axios instead of undici. So I wonder why and from where this error message comes.
                                          To make things simple clearly;
                                          1. Backup your current config.js in the safe area.
                                          2. Create a new config.js, and remove all other not-releated modules like MMM-Planetarium, MMM-soccer, … Leave only clock, calendar and MMM-CalendarExt3 modules.
                                          3. Begin with one or two calendars, not all the calendars.
                                          4. Try to execute MM again, and let’s see what happens.
                                          5. After confirmation that a small qty of calendars has no issue, add more calendars.
                                          6. After confirmation that there is no issue with the calendars, try adding more modules one by one.
                                          (A possible reason, I guess, is that your modules are racing to use the network/dest-server severely. For example, your calendars look being rescanned every minutes. You may need to rearrange the interval of the schedule.)
                                          S P 2 Replies Last reply Reply Quote 0
                                            sdetweil @MMRIZE
                                            @MMRIZE calendar uses built in fetch to get the ics file. we do not have node-ical fetch it for us ( the prior ical lib did not provide fetch)
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 34
                                            • 35
                                            • 24 / 35
