    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
      sdetweil @1lolo94
      @1lolo94 background
      use one of the modules that displays what you like and use position fullscreen_below, 3d, below is furthest away from the viewer , above is closest to the viewer and default is between them
      calendar full width. I don’t know, mm sets margin, all the way around so content is NOT jammed against the edge…
      see css/main.css at the top, 60px as I recall
      you can override that in custom.css
        sdetweil @1lolo94
        @1lolo94 said in MMM-CalendarExt3:
        and I will leave you alone
        I am here every day. am moderator
        ask away.
        others smarter than me will jump in too
          1lolo94 @1lolo94
          @sdetweil I was able to get the module - MMM-Wallpaper installed and working great - but depending on the picture, i cannot see the the calendar, events, days, etc. I’m assuming that is in the custom cc settings?
            sdetweil @1lolo94
            @1lolo94 no cool thing there. some background images will conflict w the foreground…
            I want dynamic opposite, but… no such thing
              bobbylx
              Hello all, just have a couple fine tuning questions for you. Both seem easy but I can’t seem to figure out why it’s not working. FWIW my MM has been running great for months now, finally doing some tweaking.
              So I’ve got MMM-Calendarext3 setup to only show 1 calendar, it’s my family google account. The last 2 things I would like to accomplish are having the text for long events scroll with useMarquee: true and then also to have the eventTransformer search for a name in the event title and change the color according to that.
              For some reason, I can’t get either of these to work. Config.js below. If I understand correctly, I shouldn’t need to add anything to custom.css correct? With the config file below, my calendar does not load at all, just get blank screen stating please create a config file, if I hash out the transformer stuff then it loads but never scrolls (marquee). Any advice from ya’ll smart folks?
                                             module: "MMM-CalendarExt3",
                                             position: "bottom_bar",
                                             title: "",
                                               mode: "",
                                               weekIndex: 0,
                                               weeksInView: 5,
                                               instanceId: "basicCalendar",
                                               locale: 'en-EN',
                                               maxEventLines: 5,
                                               fontSize: '26px',
                                               firstDayOfWeek: 0,
                                               refreshInterval: 120000,
                                               animationSpeed: 0,
                                               useMarquee: true,
                                               useSymbol: false,
                                               useWeather: true,
                                               displayWeatherTemp: true,
                                               calendarSet: ['us_holiday','family'],
                                             weatherPayload: (payload) => {
                       if (Array.isArray(payload?.forecastArray)) {
                         payload.forecastArray = payload.forecastArray.map((f) => {
                           f.maxTemperature = Math.round(f.maxTemperature * 9 / 5 + 32)
                           f.minTemperature = Math.round(f.minTemperature * 9 / 5 + 32)
                           return f
                       return payload
                                     eventTransformer: (ev) => {
                                      if (ev.title.search('Allie') > -1) ev.color = 'blue'
                                      return ev
              H M 2 Replies Last reply Reply Quote 0
              • H
                hrmax @bobbylx
                @bobbylx It could be because you aren’t settings the mode to week or month? It seems that the default is week but that would require that you omit the tag altogether rather than explicitly setting it to an empty string.
                  MMRIZE @bobbylx
                  @bobbylx said in MMM-CalendarExt3:
                       return payload
                     } // <== HERE
                                      return ev
                  You’ve missed comma(,) in the end of weatherPayload definition.
                    bobbylx @hrmax
                    @hrmax said in MMM-CalendarExt3:
                    I have it with no mode and a 5 week rolling view, so the current week is always at the top. I did change it back to month for testing but made no difference.
                    @MMRIZE said in MMM-CalendarExt3:
                         return payload
                       } // <== HERE
                                        return ev
                    Awesome, thank you! That did it.
                    Last one, using the Marquee for long calendar events. Is there anything else I need to do to make that work? See my config.js above, I added useMarquee: ‘true’ but it changed nothing. I assume I’m missing something simple again.
                    • L
                      Lilleberg
                      I have an issue trying to show events from Googles shared family calendar. I have several Google calendars that shows perfectly in the CalendarExt3 module. But to show events from the shared family calendar has been quite an issue.
                      I found out that I had to install the MMM-GoogleCalendar. In this module I manage to show the events from the shared calendar. But they won´t show up in the CalendarExt3 module.
                      I found this code (https://github.com/MMRIZE/MMM-CalendarExt3/wiki/Compatible-with-randomBrainstormer-MMM-GoogleCalendar) that should resolve it, but when i paste this code at the end of the config of the CalendarExt3 module. No events show up. Even the events that allready shows from the other Google Calendars.
                      I have the default calendar module to fetch the events from all of my Google Calendars, and the the GoogleCalendar module to fetch the shared calendar. I tried removing the default calendar module from the config file, and with just one calendar in the GoogleCalendar module. But no result.
                      It shows just fine in the GoogleCalendar module, so it seems to be a problem to convert the events from the GoogleCalendar module to the CalendarExt3 module.
                        sdetweil @Lilleberg
                        @Lilleberg ext3 gets it’s events from another calendar module. either the default calendar or another.
                        so if you use MMM-GoogleCalendar then it has the calendar url.
                        • L
                          Lilleberg @sdetweil
                          @sdetweil Not sure if I understod you here. What do you mean with the last sentence?
                            sdetweil @Lilleberg
                            @Lilleberg typo, calendar url
                              MMRIZE @Lilleberg
                              @Lilleberg Show us your config.
                              • L
                                Lilleberg @MMRIZE
                                Here is my config- I have replaced the calendar urls under as I dont want to show them to the world.
                                			module: 'MMM-Remote-Control',
                                			// position: 'bottom_left',
                                            apiKey: 'c92e9765778gh56h83f66fffd333c6a5'
                                			module: "alert",
                                			module: 'MMM-YrThen',
                                			position: 'top_left',
                                				showAll: "false",
                                				details: "false",
                                				title: "Været på Frekhaug neste uke",
                                				header: "true",
                                				windGust: "true",
                                				windUnit: "m/s",
                                			module: "clock",
                                			dateFormat: "dddd, D. MMMM YYYY",
                                			showSunTimes: "true",
                                			lat: "60.520806",
                                			lon: "5.237736",
                                			module: 'MMM-YrNow',
                                			position: 'top_right',
                                				locationId: '1-107159',
                                				showWeatherForecast: true
                                			hiddenOnStartup: "true",
                                				broadcastPastEvents: true, // <= IMPORTANT to see past events
                                						symbol: "none",
                                						url: "Google Calendar url",
                                						color: "#8BD3E6", //Blå
                                						symbol: "none",
                                						color: "#800080", //Lilla
                                						symbol: "none",
                                						color: "#FF6D6A", //Rød
                                						symbol: "none",
                                						url: "hGoogle Calendar url",
                                						color: "#E9EC6B", //Gul
                                						symbol: "none",
                                						color: "#77DD77", //Grønn
                                						symbol: "none",
                                						color: "#fffff", //Hvit
                                			module: 'MMM-GoogleCalendar',
                                					symbol: "none",
                                					calendarID: "Google Calendar id"
                                					color: "#000000", //Svart
                                			title: "",
                                				mode: "week",
                                				weekIndex: "0",
                                				weeksInView: "4",
                                				locale: 'nb',
                                				maxEventLines: 10,
                                				firstDayOfWeek: 1,
                                				calendarSet: [],
                                				eventHeight: "22px",
                                				displayLegend: "true",
                                				eventTransformer: (e) => {
                                					e.startDate = new Date(e.start?.date || e.start?.dateTime).valueOf()
                                					e.endDate = new Date(e.end?.date || e.end?.dateTime).valueOf()
                                					e.title = e.summary
                                					e.fulldayEvent = (e.start?.date) ? true : false
                                					return e
                                  MMRIZE @Lilleberg
                                  @Lilleberg
                                  Check broadcastEvents:true in your MMM-GoogleCalendar’s config. Unlike the original calendar module, MMM-GoogleCalendar has this value as false by default.
                                  • L
                                    Lilleberg @MMRIZE
                                    @MMRIZE Tried adding this to the config, but still no result. The module broadcasts the events, but they wont show in the Ext3 module. Se attached image. I have removed the other calendars from the config, and only show the events from the Google Calendar module.20240312_183109.jpg
                                      MMRIZE @Lilleberg
                                      @Lilleberg If possible, can you share the copy of your calendar? (And the final config file also) (eouia0819@gmail.com)
                                      Without the real data I couldn’t catch what really happened in yours.
                                      L N 2 Replies Last reply Reply Quote 0
                                      • L
                                        Lilleberg @MMRIZE
                                        @MMRIZE I’m sending you an e-mail
                                        • N
                                          nicmoly @MMRIZE
                                          @MMRIZE Hi Im also having the exact same issue as @Lilleberg , I have however seen glimpses of this working as intended but it seems to be on a whim, either it restarts and works and then not again untill a further reboot or it just wont. I find it weird that using MMM-CalendarExt3Journal works perfect every time with similar settings. Any ideas on what may be going on? Weird thing is leaving the MMM running all the sudden it works like 20-30min later, so im wondering if theres some weirdness with how the data comes in from the GoogleCalendar module
                                          Heres my config for refrence:
                                             			header: "My Google Private Cal",
                                            			position: "upper_third",
                                          			hiddenOnStartup: true,
                                          				broadcastEvents: true,
                                          							symbol: "calendar-week",
                                          							calendarID: "***",
                                          							name: "1_cal", // <= RECOMMENDED to assign name
                                          							color: "yellow" // <= RECOMMENDED to assign color
                                          							calendarID: "***",
                                          							name: "2_cal", // <= RECOMMENDED to assign name
                                          							color: "red" // <= RECOMMENDED to assign color
                                          							calendarID: "en.canadian#holiday@group.v.calendar.google.com",
                                          							name: "holiday_cal", // <= RECOMMENDED to assign name
                                          							color: "green" // <= RECOMMENDED to assign color
                                            			position: "lower_third",
                                          			title: "Family Calendar",
                                          				mode: "month",
                                          				instanceID: "I-calendar-month",
                                          				maxEventLines: 5,
                                          				firstDayOfWeek: 1,
                                          				preProcessor: (e) => {
                                          					if (e.start?.dateTime) {
                                          				  		e.startDate = new Date(e.start.dateTime).valueOf()
                                          					} else if (e.start?.date) {
                                          				  		e.startDate = new Date(`${e.start.date}T00:00:00`).valueOf()
                                          					if (e.end?.dateTime) {
                                          				  		e.endDate = new Date(e.end.dateTime).valueOf()
                                          					} else if (e.end?.date) {
                                          				  		e.endDate = new Date(`${e.end.date}T00:00:00`).valueOf()
                                          					e.title = e.summary
                                          					e.fullDayEvent = (e.start?.date) ? true : false
                                          					return e
                                          //  			module: "MMM-CalendarExt3Journal",
                                          //  			position: "bottom_bar",
                                          //  			config: {
                                          //				height: '50vh',
                                          //   			 	width: '100%',
                                          //				//locale: 'en-GB',
                                          //				staticWeek: true,
                                          //				staticTime: true,
                                          //				hourLength: 14,
                                          //				beginHour:  8,
                                          //				preProcessor: (e) => {
                                          //					if (e.start?.dateTime) {
                                          //				  		e.startDate = new Date(e.start.dateTime).valueOf()
                                          //					} else if (e.start?.date) {
                                          //				  		e.startDate = new Date(`${e.start.date}T00:00:00`).valueOf()
                                          //					if (e.end?.dateTime) {
                                          //				  		e.endDate = new Date(e.end.dateTime).valueOf()
                                          //					} else if (e.end?.date) {
                                          //				  		e.endDate = new Date(`${e.end.date}T00:00:00`).valueOf()
                                          //					e.title = e.summary
                                          //					e.fullDayEvent = (e.start?.date) ? true : false
                                          //					return e
                                            MMRIZE @nicmoly
                                            @nicmoly
                                            Usually, your symptom happens by insufficient waitFetch. Give it more. (By default it would be 5_000 ms. Give it more like 10_000)
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 34
                                            • 35
                                            • 24 / 35
