    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
      princemaxwell
      @MMRIZE
      All right, that makes complete sense.
      I understand that now.
      CX3 initially only recognizes broadcast events and does not know how many calendars are configured and waits until all of them have been processed.
      (The default value is 5000ms, not 300000)
      By the way, with the 300000 I meant the time from the default calendar, the “fetchInterval”, whose default value is: 300000 (5 minutes).
      I tried the 2nd option, unfortunately it doesn’t work, I set it to 1000 * 60 * 2, but it takes exactly 10 minutes.
      When and how often is waitFetch executed, just once? I would have expected CX3 to notice a broadcast and then update according to waitFetch.
      M 1 Reply Last reply
        MMRIZE @princemaxwell
        @princemaxwell
        waitFetch will be applied only to the very first broadcast notification. If you set waitFetch: 120000, this sequence will happen (I’ll assume the calendar module is described before CX3 in config.js)
        1. the calendar module starts the parsing of calendars.
        2. CX3 module starts. Library is loaded and the DOM is prepared. It is now ready to receive the events.
        3. The first calendars might complete its fetching. then calendar module will broadcast the events at that moment.
        4. CX3 receive the first broadcasted events. Wait 120000ms(2 minute) from that moment to get other lazy broadcasting coming.
        5. Other calendars might be fetched. But some might still need to be completed.
        6. Anyway, after 120000ms from the first broadcast, CX3 will draw the events that have arrived till then. (It means the view of CX3 is shown for the first time after at least 2 minutes from the boot)
        7. Then after 10minutes(refreshInterval), CX3 will refresh again. Maybe until then, all calendars would have been fetched.(I hope.)
        Anyway your log was showing the 1st calendar fetching as below;
        [20.03.2024 15:28.57.729] [INFO]  Calendar-Fetcher: Broadcasting 2 events from ...
        And the 8th fetching ;
        [20.03.2024 15:30.30.417] [INFO]  Calendar-Fetcher: Broadcasting 12 events from ...
        It takes 93 seconds to complete. So I think waitFetch: 120000 (120 seconds) would be enough; however, if there are still missing events, the possible reasons would be;
        1. It takes more than 120 seconds at that moment randomly to complete fetching of all calendars since first fetching,
        2. some calendars were too fast-fetched before CX3 was ready. so they were missed. (all modules are loaded and starts sequentially, so if you have certain number of modules, CX3 may not be ready until that moment.)
        Of course, you can adjust the order of modules in config, assign needed values of waitFetch and refreshInterval to show the entire events properly on the first boot time.
        But, my suggestion is,
        Just leave them and do nothing.
        After 10 minutes from the first bootup, everything will be OK. Your MM might be rebooted at midnight or in the morning on real-life usage. MM would stay turned on all day or for several days. So literally, nobody will care, even realize there had been some missing events on the bootup time. You don’t have to make an effort to solve this unworthy issue.
        P 1 Reply Last reply
          princemaxwell @MMRIZE
          @MMRIZE
          The standards are absolutely sufficient for everyday use.
          But while I position the modules and adapt the CSS to my own wishes and test the functions of the modules, the long time is rather annoying and I wanted to shorten it.
          I have now activated the following config and restarted.
          I recorded the contents of the screen and looked at exactly when and what happened.
          		module: "MMM-CalendarExt3",
          		position: "middle_center",
          		disabled: false,
          		waitFetch: 1000 * 60 * 2,
          		refreshInterval: 1000 * 60 * 2,
          		module: "MMM-CalendarExt3Agenda",
          		position: "top_center",
          		disabled: false,
          		title: "Kalender",
          			instanceId: "basicCalendar",
          			locale: 'de',
          			firstDayOfWeek: 1,
          			startDayIndex: -1,
          			endDayIndex: 10,
          			calendarSet: []
          The result is that the config is ignored.
          • CX3 starts after the calendar module and displayed the first entries of the 3 small calendars as soon as they appeared.
          • CX3 only refreshes after 10 minutes. You can tell this by the display briefly disappearing and then fading in again. Then all entries are included.
          • CX3A also starts after the calendar module and also shows the entries of the 3 small calendars directly.
          • CX3A refreshes after 30 minutes (default?). Even then, all entries are included.
          Apparently waitFetch is ignored for both, otherwise, according to your explanation, the first entries would only appear after waitFetch. But these are there immediately as soon as the module has been loaded.
          Other configurations are also ignored. For example, I used this for testing:
          mode: ‘day’,
          But i only get the week view.
          When i change it in MMM-CalendarExt3.js, then it works.
          Why is the config ignored or what am I missing?
            @princemaxwell
            You did a simple mistake. Configuration parameters of the module should be placed inside of the module’s config:{}.
              @MMRIZE
              Oh no, that’s embarrassing. I completely overlooked that and of course it works now. So often you look at what the problem could be and just don’t see it.
              Thank you very much for your help!
              • F
                flemmingss
                I can’t get this to work, just has this basic config, and it is just empty, got the orginal calender app to show the events, but can’t see anything in the MMM-CalendarExt3 module, just the name of the month “Mars”…
                _
                			//Removing this to hide default calendar module position: "top_left",
                				broadcastPastEvents: true, // <= IMPORTANT to see past events
                						name: "us_holiday", // <= RECOMMENDED to assign name
                						color: "red", // <= RECOMMENDED to assign color
                						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
                		  position: "top_bar",
                		  title: "Kalender",
                		    mode: "month",
                		    locale: 'no-NO', // Norwegian, ref https://www.localeplanet.com/java/no-NO/index.html
                		    maxEventLines: 5,
                		    firstDayOfWeek: 1,
                docker start log:
                text  error  warn  system  array  login
                ---Ensuring UID: 99 matches user---
                ---Ensuring GID: 100 matches user---
                ---Setting umask to 000---
                ---Checking for optional scripts---
                ---No optional script found, continuing---
                ---Taking ownership of data...---
                ---Starting...---
                ---Force Update enabled!---
                v2.26.0.tar.gz      100%[===================>] 381.10K  --.-KB/s    in 0.1s
                ---Successfully downloaded MagicMirror² v2.26.0!---
                rm: refusing to remove '.' or '..' directory: skipping '/magicmirror2/.'
                rm: refusing to remove '.' or '..' directory: skipping '/magicmirror2/..'
                MagicMirror-2.26.0/
                MagicMirror-2.26.0/.editorconfig
                MagicMirror-2.26.0/.eslintignore
                MagicMirror-2.26.0/.eslintrc.json
                MagicMirror-2.26.0/.gitattributes
                MagicMirror-2.26.0/.github/
                MagicMirror-2.26.0/.github/CONTRIBUTING.md
                MagicMirror-2.26.0/.github/FUNDING.yaml
                MagicMirror-2.26.0/.github/ISSUE_TEMPLATE.md
                MagicMirror-2.26.0/.github/PULL_REQUEST_TEMPLATE.md
                MagicMirror-2.26.0/.github/codecov.yaml
                MagicMirror-2.26.0/.github/dependabot.yaml
                MagicMirror-2.26.0/.github/header.png
                MagicMirror-2.26.0/.github/stale.yaml
                MagicMirror-2.26.0/.github/workflows/
                MagicMirror-2.26.0/.github/workflows/automated-tests.yaml
                MagicMirror-2.26.0/.github/workflows/depsreview.yaml
                MagicMirror-2.26.0/.github/workflows/enforce-pullrequest-rules.yaml
                MagicMirror-2.26.0/.gitignore
                MagicMirror-2.26.0/.husky/
                MagicMirror-2.26.0/.husky/pre-commit
                MagicMirror-2.26.0/.npmrc
                MagicMirror-2.26.0/.prettierignore
                MagicMirror-2.26.0/.prettierrc.json
                MagicMirror-2.26.0/.stylelintrc.json
                MagicMirror-2.26.0/CHANGELOG.md
                MagicMirror-2.26.0/Collaboration.md
                MagicMirror-2.26.0/LICENSE.md
                MagicMirror-2.26.0/README.md
                MagicMirror-2.26.0/clientonly/
                MagicMirror-2.26.0/clientonly/index.js
                MagicMirror-2.26.0/config/
                MagicMirror-2.26.0/config/config.js.sample
                MagicMirror-2.26.0/css/
                MagicMirror-2.26.0/css/custom.css.sample
                MagicMirror-2.26.0/css/main.css
                MagicMirror-2.26.0/fonts/
                MagicMirror-2.26.0/fonts/package-lock.json
                MagicMirror-2.26.0/fonts/package.json
                MagicMirror-2.26.0/fonts/roboto.css
                MagicMirror-2.26.0/index.html
                MagicMirror-2.26.0/installers/
                MagicMirror-2.26.0/installers/mm.sh
                MagicMirror-2.26.0/jest.config.js
                MagicMirror-2.26.0/js/
                MagicMirror-2.26.0/js/animateCSS.js
                MagicMirror-2.26.0/js/app.js
                MagicMirror-2.26.0/js/check_config.js
                MagicMirror-2.26.0/js/class.js
                MagicMirror-2.26.0/js/defaults.js
                MagicMirror-2.26.0/js/deprecated.js
                MagicMirror-2.26.0/js/electron.js
                MagicMirror-2.26.0/js/loader.js
                MagicMirror-2.26.0/js/logger.js
                MagicMirror-2.26.0/js/main.js
                MagicMirror-2.26.0/js/module.js
                MagicMirror-2.26.0/js/node_helper.js
                MagicMirror-2.26.0/js/server.js
                MagicMirror-2.26.0/js/server_functions.js
                MagicMirror-2.26.0/js/socketclient.js
                MagicMirror-2.26.0/js/translator.js
                MagicMirror-2.26.0/js/utils.js
                MagicMirror-2.26.0/jsconfig.json
                MagicMirror-2.26.0/module-types.ts
                MagicMirror-2.26.0/modules/
                MagicMirror-2.26.0/modules/default/
                MagicMirror-2.26.0/modules/default/alert/
                MagicMirror-2.26.0/modules/default/alert/README.md
                MagicMirror-2.26.0/modules/default/alert/alert.js
                MagicMirror-2.26.0/modules/default/alert/notificationFx.js
                MagicMirror-2.26.0/modules/default/alert/styles/
                MagicMirror-2.26.0/modules/default/alert/styles/center.css
                MagicMirror-2.26.0/modules/default/alert/styles/left.css
                MagicMirror-2.26.0/modules/default/alert/styles/notificationFx.css
                MagicMirror-2.26.0/modules/default/alert/styles/right.css
                MagicMirror-2.26.0/modules/default/alert/templates/
                MagicMirror-2.26.0/modules/default/alert/templates/alert.njk
                MagicMirror-2.26.0/modules/default/alert/templates/notification.njk
                MagicMirror-2.26.0/modules/default/alert/translations/
                MagicMirror-2.26.0/modules/default/alert/translations/bg.json
                MagicMirror-2.26.0/modules/default/alert/translations/da.json
                MagicMirror-2.26.0/modules/default/alert/translations/de.json
                MagicMirror-2.26.0/modules/default/alert/translations/en.json
                MagicMirror-2.26.0/modules/default/alert/translations/es.json
                MagicMirror-2.26.0/modules/default/alert/translations/fr.json
                MagicMirror-2.26.0/modules/default/alert/translations/hu.json
                MagicMirror-2.26.0/modules/default/alert/translations/nl.json
                MagicMirror-2.26.0/modules/default/alert/translations/ru.json
                MagicMirror-2.26.0/modules/default/alert/translations/th.json
                MagicMirror-2.26.0/modules/default/calendar/
                MagicMirror-2.26.0/modules/default/calendar/README.md
                MagicMirror-2.26.0/modules/default/calendar/calendar.css
                MagicMirror-2.26.0/modules/default/calendar/calendar.js
                MagicMirror-2.26.0/modules/default/calendar/calendarfetcher.js
                MagicMirror-2.26.0/modules/default/calendar/calendarfetcherutils.js
                MagicMirror-2.26.0/modules/default/calendar/calendarutils.js
                MagicMirror-2.26.0/modules/default/calendar/debug.js
                MagicMirror-2.26.0/modules/default/calendar/node_helper.js
                MagicMirror-2.26.0/modules/default/calendar/windowsZones.json
                MagicMirror-2.26.0/modules/default/clock/
                MagicMirror-2.26.0/modules/default/clock/README.md
                MagicMirror-2.26.0/modules/default/clock/clock.js
                MagicMirror-2.26.0/modules/default/clock/clock_styles.css
                MagicMirror-2.26.0/modules/default/clock/faces/
                MagicMirror-2.26.0/modules/default/clock/faces/face-001.svg
                MagicMirror-2.26.0/modules/default/clock/faces/face-002.svg
                MagicMirror-2.26.0/modules/default/clock/faces/face-003.svg
                MagicMirror-2.26.0/modules/default/clock/faces/face-004.svg
                MagicMirror-2.26.0/modules/default/clock/faces/face-005.svg
                MagicMirror-2.26.0/modules/default/clock/faces/face-006.svg
                MagicMirror-2.26.0/modules/default/clock/faces/face-007.svg
                MagicMirror-2.26.0/modules/default/clock/faces/face-008.svg
                MagicMirror-2.26.0/modules/default/clock/faces/face-009.svg
                MagicMirror-2.26.0/modules/default/clock/faces/face-010.svg
                MagicMirror-2.26.0/modules/default/clock/faces/face-011.svg
                MagicMirror-2.26.0/modules/default/clock/faces/face-012.svg
                MagicMirror-2.26.0/modules/default/compliments/
                MagicMirror-2.26.0/modules/default/compliments/README.md
                MagicMirror-2.26.0/modules/default/compliments/compliments.js
                MagicMirror-2.26.0/modules/default/defaultmodules.js
                MagicMirror-2.26.0/modules/default/helloworld/
                MagicMirror-2.26.0/modules/default/helloworld/README.md
                MagicMirror-2.26.0/modules/default/helloworld/helloworld.js
                MagicMirror-2.26.0/modules/default/helloworld/helloworld.njk
                MagicMirror-2.26.0/modules/default/newsfeed/
                MagicMirror-2.26.0/modules/default/newsfeed/README.md
                MagicMirror-2.26.0/modules/default/newsfeed/fullarticle.njk
                MagicMirror-2.26.0/modules/default/newsfeed/newsfeed.css
                MagicMirror-2.26.0/modules/default/newsfeed/newsfeed.js
                MagicMirror-2.26.0/modules/default/newsfeed/newsfeed.njk
                MagicMirror-2.26.0/modules/default/newsfeed/newsfeedfetcher.js
                MagicMirror-2.26.0/modules/default/newsfeed/node_helper.js
                MagicMirror-2.26.0/modules/default/newsfeed/oldconfig.njk
                MagicMirror-2.26.0/modules/default/updatenotification/
                MagicMirror-2.26.0/modules/default/updatenotification/README.md
                MagicMirror-2.26.0/modules/default/updatenotification/git_helper.js
                MagicMirror-2.26.0/modules/default/updatenotification/node_helper.js
                MagicMirror-2.26.0/modules/default/updatenotification/update_helper.js
                MagicMirror-2.26.0/modules/default/updatenotification/updatenotification.css
                MagicMirror-2.26.0/modules/default/updatenotification/updatenotification.js
                MagicMirror-2.26.0/modules/default/updatenotification/updatenotification.njk
                MagicMirror-2.26.0/modules/default/utils.js
                MagicMirror-2.26.0/modules/default/weather/
                MagicMirror-2.26.0/modules/default/weather/README.md
                MagicMirror-2.26.0/modules/default/weather/current.njk
                MagicMirror-2.26.0/modules/default/weather/forecast.njk
                MagicMirror-2.26.0/modules/default/weather/hourly.njk
                MagicMirror-2.26.0/modules/default/weather/providers/
                MagicMirror-2.26.0/modules/default/weather/providers/README.md
                MagicMirror-2.26.0/modules/default/weather/providers/envcanada.js
                MagicMirror-2.26.0/modules/default/weather/providers/openmeteo.js
                MagicMirror-2.26.0/modules/default/weather/providers/openweathermap.js
                MagicMirror-2.26.0/modules/default/weather/providers/overrideWrapper.js
                MagicMirror-2.26.0/modules/default/weather/providers/pirateweather.js
                MagicMirror-2.26.0/modules/default/weather/providers/smhi.js
                MagicMirror-2.26.0/modules/default/weather/providers/ukmetoffice.js
                MagicMirror-2.26.0/modules/default/weather/providers/ukmetofficedatahub.js
                MagicMirror-2.26.0/modules/default/weather/providers/weatherbit.js
                MagicMirror-2.26.0/modules/default/weather/providers/weatherflow.js
                MagicMirror-2.26.0/modules/default/weather/providers/weathergov.js
                MagicMirror-2.26.0/modules/default/weather/providers/yr.js
                MagicMirror-2.26.0/modules/default/weather/weather.css
                MagicMirror-2.26.0/modules/default/weather/weather.js
                MagicMirror-2.26.0/modules/default/weather/weatherobject.js
                MagicMirror-2.26.0/modules/default/weather/weatherprovider.js
                MagicMirror-2.26.0/modules/default/weather/weatherutils.js
                MagicMirror-2.26.0/package-lock.json
                MagicMirror-2.26.0/package.json
                MagicMirror-2.26.0/serveronly/
                MagicMirror-2.26.0/serveronly/index.js
                MagicMirror-2.26.0/splashscreen/
                MagicMirror-2.26.0/splashscreen/MagicMirror.plymouth
                MagicMirror-2.26.0/splashscreen/MagicMirror.script
                MagicMirror-2.26.0/splashscreen/splash.png
                MagicMirror-2.26.0/splashscreen/splash_halt.png
                MagicMirror-2.26.0/tests/
                MagicMirror-2.26.0/tests/configs/
                MagicMirror-2.26.0/tests/configs/default.js
                MagicMirror-2.26.0/tests/configs/empty_ipWhiteList.js
                MagicMirror-2.26.0/tests/configs/modules/
                MagicMirror-2.26.0/tests/configs/modules/alert/
                MagicMirror-2.26.0/tests/configs/modules/alert/default.js
                MagicMirror-2.26.0/tests/configs/modules/calendar/
                MagicMirror-2.26.0/tests/configs/modules/calendar/auth-default.js
                MagicMirror-2.26.0/tests/configs/modules/calendar/bad_rrule.js
                MagicMirror-2.26.0/tests/configs/modules/calendar/basic-auth.js
                MagicMirror-2.26.0/tests/configs/modules/calendar/changed-port.js
                MagicMirror-2.26.0/tests/configs/modules/calendar/custom.js
                MagicMirror-2.26.0/tests/configs/modules/calendar/default.js
                MagicMirror-2.26.0/tests/configs/modules/calendar/exdate.js
                MagicMirror-2.26.0/tests/configs/modules/calendar/fail-basic-auth.js
                MagicMirror-2.26.0/tests/configs/modules/calendar/old-basic-auth.js
                MagicMirror-2.26.0/tests/configs/modules/calendar/recurring.js
                MagicMirror-2.26.0/tests/configs/modules/calendar/show-duplicates-in-calendar.js
                MagicMirror-2.26.0/tests/configs/modules/clock/
                MagicMirror-2.26.0/tests/configs/modules/clock/clock_12hr.js
                MagicMirror-2.26.0/tests/configs/modules/clock/clock_24hr.js
                MagicMirror-2.26.0/tests/configs/modules/clock/clock_analog.js
                MagicMirror-2.26.0/tests/configs/modules/clock/clock_displaySeconds_false.js
                MagicMirror-2.26.0/tests/configs/modules/clock/clock_showDateAnalog.js
                MagicMirror-2.26.0/tests/configs/modules/clock/clock_showPeriodUpper.js
                MagicMirror-2.26.0/tests/configs/modules/clock/clock_showSunMoon.js
                MagicMirror-2.26.0/tests/configs/modules/clock/clock_showTime.js
                MagicMirror-2.26.0/tests/configs/modules/clock/clock_showWeek.js
                MagicMirror-2.26.0/tests/configs/modules/clock/es/
                MagicMirror-2.26.0/tests/configs/modules/clock/es/clock_12hr.js
                MagicMirror-2.26.0/tests/configs/modules/clock/es/clock_24hr.js
                MagicMirror-2.26.0/tests/configs/modules/clock/es/clock_showPeriodUpper.js
                MagicMirror-2.26.0/tests/configs/modules/clock/es/clock_showWeek.js
                MagicMirror-2.26.0/tests/configs/modules/compliments/
                MagicMirror-2.26.0/tests/configs/modules/compliments/compliments_animateCSS.js
                MagicMirror-2.26.0/tests/configs/modules/compliments/compliments_animateCSS_fallbackToDefault.js
                MagicMirror-2.26.0/tests/configs/modules/compliments/compliments_animateCSS_invertedAnimationName.js
                MagicMirror-2.26.0/tests/configs/modules/compliments/compliments_anytime.js
                MagicMirror-2.26.0/tests/configs/modules/compliments/compliments_date.js
                MagicMirror-2.26.0/tests/configs/modules/compliments/compliments_only_anytime.js
                MagicMirror-2.26.0/tests/configs/modules/compliments/compliments_parts_day.js
                MagicMirror-2.26.0/tests/configs/modules/compliments/compliments_remote.js
                MagicMirror-2.26.0/tests/configs/modules/display.js
                MagicMirror-2.26.0/tests/configs/modules/helloworld/
                MagicMirror-2.26.0/tests/configs/modules/helloworld/helloworld.js
                MagicMirror-2.26.0/tests/configs/modules/helloworld/helloworld_default.js
                MagicMirror-2.26.0/tests/configs/modules/newsfeed/
                MagicMirror-2.26.0/tests/configs/modules/newsfeed/default.js
                MagicMirror-2.26.0/tests/configs/modules/newsfeed/ignore_items.js
                MagicMirror-2.26.0/tests/configs/modules/newsfeed/incorrect_url.js
                MagicMirror-2.26.0/tests/configs/modules/newsfeed/prohibited_words.js
                MagicMirror-2.26.0/tests/configs/modules/positions.js
                MagicMirror-2.26.0/tests/configs/modules/weather/
                MagicMirror-2.26.0/tests/configs/modules/weather/currentweather_compliments.js
                MagicMirror-2.26.0/tests/configs/modules/weather/currentweather_default.js
                MagicMirror-2.26.0/tests/configs/modules/weather/currentweather_options.js
                MagicMirror-2.26.0/tests/configs/modules/weather/currentweather_units.js
                MagicMirror-2.26.0/tests/configs/modules/weather/forecastweather_absolute.js
                MagicMirror-2.26.0/tests/configs/modules/weather/forecastweather_default.js
                MagicMirror-2.26.0/tests/configs/modules/weather/forecastweather_options.js
                MagicMirror-2.26.0/tests/configs/modules/weather/forecastweather_units.js
                MagicMirror-2.26.0/tests/configs/modules/weather/hourlyweather_default.js
                MagicMirror-2.26.0/tests/configs/modules/weather/hourlyweather_options.js
                MagicMirror-2.26.0/tests/configs/modules/weather/hourlyweather_showPrecipitation.js
                MagicMirror-2.26.0/tests/configs/noIpWhiteList.js
                MagicMirror-2.26.0/tests/configs/port_8090.js
                MagicMirror-2.26.0/tests/configs/port_variable.env
                MagicMirror-2.26.0/tests/configs/port_variable.js.template
                MagicMirror-2.26.0/tests/configs/without_modules.js
                MagicMirror-2.26.0/tests/e2e/
                MagicMirror-2.26.0/tests/e2e/animateCSS_spec.js
                MagicMirror-2.26.0/tests/e2e/env_spec.js
                MagicMirror-2.26.0/tests/e2e/fonts_spec.js
                MagicMirror-2.26.0/tests/e2e/helpers/
                MagicMirror-2.26.0/tests/e2e/helpers/basic-auth.js
                MagicMirror-2.26.0/tests/e2e/helpers/global-setup.js
                MagicMirror-2.26.0/tests/e2e/helpers/mock-console.js
                MagicMirror-2.26.0/tests/e2e/helpers/weather-functions.js
                MagicMirror-2.26.0/tests/e2e/ipWhitelist_spec.js
                MagicMirror-2.26.0/tests/e2e/modules/
                MagicMirror-2.26.0/tests/e2e/modules/alert_spec.js
                MagicMirror-2.26.0/tests/e2e/modules/calendar_spec.js
                MagicMirror-2.26.0/tests/e2e/modules/clock_es_spec.js
                MagicMirror-2.26.0/tests/e2e/modules/clock_spec.js
                MagicMirror-2.26.0/tests/e2e/modules/compliments_spec.js
                MagicMirror-2.26.0/tests/e2e/modules/helloworld_spec.js
                MagicMirror-2.26.0/tests/e2e/modules/newsfeed_spec.js
                MagicMirror-2.26.0/tests/e2e/modules/weather_current_spec.js
                MagicMirror-2.26.0/tests/e2e/modules/weather_forecast_spec.js
                MagicMirror-2.26.0/tests/e2e/modules/weather_hourly_spec.js
                MagicMirror-2.26.0/tests/e2e/modules_display_spec.js
                MagicMirror-2.26.0/tests/e2e/modules_empty_spec.js
                MagicMirror-2.26.0/tests/e2e/modules_position_spec.js
                MagicMirror-2.26.0/tests/e2e/port_spec.js
                MagicMirror-2.26.0/tests/e2e/serveronly_spec.js
                MagicMirror-2.26.0/tests/e2e/template_spec.js
                MagicMirror-2.26.0/tests/e2e/translations_spec.js
                MagicMirror-2.26.0/tests/e2e/vendor_spec.js
                MagicMirror-2.26.0/tests/electron/
                MagicMirror-2.26.0/tests/electron/env_spec.js
                MagicMirror-2.26.0/tests/electron/helpers/
                MagicMirror-2.26.0/tests/electron/helpers/global-setup.js
                MagicMirror-2.26.0/tests/electron/helpers/weather-setup.js
                MagicMirror-2.26.0/tests/electron/modules/
                MagicMirror-2.26.0/tests/electron/modules/calendar_spec.js
                MagicMirror-2.26.0/tests/electron/modules/compliments_spec.js
                MagicMirror-2.26.0/tests/electron/modules/weather_spec.js
                MagicMirror-2.26.0/tests/mocks/
                MagicMirror-2.26.0/tests/mocks/bad_rrule.ics
                MagicMirror-2.26.0/tests/mocks/calendar_test.ics
                MagicMirror-2.26.0/tests/mocks/calendar_test_clone.ics
                MagicMirror-2.26.0/tests/mocks/calendar_test_exdate.ics
                MagicMirror-2.26.0/tests/mocks/calendar_test_icons.ics
                MagicMirror-2.26.0/tests/mocks/calendar_test_recurring.ics
                MagicMirror-2.26.0/tests/mocks/compliments_test.json
                MagicMirror-2.26.0/tests/mocks/newsfeed_test.xml
                MagicMirror-2.26.0/tests/mocks/translation_test.json
                MagicMirror-2.26.0/tests/mocks/weather_current.json
                MagicMirror-2.26.0/tests/mocks/weather_forecast.json
                MagicMirror-2.26.0/tests/mocks/weather_hourly.json
                MagicMirror-2.26.0/tests/unit/
                MagicMirror-2.26.0/tests/unit/classes/
                MagicMirror-2.26.0/tests/unit/classes/class_spec.js
                MagicMirror-2.26.0/tests/unit/classes/deprecated_spec.js
                MagicMirror-2.26.0/tests/unit/classes/translator_spec.js
                MagicMirror-2.26.0/tests/unit/classes/utils_spec.js
                MagicMirror-2.26.0/tests/unit/functions/
                MagicMirror-2.26.0/tests/unit/functions/__snapshots__/
                MagicMirror-2.26.0/tests/unit/functions/__snapshots__/updatenotification_spec.js.snap
                MagicMirror-2.26.0/tests/unit/functions/cmp_versions_spec.js
                MagicMirror-2.26.0/tests/unit/functions/server_functions_spec.js
                MagicMirror-2.26.0/tests/unit/functions/updatenotification_spec.js
                MagicMirror-2.26.0/tests/unit/global_vars/
                MagicMirror-2.26.0/tests/unit/global_vars/defaults_modules_spec.js
                MagicMirror-2.26.0/tests/unit/global_vars/root_path_spec.js
                MagicMirror-2.26.0/tests/unit/helpers/
                MagicMirror-2.26.0/tests/unit/helpers/global-setup.js
                MagicMirror-2.26.0/tests/unit/modules/
                MagicMirror-2.26.0/tests/unit/modules/default/
                MagicMirror-2.26.0/tests/unit/modules/default/calendar/
                MagicMirror-2.26.0/tests/unit/modules/default/calendar/calendar_fetcher_utils_bad_rrule.js
                MagicMirror-2.26.0/tests/unit/modules/default/calendar/calendar_fetcher_utils_spec.js
                MagicMirror-2.26.0/tests/unit/modules/default/calendar/calendar_utils_spec.js
                MagicMirror-2.26.0/tests/unit/modules/default/utils_spec.js
                MagicMirror-2.26.0/tests/unit/modules/default/weather/
                MagicMirror-2.26.0/tests/unit/modules/default/weather/weather_object_spec.js
                MagicMirror-2.26.0/tests/unit/modules/default/weather/weather_utils_spec.js
                MagicMirror-2.26.0/tests/utils/
                MagicMirror-2.26.0/tests/utils/test_sequencer.js
                MagicMirror-2.26.0/tests/utils/weather_mocker.js
                MagicMirror-2.26.0/translations/
                MagicMirror-2.26.0/translations/af.json
                MagicMirror-2.26.0/translations/bg.json
                MagicMirror-2.26.0/translations/ca.json
                MagicMirror-2.26.0/translations/cs.json
                MagicMirror-2.26.0/translations/cv.json
                MagicMirror-2.26.0/translations/cy.json
                MagicMirror-2.26.0/translations/da.json
                MagicMirror-2.26.0/translations/de.json
                MagicMirror-2.26.0/translations/el.json
                MagicMirror-2.26.0/translations/en.json
                MagicMirror-2.26.0/translations/es.json
                MagicMirror-2.26.0/translations/et.json
                MagicMirror-2.26.0/translations/fi.json
                MagicMirror-2.26.0/translations/fr.json
                MagicMirror-2.26.0/translations/fy.json
                MagicMirror-2.26.0/translations/gl.json
                MagicMirror-2.26.0/translations/gu.json
                MagicMirror-2.26.0/translations/he.json
                MagicMirror-2.26.0/translations/hi.json
                MagicMirror-2.26.0/translations/hr.json
                MagicMirror-2.26.0/translations/hu.json
                MagicMirror-2.26.0/translations/id.json
                MagicMirror-2.26.0/translations/is.json
                MagicMirror-2.26.0/translations/it.json
                MagicMirror-2.26.0/translations/ja.json
                MagicMirror-2.26.0/translations/ko.json
                MagicMirror-2.26.0/translations/lt.json
                MagicMirror-2.26.0/translations/ms-my.json
                MagicMirror-2.26.0/translations/nb.json
                MagicMirror-2.26.0/translations/nl.json
                MagicMirror-2.26.0/translations/nn.json
                MagicMirror-2.26.0/translations/pl.json
                MagicMirror-2.26.0/translations/ps.json
                MagicMirror-2.26.0/translations/pt-br.json
                MagicMirror-2.26.0/translations/pt.json
                MagicMirror-2.26.0/translations/ro.json
                MagicMirror-2.26.0/translations/ru.json
                MagicMirror-2.26.0/translations/sk.json
                MagicMirror-2.26.0/translations/sv.json
                MagicMirror-2.26.0/translations/th.json
                MagicMirror-2.26.0/translations/tlh.json
                MagicMirror-2.26.0/translations/tr.json
                MagicMirror-2.26.0/translations/translations.js
                MagicMirror-2.26.0/translations/uk.json
                MagicMirror-2.26.0/translations/zh-cn.json
                MagicMirror-2.26.0/translations/zh-tw.json
                MagicMirror-2.26.0/vendor/
                MagicMirror-2.26.0/vendor/css/
                MagicMirror-2.26.0/vendor/css/font-awesome.css
                MagicMirror-2.26.0/vendor/package-lock.json
                MagicMirror-2.26.0/vendor/package.json
                MagicMirror-2.26.0/vendor/vendor.js
                ---Looking for new modules to install---
                ---Updating all modules---
                ---Updating 'MMM-CalendarExt3'---
                hint: Pulling without specifying how to reconcile divergent branches is
                hint: discouraged. You can squelch this message by running one of the following
                hint: commands sometime before your next pull:
                hint:
                hint:   git config pull.rebase false  # merge (the default strategy)
                hint:   git config pull.rebase true   # rebase
                hint:   git config pull.ff only       # fast-forward only
                hint:
                hint: You can replace "git config" with "git config --global" to set a default
                hint: preference for all repositories. You can also pass --rebase, --no-rebase,
                hint: or --ff-only on the command line to override the configured default per
                hint: invocation.
                Already up to date.
                Wrote to /magicmirror2/modules/MMM-CalendarExt3/package.json:
                  "name": "mmm-calendarext3",
                  "version": "1.8.1",
                  "description": "MagicMirror module for calendar view",
                  "main": "MMM-CalendarExt3.js",
                  "scripts": {
                    "test": "echo \"Error: no test specified\" && exit 1",
                    "postinstall": "git submodule update --init --recursive",
                    "postupdate": "git submodule update --init --recursive"
                  "repository": {
                    "type": "git",
                    "url": "git+https://github.com/MMRIZE/MMM-CalendarExt3.git"
                  "keywords": [
                    "MM",
                    "MagicMirror",
                    "calendar",
                    "CALEXT3"
                  "author": "eouia0819@gmail.com",
                  "license": "MIT",
                  "bugs": {
                    "url": "https://github.com/MMRIZE/MMM-CalendarExt3/issues"
                  "homepage": "https://github.com/MMRIZE/MMM-CalendarExt3#readme",
                  "directories": {
                    "example": "example"
                  "dependencies": {
                    "request": "^2.88.2"
                  "devDependencies": {}
                up to date, audited 48 packages in 1s
                2 packages are looking for funding
                  run `npm fund` for details
                2 moderate severity vulnerabilities
                Some issues need review, and may require choosing
                a different dependency.
                Run `npm audit` for details.
                npm notice
                npm notice New minor version of npm available! 10.2.3 -> 10.5.0
                npm notice Changelog: <https://github.com/npm/cli/releases/tag/v10.5.0>
                npm notice Run `npm install -g npm@10.5.0` to update!
                npm notice
                ---Installing, this can take some time please stand by...---
                > magicmirror@2.26.0 postinstall
                > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                > magicmirror@2.26.0 install-vendor
                > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                added 10 packages in 4s
                > magicmirror@2.26.0 install-fonts
                > echo "Installing fonts ...
                > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                added 2 packages in 2s
                > magicmirror@2.26.0 prepare
                > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                fatal: not a git repository (or any parent up to mount point /)
                Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
                husky - git command not found, skipping install
                added 846 packages, and audited 847 packages in 39s
                196 packages are looking for funding
                3 moderate severity vulnerabilities
                To address all issues, run:
                  npm audit fix
                ---Preparing Server---
                ---Configuration file found!---
                ---Please wait, permissions are set, this can take some time...---
                ---Starting Server---
                > magicmirror@2.26.0 server
                > node ./serveronly
                [27.03.2024 11:27.12.269] [LOG]   Starting MagicMirror: v2.26.0
                [27.03.2024 11:27.12.272] [LOG]   Loading config ...
                [27.03.2024 11:27.12.276] [DEBUG] config template file not exists, no envsubst
                [27.03.2024 11:27.12.281] [LOG]   Loading module helpers ...
                [27.03.2024 11:27.12.471] [LOG]   Initializing new module helper ...
                [27.03.2024 11:27.12.471] [LOG]   Module helper loaded: calendar
                [27.03.2024 11:27.12.472] [LOG]   No helper found for module: MMM-CalendarExt3.
                [27.03.2024 11:27.12.473] [LOG]   All module helpers loaded.
                [27.03.2024 11:27.12.481] [LOG]   Starting server on port 8080 ...
                [27.03.2024 11:27.12.483] [WARN]  You're using a full whitelist configuration to allow for all IPs
                [27.03.2024 11:27.12.492] [LOG]   Server started ...
                [27.03.2024 11:27.12.492] [LOG]   Connecting socket for: calendar
                [27.03.2024 11:27.12.493] [LOG]   Starting node helper for: calendar
                [27.03.2024 11:27.12.493] [LOG]   Sockets connected & modules started ...
                Ready to go! Please point your browser to: http://0.0.0.0:8080
                [27.03.2024 11:27.26.666] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 3600000
                [27.03.2024 11:27.27.617] [INFO]  Calendar-Fetcher: Broadcasting 23 events from http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics.
                [27.03.2024 11:27.30.844] [LOG]   Use existing calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
                [27.03.2024 11:27.30.845] [INFO]  Calendar-Fetcher: Broadcasting 23 events from http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics.
                [27.03.2024 11:27.31.550] [INFO]  Calendar-Fetcher: Broadcasting 23 events from http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics.
                [27.03.2024 11:27.43.015] [LOG]   Use existing calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
                [27.03.2024 11:27.43.015] [INFO]  Calendar-Fetcher: Broadcasting 23 events from http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics.
                [27.03.2024 11:27.43.719] [INFO]  Calendar-Fetcher: Broadcasting 23 events from http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics.
                  MMRIZE @flemmingss
                  @flemmingss
                  I copied your config and test works.
                  To check whether there is issue;
                  • Open the front-end dev-console in the browser (Ctrl+Shift+i) and see the console tab, find any suspicious issue.
                  • Or install MMM-LogExt to record the front-end logs into the backend log.
                  F 1 Reply Last reply
                  • F
                    flemmingss @MMRIZE
                    @MMRIZE
                      MMRIZE @flemmingss
                      @flemmingss
                      You may still need to complete the installation of the module. You may have missed these instructions on installation;
                      npm install
                      Or, you are using Docker, and for some reason, css/custom.css and modules/MMM-CalendarExt3/CX3_Shared/CX3_Shared.mjs seems not being loaded. I’m not familiar with Docker so not sure.
                      • F
                        flemmingss @MMRIZE
                        @MMRIZE
                        Hmm, these commands di not solve anyhing.
                        To be more accurate, I am running this on UnRAID with this image: https://hub.docker.com/r/ich777/magic-mirror2
                        The modules are installed by entering the URL in a text-file “magicmirror2\modules\modules.txt”.
                        # Paste the links from the git repository wich you want to install here.
                        # The Y or N is the indication if the module needs 'npm install' to work.
                        # Also you can delete the # in front of any line below to install a module
                        # from the corresponding github repository (please don't delete the last line).
                        N https://github.com/MMRIZE/MMM-LogExt
                        Y https://github.com/MMRIZE/MMM-CalendarExt3.git
                        #Y https://github.com/ItayXD/MMM-Admin-Interface.git
                        #N https://github.com/werthdavid/MMM-BurnIn.git
                        #N https://github.com/barnabycolby/MMM-Carousel
                        #N https://github.com/Toreke/MMM-Dynamic-Modules.git
                        #N https://github.com/Kreshnik/MMM-JokeAPI.git
                        #Y https://github.com/slametps/MMM-NetworkConnection.git
                        #Y https://github.com/PoOwAa/MMM-network-signal.git
                        #N https://github.com/glitch452/MMM-ViewNotifications.git
                        #N https://github.com/ulrichwisser/MMM-HTMLSnippet
                        #Y https://github.com/eouia/MMM-AVStock
                        #N https://github.com/jeroenpeters1986/MMM-bitcoin-portfolio.git
                        #Y https://github.com/Elaniobro/MMM-stocks.git
                        #N https://github.com/rehne/MMM-Ecosia-Tree-Counter.git
                        #N https://github.com/amcolash/MMM-GoogleFit.git
                        #Y https://github.com/eouia/MMM-News
                        #Y https://github.com/pinsdorf/MMM-WeeklySchedule.git
                        #N https://github.com/mihairinzis/MMM-wiki
                        #Y https://github.com/Jopyth/MMM-Remote-Control.git
                        #Y https://github.com/ronny3050/phone-notification-mirror.git
                        #Y https://github.com/ianperrin/MMM-Strava.git
                        #N https://github.com/PtrBld/MMM-Scrobbler.git
                        #N https://github.com/MitchSS/MMM-Hue.git
                        # Don't delete this line!
                        It it is for any helt, this is the content of my MMM-CalendarExt3 module folder
                        https://fastupload.io/0UNy4rcEJ3b4nrI/file
                          MMRIZE @flemmingss
                          @flemmingss
                          Your RAR is not downloadable by security issue. Anyway, is there CX3_Shared/CX3_Shared.mjs in position? Your error log says it is not accessible on your system.
                          • F
                            flemmingss @MMRIZE
                            @MMRIZE
                            The “CX3_Shared” folder is empty, maybe that one is missing somthing?
                            Yo can try this: https://nextcloud.flemmingss.top/s/QBE24rBABaao7ci
                            karsten13K 1 Reply Last reply
                            • karsten13K
                              karsten13 @flemmingss
                              @flemmingss said in MMM-CalendarExt3:
                              this is the problem which is caused by the strange installation procedure in the used docker image.
                              The module installation is done via
                              npm init -y
                              npm install request --save
                              You have to ask the author of this script why he is doing this.
                              With this construction the postinstall/postupgrade scripts defined in the package,json of MMM-CalendarExt3 are never called so the CX3_Shared folder is empty.
                              • F
                                flemmingss @karsten13
                                @karsten13
                                Looks like your right, I did the install procedure manual inside the docker container and it is working like it should :D
                                Thanks for your help, I will inform the container developer about this issue.
                                root@413f2db9a7a6:/tmp# cd ..
                                root@413f2db9a7a6:/# cd magicmirror2/modules
                                root@413f2db9a7a6:/magicmirror2/modules# git clone https://github.com/MMRIZE/MMM-CalendarExt3
                                Cloning into 'MMM-CalendarExt3'...
                                remote: Enumerating objects: 301, done.
                                remote: Counting objects: 100% (117/117), done.
                                remote: Compressing objects: 100% (62/62), done.
                                remote: Total 301 (delta 65), reused 81 (delta 54), pack-reused 184
                                Receiving objects: 100% (301/301), 119.61 KiB | 1.21 MiB/s, done.
                                Resolving deltas: 100% (170/170), done.
                                root@413f2db9a7a6:/magicmirror2/modules# cd MMM-CalendarExt3
                                root@413f2db9a7a6:/magicmirror2/modules/MMM-CalendarExt3# npm install
                                > mmm-calendarext3@1.8.1 postinstall
                                Submodule 'CX3_Shared' (https://github.com/MMRIZE/CX3_Shared) registered for path 'CX3_Shared'
                                Cloning into '/magicmirror2/modules/MMM-CalendarExt3/CX3_Shared'...
                                Submodule path 'CX3_Shared': checked out '44c7176e2b79a12e76badb78a49455bd7fbb22e3'
                                up to date, audited 1 package in 2s
                                found 0 vulnerabilities
                                npm notice
                                npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.5.0
                                npm notice Run npm install -g npm@10.5.0 to update!
                                npm notice
                                root@413f2db9a7a6:/magicmirror2/modules/MMM-CalendarExt3# git submodule update --init --recursive
                                EDIT: Github issue: https://github.com/ich777/docker-magicmirror2/issues/4
                                • bugsounetB bugsounet referenced this topic on
                                • F
                                  flemmingss
                                  okay, new issue, I have gotten this working, but not with past days. I see events from now and forward, but nothing before, even if I have enabled broadcastPastEvents.
                                  /* Magic Mirror Config Sample
                                   * MIT Licensed.
                                  var config = {
                                  	address: "0.0.0.0", // Address to listen on, can be:
                                  	port: 8080,
                                  	ipWhitelist: [], // Set [] to allow all IP addresses
                                  	language: "no",
                                  	timeFormat: 24,
                                  	units: "metric",
                                  	serverOnly:  "true" ,
                                  			     // false, default for all  NON-armv6l devices
                                  			module: "alert",
                                  		//	position: "top_left", 					**Hide this module**
                                  						symbol: "calendar-check",
                                  						color: "cyan",
                                  						url: "https://calendar.google.com/calendar/ical/xxx%40group.calendar.google.com/private-xxx/basic.ics" //felles
                                  						color: "red",
                                  			title: "Kalender",
                                  			config:
                                  				//mode: "month",
                                  				useMarquee: true, //animasjon for å se hele teksten
                                  EDIT: Looks like the calendar settings did not refresh until i rebooted my system, working now
                                    MMRIZE @flemmingss
                                    @flemmingss
                                    Set enough ‘maximumEntries’, ‘maximumNumberOfDays’ and ‘pastDaysCount’ of the default calendar.
                                    • F
                                      flemmingss @MMRIZE
                                      @MMRIZE Tested that, and did not work, but when I rebooted the service, it worked. So these settings must need a restart somehow.
                                        sdetweil @flemmingss
                                        @flemmingss yes, the fetcher is started once, the web page can be refreshed, but the fetcher does not restart.
                                        W 1 Reply Last reply
                                        • W
                                          Welle05 @sdetweil
                                          Problem with full day events since summer time in Germany.
                                          Full-day events which are part of a series are now spawn over two days. All series were built in winter time. I checked the original (google) Calendar : fine, also the Standard Calendar Module, but when it comes to Ext3 there are shown like this:
                                          single full dayevents (not part of a series): fine
                                          serial events with start date: also fine
                                          Any idea?
                                          Best regards
                                          Chris
                                          • F
                                            fedale @Welle05
                                            @Welle05 have you found a solution for this? i have the same issue in Sweden.
                                            And it´s only for fullday events.
                                            S M 2 Replies Last reply
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 34
                                            • 35
                                            • 25 / 35
