    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
      princemaxwell @sdetweil
      No problem, i removed fragments from the share link and named them like my list above, sorted by size, cal-8 is the smallest filesize.
      > magicmirror@2.26.0 start
      [20.03.2024 15:28.52.845] [LOG]   Starting MagicMirror: v2.26.0
      [20.03.2024 15:28.52.851] [LOG]   Loading config ...
      [20.03.2024 15:28.52.856] [DEBUG] config template file not exists, no envsubst
      [20.03.2024 15:28.52.862] [LOG]   Loading module helpers ...
      [20.03.2024 15:28.52.864] [LOG]   No helper found for module: alert.
      [20.03.2024 15:28.52.898] [LOG]   Initializing new module helper ...
      [20.03.2024 15:28.52.898] [LOG]   Module helper loaded: updatenotification
      [20.03.2024 15:28.52.900] [LOG]   No helper found for module: clock.
      [20.03.2024 15:28.53.231] [LOG]   Initializing new module helper ...
      [20.03.2024 15:28.53.232] [LOG]   Module helper loaded: calendar
      [20.03.2024 15:28.53.234] [LOG]   No helper found for module: MMM-CalendarExt3.
      [20.03.2024 15:28.53.235] [LOG]   All module helpers loaded.
      [20.03.2024 15:28.53.244] [LOG]   Starting server on port 8080 ...
      [20.03.2024 15:28.53.275] [LOG]   Server started ...
      [20.03.2024 15:28.53.278] [LOG]   Connecting socket for: updatenotification
      [20.03.2024 15:28.53.280] [LOG]   Starting module helper: updatenotification
      [20.03.2024 15:28.53.281] [LOG]   Connecting socket for: calendar
      [20.03.2024 15:28.53.282] [LOG]   Starting node helper for: calendar
      [20.03.2024 15:28.53.283] [LOG]   Sockets connected & modules started ...
      [20.03.2024 15:28.53.918] [LOG]   Launching application.
      [20.03.2024 15:28.57.031] [LOG]   Create new calendarfetcher for url: https://p63-caldav.icloud.com/published/2/MTA-cal-2 - Interval: 3600000
      [20.03.2024 15:28.57.194] [LOG]   Create new calendarfetcher for url: https://p63-caldav.icloud.com/published/2/MTA-cal-4 - Interval: 3600000
      [20.03.2024 15:28.57.198] [LOG]   Create new calendarfetcher for url: https://p63-caldav.icloud.com/published/2/MTA-cal-3 - Interval: 3600000
      [20.03.2024 15:28.57.201] [LOG]   Create new calendarfetcher for url: https://p29-caldav.icloud.com/published/2/ODA-cal-1 - Interval: 3600000
      [20.03.2024 15:28.57.205] [LOG]   Create new calendarfetcher for url: https://p63-caldav.icloud.com/published/2/MTA-cal-5 - Interval: 3600000
      [20.03.2024 15:28.57.208] [LOG]   Create new calendarfetcher for url: https://i.cal.to/ical/3/borussiadortmund/bundesliga-spielplan/cal-6.ics - Interval: 3600000
      [20.03.2024 15:28.57.217] [LOG]   Create new calendarfetcher for url: https://i.cal.to/ical/77/nrw/ferien/cal-8.ics - Interval: 3600000
      [20.03.2024 15:28.57.221] [LOG]   Create new calendarfetcher for url: https://i.cal.to/ical/61/nrw/feiertage/cal-7.ics - Interval: 3600000
      [20.03.2024 15:28.57.224] [INFO]  updatenotification: Updater Class Loaded!
      [20.03.2024 15:28.57.225] [INFO]  updatenotification: Checking PM2 using...
      [20.03.2024 15:28.57.227] [INFO]  Checking git for module: MMM-CalendarExt3
      [20.03.2024 15:28.57.290] [INFO]  Checking git for module: MagicMirror
      [20.03.2024 15:28.57.729] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://i.cal.to/ical/61/nrw/feiertage/cal-7.ics.
      [20.03.2024 15:28.57.825] [INFO]  Calendar-Fetcher: Broadcasting 1 events from https://i.cal.to/ical/77/nrw/ferien/cal-8.ics.
      [20.03.2024 15:28.59.069] [INFO]  Calendar-Fetcher: Broadcasting 5 events from https://i.cal.to/ical/3/borussiadortmund/bundesliga-spielplan/cal-6.ics.
      [20.03.2024 15:29.00.814] [INFO]  Calendar-Fetcher: Broadcasting 4 events from https://p63-caldav.icloud.com/published/2/MTA-cal-5.
      [20.03.2024 15:29.00.869] [INFO]  updatenotification: You are using pm2 with MagicMirror
      [20.03.2024 15:29.02.223] [INFO]  Calendar-Fetcher: Broadcasting 1 events from https://p63-caldav.icloud.com/published/2/MTA-cal-4.
      [20.03.2024 15:29.04.265] [INFO]  Calendar-Fetcher: Broadcasting 7 events from https://p63-caldav.icloud.com/published/2/MTA-cal-3.
      [20.03.2024 15:29.49.438] [INFO]  Calendar-Fetcher: Broadcasting 8 events from https://p63-caldav.icloud.com/published/2/MTA-cal-2.
      [20.03.2024 15:30.30.417] [INFO]  Calendar-Fetcher: Broadcasting 12 events from https://p29-caldav.icloud.com/published/2/ODA-cal-1.
        MMRIZE @princemaxwell
        @princemaxwell
        Now I know what happens. Your symptom is not related with any errors.
        Let me explain the process.
        1. Each calendar parsing/fetching in the calendar module will take some time, a few seconds or some dozen seconds. How long will it take is unpredictable.
        2. The default calendar module will refresh itself and broadcast accumulated events on any calendar fetched. So, in some unlucky cases, the module may flicker due to too-short-term refreshing.
        3. CX3’s view is very complex and heavy for redrawing frequently. To avoid that flickering, CX3 will wait some time after any broadcasted event arrives (waitFetch: 5000ms by default) to check whether the following broadcasting will arrive in the short term. If no other followed broadcasting happens, stop waiting and process collected events at that moment and draw the view.
        4. This means that if you have 8 calendars and 5 calendars complete fetching in 4 seconds and the other 3 calendars may take over 10 seconds, only the events from the earlier 5 calendars will be collected and prepared to show before the first rendering time(waitFetch 5000ms).
        5. After the first rendering, the remaining 3 calendars may complete fetching. CX3 receives those events but does not render them instantly to avoid flickering. The rendering will be done every refreshInterval (by default 10 minutes) with stocked events that are received during that period.
        6. That is the reason why some of your calendars will be shown the first time, but others are applied after 10 minutes.
        So, you may have these options.
        1. Do nothing. Just wait 10 minutes; the lazy events will normally be applied to CX3 from the second refreshing cycle. Calendar events are not regarded as needing urgent, instant reflection. Your MM may stay on for a long time. Ten minutes after the first bootup will not be a big issue, and your family will not care.
        2. Or Give enough long waitFetch. Your log showed that almost 2 minute is needed to complete fetching 8 calendars entirely. waitFetch: 1000 * 60 * 2 may work. (The default value is 5000ms, not 300000) (This means you need 2 minutes before drawing the CX3 view at first time.)
        3. Or Give shorter refreshInterval to redraw and reflect the change of events. The default value is 1000 * 60 * 10 (10 minutes) But you can assign shorter. But 99.99% of refreshing will deal unchanged same events. So I think it is a kind of waste. Anyway, if you want instant reflection, give it shorter value.
          princemaxwell
          @MMRIZE
          All right, that makes complete sense.
          I understand that now.
          CX3 initially only recognizes broadcast events and does not know how many calendars are configured and waits until all of them have been processed.
          By the way, with the 300000 I meant the time from the default calendar, the “fetchInterval”, whose default value is: 300000 (5 minutes).
          I tried the 2nd option, unfortunately it doesn’t work, I set it to 1000 * 60 * 2, but it takes exactly 10 minutes.
          When and how often is waitFetch executed, just once? I would have expected CX3 to notice a broadcast and then update according to waitFetch.
            @princemaxwell
            waitFetch will be applied only to the very first broadcast notification. If you set waitFetch: 120000, this sequence will happen (I’ll assume the calendar module is described before CX3 in config.js)
            1. the calendar module starts the parsing of calendars.
            2. CX3 module starts. Library is loaded and the DOM is prepared. It is now ready to receive the events.
            3. The first calendars might complete its fetching. then calendar module will broadcast the events at that moment.
            4. CX3 receive the first broadcasted events. Wait 120000ms(2 minute) from that moment to get other lazy broadcasting coming.
            5. Other calendars might be fetched. But some might still need to be completed.
            6. Anyway, after 120000ms from the first broadcast, CX3 will draw the events that have arrived till then. (It means the view of CX3 is shown for the first time after at least 2 minutes from the boot)
            7. Then after 10minutes(refreshInterval), CX3 will refresh again. Maybe until then, all calendars would have been fetched.(I hope.)
            Anyway your log was showing the 1st calendar fetching as below;
            [20.03.2024 15:28.57.729] [INFO]  Calendar-Fetcher: Broadcasting 2 events from ...
            And the 8th fetching ;
            [20.03.2024 15:30.30.417] [INFO]  Calendar-Fetcher: Broadcasting 12 events from ...
            It takes 93 seconds to complete. So I think waitFetch: 120000 (120 seconds) would be enough; however, if there are still missing events, the possible reasons would be;
            1. It takes more than 120 seconds at that moment randomly to complete fetching of all calendars since first fetching,
            2. some calendars were too fast-fetched before CX3 was ready. so they were missed. (all modules are loaded and starts sequentially, so if you have certain number of modules, CX3 may not be ready until that moment.)
            Of course, you can adjust the order of modules in config, assign needed values of waitFetch and refreshInterval to show the entire events properly on the first boot time.
            But, my suggestion is,
            Just leave them and do nothing.
            After 10 minutes from the first bootup, everything will be OK. Your MM might be rebooted at midnight or in the morning on real-life usage. MM would stay turned on all day or for several days. So literally, nobody will care, even realize there had been some missing events on the bootup time. You don’t have to make an effort to solve this unworthy issue.
              princemaxwell @MMRIZE
              @MMRIZE
              The standards are absolutely sufficient for everyday use.
              But while I position the modules and adapt the CSS to my own wishes and test the functions of the modules, the long time is rather annoying and I wanted to shorten it.
              I have now activated the following config and restarted.
              I recorded the contents of the screen and looked at exactly when and what happened.
              		module: "MMM-CalendarExt3",
              		position: "middle_center",
              		disabled: false,
              		waitFetch: 1000 * 60 * 2,
              		refreshInterval: 1000 * 60 * 2,
              		module: "MMM-CalendarExt3Agenda",
              		position: "top_center",
              		disabled: false,
              		title: "Kalender",
              			instanceId: "basicCalendar",
              			locale: 'de',
              			firstDayOfWeek: 1,
              			startDayIndex: -1,
              			endDayIndex: 10,
              			calendarSet: []
              The result is that the config is ignored.
              • CX3 starts after the calendar module and displayed the first entries of the 3 small calendars as soon as they appeared.
              • CX3 only refreshes after 10 minutes. You can tell this by the display briefly disappearing and then fading in again. Then all entries are included.
              • CX3A also starts after the calendar module and also shows the entries of the 3 small calendars directly.
              • CX3A refreshes after 30 minutes (default?). Even then, all entries are included.
              Apparently waitFetch is ignored for both, otherwise, according to your explanation, the first entries would only appear after waitFetch. But these are there immediately as soon as the module has been loaded.
              Other configurations are also ignored. For example, I used this for testing:
              mode: ‘day’,
              But i only get the week view.
              When i change it in MMM-CalendarExt3.js, then it works.
              Why is the config ignored or what am I missing?
                @princemaxwell
                You did a simple mistake. Configuration parameters of the module should be placed inside of the module’s config:{}.
                  @MMRIZE
                  Oh no, that’s embarrassing. I completely overlooked that and of course it works now. So often you look at what the problem could be and just don’t see it.
                  Thank you very much for your help!
                  • F Offline
                    flemmingss
                    I can’t get this to work, just has this basic config, and it is just empty, got the orginal calender app to show the events, but can’t see anything in the MMM-CalendarExt3 module, just the name of the month “Mars”…
                    _
                    			//Removing this to hide default calendar module position: "top_left",
                    				broadcastPastEvents: true, // <= IMPORTANT to see past events
                    						name: "us_holiday", // <= RECOMMENDED to assign name
                    						color: "red", // <= RECOMMENDED to assign color
                    						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
                    		  position: "top_bar",
                    		  title: "Kalender",
                    		    mode: "month",
                    		    locale: 'no-NO', // Norwegian, ref https://www.localeplanet.com/java/no-NO/index.html
                    		    maxEventLines: 5,
                    		    firstDayOfWeek: 1,
                    docker start log:
                    text  error  warn  system  array  login
                    ---Ensuring UID: 99 matches user---
                    ---Ensuring GID: 100 matches user---
                    ---Setting umask to 000---
                    ---Checking for optional scripts---
                    ---No optional script found, continuing---
                    ---Taking ownership of data...---
                    ---Starting...---
                    ---Force Update enabled!---
                    v2.26.0.tar.gz      100%[===================>] 381.10K  --.-KB/s    in 0.1s
                    ---Successfully downloaded MagicMirror² v2.26.0!---
                    rm: refusing to remove '.' or '..' directory: skipping '/magicmirror2/.'
                    rm: refusing to remove '.' or '..' directory: skipping '/magicmirror2/..'
                    MagicMirror-2.26.0/
                    MagicMirror-2.26.0/.editorconfig
                    MagicMirror-2.26.0/.eslintignore
                    MagicMirror-2.26.0/.eslintrc.json
                    MagicMirror-2.26.0/.gitattributes
                    MagicMirror-2.26.0/.github/
                    MagicMirror-2.26.0/.github/CONTRIBUTING.md
                    MagicMirror-2.26.0/.github/FUNDING.yaml
                    MagicMirror-2.26.0/.github/ISSUE_TEMPLATE.md
                    MagicMirror-2.26.0/.github/PULL_REQUEST_TEMPLATE.md
                    MagicMirror-2.26.0/.github/codecov.yaml
                    MagicMirror-2.26.0/.github/dependabot.yaml
                    MagicMirror-2.26.0/.github/header.png
                    MagicMirror-2.26.0/.github/stale.yaml
                    MagicMirror-2.26.0/.github/workflows/
                    MagicMirror-2.26.0/.github/workflows/automated-tests.yaml
                    MagicMirror-2.26.0/.github/workflows/depsreview.yaml
                    MagicMirror-2.26.0/.github/workflows/enforce-pullrequest-rules.yaml
                    MagicMirror-2.26.0/.gitignore
                    MagicMirror-2.26.0/.husky/
                    MagicMirror-2.26.0/.husky/pre-commit
                    MagicMirror-2.26.0/.npmrc
                    MagicMirror-2.26.0/.prettierignore
                    MagicMirror-2.26.0/.prettierrc.json
                    MagicMirror-2.26.0/.stylelintrc.json
                    MagicMirror-2.26.0/CHANGELOG.md
                    MagicMirror-2.26.0/Collaboration.md
                    MagicMirror-2.26.0/LICENSE.md
                    MagicMirror-2.26.0/README.md
                    MagicMirror-2.26.0/clientonly/
                    MagicMirror-2.26.0/clientonly/index.js
                    MagicMirror-2.26.0/config/
                    MagicMirror-2.26.0/config/config.js.sample
                    MagicMirror-2.26.0/css/
                    MagicMirror-2.26.0/css/custom.css.sample
                    MagicMirror-2.26.0/css/main.css
                    MagicMirror-2.26.0/fonts/
                    MagicMirror-2.26.0/fonts/package-lock.json
                    MagicMirror-2.26.0/fonts/package.json
                    MagicMirror-2.26.0/fonts/roboto.css
                    MagicMirror-2.26.0/index.html
                    MagicMirror-2.26.0/installers/
                    MagicMirror-2.26.0/installers/mm.sh
                    MagicMirror-2.26.0/jest.config.js
                    MagicMirror-2.26.0/js/
                    MagicMirror-2.26.0/js/animateCSS.js
                    MagicMirror-2.26.0/js/app.js
                    MagicMirror-2.26.0/js/check_config.js
                    MagicMirror-2.26.0/js/class.js
                    MagicMirror-2.26.0/js/defaults.js
                    MagicMirror-2.26.0/js/deprecated.js
                    MagicMirror-2.26.0/js/electron.js
                    MagicMirror-2.26.0/js/loader.js
                    MagicMirror-2.26.0/js/logger.js
                    MagicMirror-2.26.0/js/main.js
                    MagicMirror-2.26.0/js/module.js
                    MagicMirror-2.26.0/js/node_helper.js
                    MagicMirror-2.26.0/js/server.js
                    MagicMirror-2.26.0/js/server_functions.js
                    MagicMirror-2.26.0/js/socketclient.js
                    MagicMirror-2.26.0/js/translator.js
                    MagicMirror-2.26.0/js/utils.js
                    MagicMirror-2.26.0/jsconfig.json
                    MagicMirror-2.26.0/module-types.ts
                    MagicMirror-2.26.0/modules/
                    MagicMirror-2.26.0/modules/default/
                    MagicMirror-2.26.0/modules/default/alert/
                    MagicMirror-2.26.0/modules/default/alert/README.md
                    MagicMirror-2.26.0/modules/default/alert/alert.js
                    MagicMirror-2.26.0/modules/default/alert/notificationFx.js
                    MagicMirror-2.26.0/modules/default/alert/styles/
                    MagicMirror-2.26.0/modules/default/alert/styles/center.css
                    MagicMirror-2.26.0/modules/default/alert/styles/left.css
                    MagicMirror-2.26.0/modules/default/alert/styles/notificationFx.css
                    MagicMirror-2.26.0/modules/default/alert/styles/right.css
                    MagicMirror-2.26.0/modules/default/alert/templates/
                    MagicMirror-2.26.0/modules/default/alert/templates/alert.njk
                    MagicMirror-2.26.0/modules/default/alert/templates/notification.njk
                    MagicMirror-2.26.0/modules/default/alert/translations/
                    MagicMirror-2.26.0/modules/default/alert/translations/bg.json
                    MagicMirror-2.26.0/modules/default/alert/translations/da.json
                    MagicMirror-2.26.0/modules/default/alert/translations/de.json
                    MagicMirror-2.26.0/modules/default/alert/translations/en.json
                    MagicMirror-2.26.0/modules/default/alert/translations/es.json
                    MagicMirror-2.26.0/modules/default/alert/translations/fr.json
                    MagicMirror-2.26.0/modules/default/alert/translations/hu.json
                    MagicMirror-2.26.0/modules/default/alert/translations/nl.json
                    MagicMirror-2.26.0/modules/default/alert/translations/ru.json
                    MagicMirror-2.26.0/modules/default/alert/translations/th.json
                    MagicMirror-2.26.0/modules/default/calendar/
                    MagicMirror-2.26.0/modules/default/calendar/README.md
                    MagicMirror-2.26.0/modules/default/calendar/calendar.css
                    MagicMirror-2.26.0/modules/default/calendar/calendar.js
                    MagicMirror-2.26.0/modules/default/calendar/calendarfetcher.js
                    MagicMirror-2.26.0/modules/default/calendar/calendarfetcherutils.js
                    MagicMirror-2.26.0/modules/default/calendar/calendarutils.js
                    MagicMirror-2.26.0/modules/default/calendar/debug.js
                    MagicMirror-2.26.0/modules/default/calendar/node_helper.js
                    MagicMirror-2.26.0/modules/default/calendar/windowsZones.json
                    MagicMirror-2.26.0/modules/default/clock/
                    MagicMirror-2.26.0/modules/default/clock/README.md
                    MagicMirror-2.26.0/modules/default/clock/clock.js
                    MagicMirror-2.26.0/modules/default/clock/clock_styles.css
                    MagicMirror-2.26.0/modules/default/clock/faces/
                    MagicMirror-2.26.0/modules/default/clock/faces/face-001.svg
                    MagicMirror-2.26.0/modules/default/clock/faces/face-002.svg
                    MagicMirror-2.26.0/modules/default/clock/faces/face-003.svg
                    MagicMirror-2.26.0/modules/default/clock/faces/face-004.svg
                    MagicMirror-2.26.0/modules/default/clock/faces/face-005.svg
                    MagicMirror-2.26.0/modules/default/clock/faces/face-006.svg
                    MagicMirror-2.26.0/modules/default/clock/faces/face-007.svg
                    MagicMirror-2.26.0/modules/default/clock/faces/face-008.svg
                    MagicMirror-2.26.0/modules/default/clock/faces/face-009.svg
                    MagicMirror-2.26.0/modules/default/clock/faces/face-010.svg
                    MagicMirror-2.26.0/modules/default/clock/faces/face-011.svg
                    MagicMirror-2.26.0/modules/default/clock/faces/face-012.svg
                    MagicMirror-2.26.0/modules/default/compliments/
                    MagicMirror-2.26.0/modules/default/compliments/README.md
                    MagicMirror-2.26.0/modules/default/compliments/compliments.js
                    MagicMirror-2.26.0/modules/default/defaultmodules.js
                    MagicMirror-2.26.0/modules/default/helloworld/
                    MagicMirror-2.26.0/modules/default/helloworld/README.md
                    MagicMirror-2.26.0/modules/default/helloworld/helloworld.js
                    MagicMirror-2.26.0/modules/default/helloworld/helloworld.njk
                    MagicMirror-2.26.0/modules/default/newsfeed/
                    MagicMirror-2.26.0/modules/default/newsfeed/README.md
                    MagicMirror-2.26.0/modules/default/newsfeed/fullarticle.njk
                    MagicMirror-2.26.0/modules/default/newsfeed/newsfeed.css
                    MagicMirror-2.26.0/modules/default/newsfeed/newsfeed.js
                    MagicMirror-2.26.0/modules/default/newsfeed/newsfeed.njk
                    MagicMirror-2.26.0/modules/default/newsfeed/newsfeedfetcher.js
                    MagicMirror-2.26.0/modules/default/newsfeed/node_helper.js
                    MagicMirror-2.26.0/modules/default/newsfeed/oldconfig.njk
                    MagicMirror-2.26.0/modules/default/updatenotification/
                    MagicMirror-2.26.0/modules/default/updatenotification/README.md
                    MagicMirror-2.26.0/modules/default/updatenotification/git_helper.js
                    MagicMirror-2.26.0/modules/default/updatenotification/node_helper.js
                    MagicMirror-2.26.0/modules/default/updatenotification/update_helper.js
                    MagicMirror-2.26.0/modules/default/updatenotification/updatenotification.css
                    MagicMirror-2.26.0/modules/default/updatenotification/updatenotification.js
                    MagicMirror-2.26.0/modules/default/updatenotification/updatenotification.njk
                    MagicMirror-2.26.0/modules/default/utils.js
                    MagicMirror-2.26.0/modules/default/weather/
                    MagicMirror-2.26.0/modules/default/weather/README.md
                    MagicMirror-2.26.0/modules/default/weather/current.njk
                    MagicMirror-2.26.0/modules/default/weather/forecast.njk
                    MagicMirror-2.26.0/modules/default/weather/hourly.njk
                    MagicMirror-2.26.0/modules/default/weather/providers/
                    MagicMirror-2.26.0/modules/default/weather/providers/README.md
                    MagicMirror-2.26.0/modules/default/weather/providers/envcanada.js
                    MagicMirror-2.26.0/modules/default/weather/providers/openmeteo.js
                    MagicMirror-2.26.0/modules/default/weather/providers/openweathermap.js
                    MagicMirror-2.26.0/modules/default/weather/providers/overrideWrapper.js
                    MagicMirror-2.26.0/modules/default/weather/providers/pirateweather.js
                    MagicMirror-2.26.0/modules/default/weather/providers/smhi.js
                    MagicMirror-2.26.0/modules/default/weather/providers/ukmetoffice.js
                    MagicMirror-2.26.0/modules/default/weather/providers/ukmetofficedatahub.js
                    MagicMirror-2.26.0/modules/default/weather/providers/weatherbit.js
                    MagicMirror-2.26.0/modules/default/weather/providers/weatherflow.js
                    MagicMirror-2.26.0/modules/default/weather/providers/weathergov.js
                    MagicMirror-2.26.0/modules/default/weather/providers/yr.js
                    MagicMirror-2.26.0/modules/default/weather/weather.css
                    MagicMirror-2.26.0/modules/default/weather/weather.js
                    MagicMirror-2.26.0/modules/default/weather/weatherobject.js
                    MagicMirror-2.26.0/modules/default/weather/weatherprovider.js
                    MagicMirror-2.26.0/modules/default/weather/weatherutils.js
                    MagicMirror-2.26.0/package-lock.json
                    MagicMirror-2.26.0/package.json
                    MagicMirror-2.26.0/serveronly/
                    MagicMirror-2.26.0/serveronly/index.js
                    MagicMirror-2.26.0/splashscreen/
                    MagicMirror-2.26.0/splashscreen/MagicMirror.plymouth
                    MagicMirror-2.26.0/splashscreen/MagicMirror.script
                    MagicMirror-2.26.0/splashscreen/splash.png
                    MagicMirror-2.26.0/splashscreen/splash_halt.png
                    MagicMirror-2.26.0/tests/
                    MagicMirror-2.26.0/tests/configs/
                    MagicMirror-2.26.0/tests/configs/default.js
                    MagicMirror-2.26.0/tests/configs/empty_ipWhiteList.js
                    MagicMirror-2.26.0/tests/configs/modules/
                    MagicMirror-2.26.0/tests/configs/modules/alert/
                    MagicMirror-2.26.0/tests/configs/modules/alert/default.js
                    MagicMirror-2.26.0/tests/configs/modules/calendar/
                    MagicMirror-2.26.0/tests/configs/modules/calendar/auth-default.js
                    MagicMirror-2.26.0/tests/configs/modules/calendar/bad_rrule.js
                    MagicMirror-2.26.0/tests/configs/modules/calendar/basic-auth.js
                    MagicMirror-2.26.0/tests/configs/modules/calendar/changed-port.js
                    MagicMirror-2.26.0/tests/configs/modules/calendar/custom.js
                    MagicMirror-2.26.0/tests/configs/modules/calendar/default.js
                    MagicMirror-2.26.0/tests/configs/modules/calendar/exdate.js
                    MagicMirror-2.26.0/tests/configs/modules/calendar/fail-basic-auth.js
                    MagicMirror-2.26.0/tests/configs/modules/calendar/old-basic-auth.js
                    MagicMirror-2.26.0/tests/configs/modules/calendar/recurring.js
                    MagicMirror-2.26.0/tests/configs/modules/calendar/show-duplicates-in-calendar.js
                    MagicMirror-2.26.0/tests/configs/modules/clock/
                    MagicMirror-2.26.0/tests/configs/modules/clock/clock_12hr.js
                    MagicMirror-2.26.0/tests/configs/modules/clock/clock_24hr.js
                    MagicMirror-2.26.0/tests/configs/modules/clock/clock_analog.js
                    MagicMirror-2.26.0/tests/configs/modules/clock/clock_displaySeconds_false.js
                    MagicMirror-2.26.0/tests/configs/modules/clock/clock_showDateAnalog.js
                    MagicMirror-2.26.0/tests/configs/modules/clock/clock_showPeriodUpper.js
                    MagicMirror-2.26.0/tests/configs/modules/clock/clock_showSunMoon.js
                    MagicMirror-2.26.0/tests/configs/modules/clock/clock_showTime.js
                    MagicMirror-2.26.0/tests/configs/modules/clock/clock_showWeek.js
                    MagicMirror-2.26.0/tests/configs/modules/clock/es/
                    MagicMirror-2.26.0/tests/configs/modules/clock/es/clock_12hr.js
                    MagicMirror-2.26.0/tests/configs/modules/clock/es/clock_24hr.js
                    MagicMirror-2.26.0/tests/configs/modules/clock/es/clock_showPeriodUpper.js
                    MagicMirror-2.26.0/tests/configs/modules/clock/es/clock_showWeek.js
                    MagicMirror-2.26.0/tests/configs/modules/compliments/
                    MagicMirror-2.26.0/tests/configs/modules/compliments/compliments_animateCSS.js
                    MagicMirror-2.26.0/tests/configs/modules/compliments/compliments_animateCSS_fallbackToDefault.js
                    MagicMirror-2.26.0/tests/configs/modules/compliments/compliments_animateCSS_invertedAnimationName.js
                    MagicMirror-2.26.0/tests/configs/modules/compliments/compliments_anytime.js
                    MagicMirror-2.26.0/tests/configs/modules/compliments/compliments_date.js
                    MagicMirror-2.26.0/tests/configs/modules/compliments/compliments_only_anytime.js
                    MagicMirror-2.26.0/tests/configs/modules/compliments/compliments_parts_day.js
                    MagicMirror-2.26.0/tests/configs/modules/compliments/compliments_remote.js
                    MagicMirror-2.26.0/tests/configs/modules/display.js
                    MagicMirror-2.26.0/tests/configs/modules/helloworld/
                    MagicMirror-2.26.0/tests/configs/modules/helloworld/helloworld.js
                    MagicMirror-2.26.0/tests/configs/modules/helloworld/helloworld_default.js
                    MagicMirror-2.26.0/tests/configs/modules/newsfeed/
                    MagicMirror-2.26.0/tests/configs/modules/newsfeed/default.js
                    MagicMirror-2.26.0/tests/configs/modules/newsfeed/ignore_items.js
                    MagicMirror-2.26.0/tests/configs/modules/newsfeed/incorrect_url.js
                    MagicMirror-2.26.0/tests/configs/modules/newsfeed/prohibited_words.js
                    MagicMirror-2.26.0/tests/configs/modules/positions.js
                    MagicMirror-2.26.0/tests/configs/modules/weather/
                    MagicMirror-2.26.0/tests/configs/modules/weather/currentweather_compliments.js
                    MagicMirror-2.26.0/tests/configs/modules/weather/currentweather_default.js
                    MagicMirror-2.26.0/tests/configs/modules/weather/currentweather_options.js
                    MagicMirror-2.26.0/tests/configs/modules/weather/currentweather_units.js
                    MagicMirror-2.26.0/tests/configs/modules/weather/forecastweather_absolute.js
                    MagicMirror-2.26.0/tests/configs/modules/weather/forecastweather_default.js
                    MagicMirror-2.26.0/tests/configs/modules/weather/forecastweather_options.js
                    MagicMirror-2.26.0/tests/configs/modules/weather/forecastweather_units.js
                    MagicMirror-2.26.0/tests/configs/modules/weather/hourlyweather_default.js
                    MagicMirror-2.26.0/tests/configs/modules/weather/hourlyweather_options.js
                    MagicMirror-2.26.0/tests/configs/modules/weather/hourlyweather_showPrecipitation.js
                    MagicMirror-2.26.0/tests/configs/noIpWhiteList.js
                    MagicMirror-2.26.0/tests/configs/port_8090.js
                    MagicMirror-2.26.0/tests/configs/port_variable.env
                    MagicMirror-2.26.0/tests/configs/port_variable.js.template
                    MagicMirror-2.26.0/tests/configs/without_modules.js
                    MagicMirror-2.26.0/tests/e2e/
                    MagicMirror-2.26.0/tests/e2e/animateCSS_spec.js
                    MagicMirror-2.26.0/tests/e2e/env_spec.js
                    MagicMirror-2.26.0/tests/e2e/fonts_spec.js
                    MagicMirror-2.26.0/tests/e2e/helpers/
                    MagicMirror-2.26.0/tests/e2e/helpers/basic-auth.js
                    MagicMirror-2.26.0/tests/e2e/helpers/global-setup.js
                    MagicMirror-2.26.0/tests/e2e/helpers/mock-console.js
                    MagicMirror-2.26.0/tests/e2e/helpers/weather-functions.js
                    MagicMirror-2.26.0/tests/e2e/ipWhitelist_spec.js
                    MagicMirror-2.26.0/tests/e2e/modules/
                    MagicMirror-2.26.0/tests/e2e/modules/alert_spec.js
                    MagicMirror-2.26.0/tests/e2e/modules/calendar_spec.js
                    MagicMirror-2.26.0/tests/e2e/modules/clock_es_spec.js
                    MagicMirror-2.26.0/tests/e2e/modules/clock_spec.js
                    MagicMirror-2.26.0/tests/e2e/modules/compliments_spec.js
                    MagicMirror-2.26.0/tests/e2e/modules/helloworld_spec.js
                    MagicMirror-2.26.0/tests/e2e/modules/newsfeed_spec.js
                    MagicMirror-2.26.0/tests/e2e/modules/weather_current_spec.js
                    MagicMirror-2.26.0/tests/e2e/modules/weather_forecast_spec.js
                    MagicMirror-2.26.0/tests/e2e/modules/weather_hourly_spec.js
                    MagicMirror-2.26.0/tests/e2e/modules_display_spec.js
                    MagicMirror-2.26.0/tests/e2e/modules_empty_spec.js
                    MagicMirror-2.26.0/tests/e2e/modules_position_spec.js
                    MagicMirror-2.26.0/tests/e2e/port_spec.js
                    MagicMirror-2.26.0/tests/e2e/serveronly_spec.js
                    MagicMirror-2.26.0/tests/e2e/template_spec.js
                    MagicMirror-2.26.0/tests/e2e/translations_spec.js
                    MagicMirror-2.26.0/tests/e2e/vendor_spec.js
                    MagicMirror-2.26.0/tests/electron/
                    MagicMirror-2.26.0/tests/electron/env_spec.js
                    MagicMirror-2.26.0/tests/electron/helpers/
                    MagicMirror-2.26.0/tests/electron/helpers/global-setup.js
                    MagicMirror-2.26.0/tests/electron/helpers/weather-setup.js
                    MagicMirror-2.26.0/tests/electron/modules/
                    MagicMirror-2.26.0/tests/electron/modules/calendar_spec.js
                    MagicMirror-2.26.0/tests/electron/modules/compliments_spec.js
                    MagicMirror-2.26.0/tests/electron/modules/weather_spec.js
                    MagicMirror-2.26.0/tests/mocks/
                    MagicMirror-2.26.0/tests/mocks/bad_rrule.ics
                    MagicMirror-2.26.0/tests/mocks/calendar_test.ics
                    MagicMirror-2.26.0/tests/mocks/calendar_test_clone.ics
                    MagicMirror-2.26.0/tests/mocks/calendar_test_exdate.ics
                    MagicMirror-2.26.0/tests/mocks/calendar_test_icons.ics
                    MagicMirror-2.26.0/tests/mocks/calendar_test_recurring.ics
                    MagicMirror-2.26.0/tests/mocks/compliments_test.json
                    MagicMirror-2.26.0/tests/mocks/newsfeed_test.xml
                    MagicMirror-2.26.0/tests/mocks/translation_test.json
                    MagicMirror-2.26.0/tests/mocks/weather_current.json
                    MagicMirror-2.26.0/tests/mocks/weather_forecast.json
                    MagicMirror-2.26.0/tests/mocks/weather_hourly.json
                    MagicMirror-2.26.0/tests/unit/
                    MagicMirror-2.26.0/tests/unit/classes/
                    MagicMirror-2.26.0/tests/unit/classes/class_spec.js
                    MagicMirror-2.26.0/tests/unit/classes/deprecated_spec.js
                    MagicMirror-2.26.0/tests/unit/classes/translator_spec.js
                    MagicMirror-2.26.0/tests/unit/classes/utils_spec.js
                    MagicMirror-2.26.0/tests/unit/functions/
                    MagicMirror-2.26.0/tests/unit/functions/__snapshots__/
                    MagicMirror-2.26.0/tests/unit/functions/__snapshots__/updatenotification_spec.js.snap
                    MagicMirror-2.26.0/tests/unit/functions/cmp_versions_spec.js
                    MagicMirror-2.26.0/tests/unit/functions/server_functions_spec.js
                    MagicMirror-2.26.0/tests/unit/functions/updatenotification_spec.js
                    MagicMirror-2.26.0/tests/unit/global_vars/
                    MagicMirror-2.26.0/tests/unit/global_vars/defaults_modules_spec.js
                    MagicMirror-2.26.0/tests/unit/global_vars/root_path_spec.js
                    MagicMirror-2.26.0/tests/unit/helpers/
                    MagicMirror-2.26.0/tests/unit/helpers/global-setup.js
                    MagicMirror-2.26.0/tests/unit/modules/
                    MagicMirror-2.26.0/tests/unit/modules/default/
                    MagicMirror-2.26.0/tests/unit/modules/default/calendar/
                    MagicMirror-2.26.0/tests/unit/modules/default/calendar/calendar_fetcher_utils_bad_rrule.js
                    MagicMirror-2.26.0/tests/unit/modules/default/calendar/calendar_fetcher_utils_spec.js
                    MagicMirror-2.26.0/tests/unit/modules/default/calendar/calendar_utils_spec.js
                    MagicMirror-2.26.0/tests/unit/modules/default/utils_spec.js
                    MagicMirror-2.26.0/tests/unit/modules/default/weather/
                    MagicMirror-2.26.0/tests/unit/modules/default/weather/weather_object_spec.js
                    MagicMirror-2.26.0/tests/unit/modules/default/weather/weather_utils_spec.js
                    MagicMirror-2.26.0/tests/utils/
                    MagicMirror-2.26.0/tests/utils/test_sequencer.js
                    MagicMirror-2.26.0/tests/utils/weather_mocker.js
                    MagicMirror-2.26.0/translations/
                    MagicMirror-2.26.0/translations/af.json
                    MagicMirror-2.26.0/translations/bg.json
                    MagicMirror-2.26.0/translations/ca.json
                    MagicMirror-2.26.0/translations/cs.json
                    MagicMirror-2.26.0/translations/cv.json
                    MagicMirror-2.26.0/translations/cy.json
                    MagicMirror-2.26.0/translations/da.json
                    MagicMirror-2.26.0/translations/de.json
                    MagicMirror-2.26.0/translations/el.json
                    MagicMirror-2.26.0/translations/en.json
                    MagicMirror-2.26.0/translations/es.json
                    MagicMirror-2.26.0/translations/et.json
                    MagicMirror-2.26.0/translations/fi.json
                    MagicMirror-2.26.0/translations/fr.json
                    MagicMirror-2.26.0/translations/fy.json
                    MagicMirror-2.26.0/translations/gl.json
                    MagicMirror-2.26.0/translations/gu.json
                    MagicMirror-2.26.0/translations/he.json
                    MagicMirror-2.26.0/translations/hi.json
                    MagicMirror-2.26.0/translations/hr.json
                    MagicMirror-2.26.0/translations/hu.json
                    MagicMirror-2.26.0/translations/id.json
                    MagicMirror-2.26.0/translations/is.json
                    MagicMirror-2.26.0/translations/it.json
                    MagicMirror-2.26.0/translations/ja.json
                    MagicMirror-2.26.0/translations/ko.json
                    MagicMirror-2.26.0/translations/lt.json
                    MagicMirror-2.26.0/translations/ms-my.json
                    MagicMirror-2.26.0/translations/nb.json
                    MagicMirror-2.26.0/translations/nl.json
                    MagicMirror-2.26.0/translations/nn.json
                    MagicMirror-2.26.0/translations/pl.json
                    MagicMirror-2.26.0/translations/ps.json
                    MagicMirror-2.26.0/translations/pt-br.json
                    MagicMirror-2.26.0/translations/pt.json
                    MagicMirror-2.26.0/translations/ro.json
                    MagicMirror-2.26.0/translations/ru.json
                    MagicMirror-2.26.0/translations/sk.json
                    MagicMirror-2.26.0/translations/sv.json
                    MagicMirror-2.26.0/translations/th.json
                    MagicMirror-2.26.0/translations/tlh.json
                    MagicMirror-2.26.0/translations/tr.json
                    MagicMirror-2.26.0/translations/translations.js
                    MagicMirror-2.26.0/translations/uk.json
                    MagicMirror-2.26.0/translations/zh-cn.json
                    MagicMirror-2.26.0/translations/zh-tw.json
                    MagicMirror-2.26.0/vendor/
                    MagicMirror-2.26.0/vendor/css/
                    MagicMirror-2.26.0/vendor/css/font-awesome.css
                    MagicMirror-2.26.0/vendor/package-lock.json
                    MagicMirror-2.26.0/vendor/package.json
                    MagicMirror-2.26.0/vendor/vendor.js
                    ---Looking for new modules to install---
                    ---Updating all modules---
                    ---Updating 'MMM-CalendarExt3'---
                    hint: Pulling without specifying how to reconcile divergent branches is
                    hint: discouraged. You can squelch this message by running one of the following
                    hint: commands sometime before your next pull:
                    hint:
                    hint:   git config pull.rebase false  # merge (the default strategy)
                    hint:   git config pull.rebase true   # rebase
                    hint:   git config pull.ff only       # fast-forward only
                    hint:
                    hint: You can replace "git config" with "git config --global" to set a default
                    hint: preference for all repositories. You can also pass --rebase, --no-rebase,
                    hint: or --ff-only on the command line to override the configured default per
                    hint: invocation.
                    Already up to date.
                    Wrote to /magicmirror2/modules/MMM-CalendarExt3/package.json:
                      "name": "mmm-calendarext3",
                      "version": "1.8.1",
                      "description": "MagicMirror module for calendar view",
                      "main": "MMM-CalendarExt3.js",
                      "scripts": {
                        "test": "echo \"Error: no test specified\" && exit 1",
                        "postinstall": "git submodule update --init --recursive",
                        "postupdate": "git submodule update --init --recursive"
                      "repository": {
                        "type": "git",
                        "url": "git+https://github.com/MMRIZE/MMM-CalendarExt3.git"
                      "keywords": [
                        "MM",
                        "MagicMirror",
                        "calendar",
                        "CALEXT3"
                      "author": "eouia0819@gmail.com",
                      "license": "MIT",
                      "bugs": {
                        "url": "https://github.com/MMRIZE/MMM-CalendarExt3/issues"
                      "homepage": "https://github.com/MMRIZE/MMM-CalendarExt3#readme",
                      "directories": {
                        "example": "example"
                      "dependencies": {
                        "request": "^2.88.2"
                      "devDependencies": {}
                    up to date, audited 48 packages in 1s
                    2 packages are looking for funding
                      run `npm fund` for details
                    2 moderate severity vulnerabilities
                    Some issues need review, and may require choosing
                    a different dependency.
                    Run `npm audit` for details.
                    npm notice
                    npm notice New minor version of npm available! 10.2.3 -> 10.5.0
                    npm notice Changelog: <https://github.com/npm/cli/releases/tag/v10.5.0>
                    npm notice Run `npm install -g npm@10.5.0` to update!
                    npm notice
                    ---Installing, this can take some time please stand by...---
                    > magicmirror@2.26.0 postinstall
                    > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                    > magicmirror@2.26.0 install-vendor
                    > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                    added 10 packages in 4s
                    > magicmirror@2.26.0 install-fonts
                    > echo "Installing fonts ...
                    > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                    added 2 packages in 2s
                    > magicmirror@2.26.0 prepare
                    > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                    fatal: not a git repository (or any parent up to mount point /)
                    Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
                    husky - git command not found, skipping install
                    added 846 packages, and audited 847 packages in 39s
                    196 packages are looking for funding
                    3 moderate severity vulnerabilities
                    To address all issues, run:
                      npm audit fix
                    ---Preparing Server---
                    ---Configuration file found!---
                    ---Please wait, permissions are set, this can take some time...---
                    ---Starting Server---
                    > magicmirror@2.26.0 server
                    > node ./serveronly
                    [27.03.2024 11:27.12.269] [LOG]   Starting MagicMirror: v2.26.0
                    [27.03.2024 11:27.12.272] [LOG]   Loading config ...
                    [27.03.2024 11:27.12.276] [DEBUG] config template file not exists, no envsubst
                    [27.03.2024 11:27.12.281] [LOG]   Loading module helpers ...
                    [27.03.2024 11:27.12.471] [LOG]   Initializing new module helper ...
                    [27.03.2024 11:27.12.471] [LOG]   Module helper loaded: calendar
                    [27.03.2024 11:27.12.472] [LOG]   No helper found for module: MMM-CalendarExt3.
                    [27.03.2024 11:27.12.473] [LOG]   All module helpers loaded.
                    [27.03.2024 11:27.12.481] [LOG]   Starting server on port 8080 ...
                    [27.03.2024 11:27.12.483] [WARN]  You're using a full whitelist configuration to allow for all IPs
                    [27.03.2024 11:27.12.492] [LOG]   Server started ...
                    [27.03.2024 11:27.12.492] [LOG]   Connecting socket for: calendar
                    [27.03.2024 11:27.12.493] [LOG]   Starting node helper for: calendar
                    [27.03.2024 11:27.12.493] [LOG]   Sockets connected & modules started ...
                    Ready to go! Please point your browser to: http://0.0.0.0:8080
                    [27.03.2024 11:27.26.666] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 3600000
                    [27.03.2024 11:27.27.617] [INFO]  Calendar-Fetcher: Broadcasting 23 events from http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics.
                    [27.03.2024 11:27.30.844] [LOG]   Use existing calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
                    [27.03.2024 11:27.30.845] [INFO]  Calendar-Fetcher: Broadcasting 23 events from http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics.
                    [27.03.2024 11:27.31.550] [INFO]  Calendar-Fetcher: Broadcasting 23 events from http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics.
                    [27.03.2024 11:27.43.015] [LOG]   Use existing calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
                    [27.03.2024 11:27.43.015] [INFO]  Calendar-Fetcher: Broadcasting 23 events from http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics.
                    [27.03.2024 11:27.43.719] [INFO]  Calendar-Fetcher: Broadcasting 23 events from http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics.
                      MMRIZE @flemmingss
                      @flemmingss
                      I copied your config and test works.
                      To check whether there is issue;
                      • Open the front-end dev-console in the browser (Ctrl+Shift+i) and see the console tab, find any suspicious issue.
                      • Or install MMM-LogExt to record the front-end logs into the backend log.
                      • F Offline
                        flemmingss @MMRIZE
                        @MMRIZE
                          MMRIZE @flemmingss
                          @flemmingss
                          You may still need to complete the installation of the module. You may have missed these instructions on installation;
                          npm install
                          Or, you are using Docker, and for some reason, css/custom.css and modules/MMM-CalendarExt3/CX3_Shared/CX3_Shared.mjs seems not being loaded. I’m not familiar with Docker so not sure.
                          • F Offline
                            flemmingss @MMRIZE
                            @MMRIZE
                            Hmm, these commands di not solve anyhing.
                            To be more accurate, I am running this on UnRAID with this image: https://hub.docker.com/r/ich777/magic-mirror2
                            The modules are installed by entering the URL in a text-file “magicmirror2\modules\modules.txt”.
                            # Paste the links from the git repository wich you want to install here.
                            # The Y or N is the indication if the module needs 'npm install' to work.
                            # Also you can delete the # in front of any line below to install a module
                            # from the corresponding github repository (please don't delete the last line).
                            N https://github.com/MMRIZE/MMM-LogExt
                            Y https://github.com/MMRIZE/MMM-CalendarExt3.git
                            #Y https://github.com/ItayXD/MMM-Admin-Interface.git
                            #N https://github.com/werthdavid/MMM-BurnIn.git
                            #N https://github.com/barnabycolby/MMM-Carousel
                            #N https://github.com/Toreke/MMM-Dynamic-Modules.git
                            #N https://github.com/Kreshnik/MMM-JokeAPI.git
                            #Y https://github.com/slametps/MMM-NetworkConnection.git
                            #Y https://github.com/PoOwAa/MMM-network-signal.git
                            #N https://github.com/glitch452/MMM-ViewNotifications.git
                            #N https://github.com/ulrichwisser/MMM-HTMLSnippet
                            #Y https://github.com/eouia/MMM-AVStock
                            #N https://github.com/jeroenpeters1986/MMM-bitcoin-portfolio.git
                            #Y https://github.com/Elaniobro/MMM-stocks.git
                            #N https://github.com/rehne/MMM-Ecosia-Tree-Counter.git
                            #N https://github.com/amcolash/MMM-GoogleFit.git
                            #Y https://github.com/eouia/MMM-News
                            #Y https://github.com/pinsdorf/MMM-WeeklySchedule.git
                            #N https://github.com/mihairinzis/MMM-wiki
                            #Y https://github.com/Jopyth/MMM-Remote-Control.git
                            #Y https://github.com/ronny3050/phone-notification-mirror.git
                            #Y https://github.com/ianperrin/MMM-Strava.git
                            #N https://github.com/PtrBld/MMM-Scrobbler.git
                            #N https://github.com/MitchSS/MMM-Hue.git
                            # Don't delete this line!
                            It it is for any helt, this is the content of my MMM-CalendarExt3 module folder
                            https://fastupload.io/0UNy4rcEJ3b4nrI/file
                              MMRIZE @flemmingss
                              @flemmingss
                              Your RAR is not downloadable by security issue. Anyway, is there CX3_Shared/CX3_Shared.mjs in position? Your error log says it is not accessible on your system.
                              • F Offline
                                flemmingss @MMRIZE
                                @MMRIZE
                                The “CX3_Shared” folder is empty, maybe that one is missing somthing?
                                Yo can try this: https://nextcloud.flemmingss.top/s/QBE24rBABaao7ci
                                • karsten13K Offline
                                  karsten13 @flemmingss
                                  @flemmingss said in MMM-CalendarExt3:
                                  this is the problem which is caused by the strange installation procedure in the used docker image.
                                  The module installation is done via
                                  npm init -y
                                  npm install request --save
                                  You have to ask the author of this script why he is doing this.
                                  With this construction the postinstall/postupgrade scripts defined in the package,json of MMM-CalendarExt3 are never called so the CX3_Shared folder is empty.
                                  • F Offline
                                    flemmingss @karsten13
                                    @karsten13
                                    Looks like your right, I did the install procedure manual inside the docker container and it is working like it should :D
                                    Thanks for your help, I will inform the container developer about this issue.
                                    root@413f2db9a7a6:/tmp# cd ..
                                    root@413f2db9a7a6:/# cd magicmirror2/modules
                                    root@413f2db9a7a6:/magicmirror2/modules# git clone https://github.com/MMRIZE/MMM-CalendarExt3
                                    Cloning into 'MMM-CalendarExt3'...
                                    remote: Enumerating objects: 301, done.
                                    remote: Counting objects: 100% (117/117), done.
                                    remote: Compressing objects: 100% (62/62), done.
                                    remote: Total 301 (delta 65), reused 81 (delta 54), pack-reused 184
                                    Receiving objects: 100% (301/301), 119.61 KiB | 1.21 MiB/s, done.
                                    Resolving deltas: 100% (170/170), done.
                                    root@413f2db9a7a6:/magicmirror2/modules# cd MMM-CalendarExt3
                                    root@413f2db9a7a6:/magicmirror2/modules/MMM-CalendarExt3# npm install
                                    > mmm-calendarext3@1.8.1 postinstall
                                    Submodule 'CX3_Shared' (https://github.com/MMRIZE/CX3_Shared) registered for path 'CX3_Shared'
                                    Cloning into '/magicmirror2/modules/MMM-CalendarExt3/CX3_Shared'...
                                    Submodule path 'CX3_Shared': checked out '44c7176e2b79a12e76badb78a49455bd7fbb22e3'
                                    up to date, audited 1 package in 2s
                                    found 0 vulnerabilities
                                    npm notice
                                    npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.5.0
                                    npm notice Run npm install -g npm@10.5.0 to update!
                                    npm notice
                                    root@413f2db9a7a6:/magicmirror2/modules/MMM-CalendarExt3# git submodule update --init --recursive
                                    EDIT: Github issue: https://github.com/ich777/docker-magicmirror2/issues/4
                                    • bugsounetB bugsounet referenced this topic on
                                    • F Offline
                                      flemmingss
                                      okay, new issue, I have gotten this working, but not with past days. I see events from now and forward, but nothing before, even if I have enabled broadcastPastEvents.
                                      /* Magic Mirror Config Sample
                                       * MIT Licensed.
                                      var config = {
                                      	address: "0.0.0.0", // Address to listen on, can be:
                                      	port: 8080,
                                      	ipWhitelist: [], // Set [] to allow all IP addresses
                                      	language: "no",
                                      	timeFormat: 24,
                                      	units: "metric",
                                      	serverOnly:  "true" ,
                                      			     // false, default for all  NON-armv6l devices
                                      			module: "alert",
                                      		//	position: "top_left", 					**Hide this module**
                                      						symbol: "calendar-check",
                                      						color: "cyan",
                                      						url: "https://calendar.google.com/calendar/ical/xxx%40group.calendar.google.com/private-xxx/basic.ics" //felles
                                      						color: "red",
                                      			title: "Kalender",
                                      			config:
                                      				//mode: "month",
                                      				useMarquee: true, //animasjon for å se hele teksten
                                      EDIT: Looks like the calendar settings did not refresh until i rebooted my system, working now
                                        MMRIZE @flemmingss
                                        @flemmingss
                                        Set enough ‘maximumEntries’, ‘maximumNumberOfDays’ and ‘pastDaysCount’ of the default calendar.
                                        • F Offline
                                          flemmingss @MMRIZE
                                          @MMRIZE Tested that, and did not work, but when I rebooted the service, it worked. So these settings must need a restart somehow.
                                            sdetweil @flemmingss
                                            @flemmingss yes, the fetcher is started once, the web page can be refreshed, but the fetcher does not restart.
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 34
                                            • 35
                                            • 25 / 35
