    MMM-CalendarExt3
    689 Posts 82 Posters 3.3m Views 86 Watching
      MMRIZE @flemmingss
      @flemmingss
      You may still need to complete the installation of the module. You may have missed these instructions on installation;
      npm install
      git submodule update --init --recursive
      Or, you are using Docker, and for some reason, css/custom.css and modules/MMM-CalendarExt3/CX3_Shared/CX3_Shared.mjs seems not being loaded. I’m not familiar with Docker so not sure.
      F 1 Reply Last reply
      • F
        flemmingss @MMRIZE
        @MMRIZE
        Hmm, these commands di not solve anyhing.
        To be more accurate, I am running this on UnRAID with this image: https://hub.docker.com/r/ich777/magic-mirror2
        The modules are installed by entering the URL in a text-file “magicmirror2\modules\modules.txt”.
        # Paste the links from the git repository wich you want to install here.
        # The Y or N is the indication if the module needs 'npm install' to work.
        # Also you can delete the # in front of any line below to install a module
        # from the corresponding github repository (please don't delete the last line).
        N https://github.com/MMRIZE/MMM-LogExt
        Y https://github.com/MMRIZE/MMM-CalendarExt3.git
        #Y https://github.com/ItayXD/MMM-Admin-Interface.git
        #N https://github.com/werthdavid/MMM-BurnIn.git
        #N https://github.com/barnabycolby/MMM-Carousel
        #N https://github.com/Toreke/MMM-Dynamic-Modules.git
        #N https://github.com/Kreshnik/MMM-JokeAPI.git
        #Y https://github.com/slametps/MMM-NetworkConnection.git
        #Y https://github.com/PoOwAa/MMM-network-signal.git
        #N https://github.com/glitch452/MMM-ViewNotifications.git
        #N https://github.com/ulrichwisser/MMM-HTMLSnippet
        #Y https://github.com/eouia/MMM-AVStock
        #N https://github.com/jeroenpeters1986/MMM-bitcoin-portfolio.git
        #Y https://github.com/Elaniobro/MMM-stocks.git
        #N https://github.com/rehne/MMM-Ecosia-Tree-Counter.git
        #N https://github.com/amcolash/MMM-GoogleFit.git
        #Y https://github.com/eouia/MMM-News
        #Y https://github.com/pinsdorf/MMM-WeeklySchedule.git
        #N https://github.com/mihairinzis/MMM-wiki
        #Y https://github.com/Jopyth/MMM-Remote-Control.git
        #Y https://github.com/ronny3050/phone-notification-mirror.git
        #Y https://github.com/ianperrin/MMM-Strava.git
        #N https://github.com/PtrBld/MMM-Scrobbler.git
        #N https://github.com/MitchSS/MMM-Hue.git
        # Don't delete this line!
        It it is for any helt, this is the content of my MMM-CalendarExt3 module folder
        https://fastupload.io/0UNy4rcEJ3b4nrI/file
        M 1 Reply Last reply
          MMRIZE @flemmingss
          @flemmingss
          Your RAR is not downloadable by security issue. Anyway, is there CX3_Shared/CX3_Shared.mjs in position? Your error log says it is not accessible on your system.
          • F
            flemmingss @MMRIZE
            @MMRIZE
            The “CX3_Shared” folder is empty, maybe that one is missing somthing?
            Yo can try this: https://nextcloud.flemmingss.top/s/QBE24rBABaao7ci
            karsten13K 1 Reply Last reply
            • karsten13K
              karsten13 @flemmingss
              @flemmingss said in MMM-CalendarExt3:
              this is the problem which is caused by the strange installation procedure in the used docker image.
              The module installation is done via
              npm init -y
              npm install request --save
              You have to ask the author of this script why he is doing this.
              With this construction the postinstall/postupgrade scripts defined in the package,json of MMM-CalendarExt3 are never called so the CX3_Shared folder is empty.
              • F
                flemmingss @karsten13
                @karsten13
                Looks like your right, I did the install procedure manual inside the docker container and it is working like it should :D
                Thanks for your help, I will inform the container developer about this issue.
                root@413f2db9a7a6:/tmp# cd ..
                root@413f2db9a7a6:/# cd magicmirror2/modules
                root@413f2db9a7a6:/magicmirror2/modules# git clone https://github.com/MMRIZE/MMM-CalendarExt3
                Cloning into 'MMM-CalendarExt3'...
                remote: Enumerating objects: 301, done.
                remote: Counting objects: 100% (117/117), done.
                remote: Compressing objects: 100% (62/62), done.
                remote: Total 301 (delta 65), reused 81 (delta 54), pack-reused 184
                Receiving objects: 100% (301/301), 119.61 KiB | 1.21 MiB/s, done.
                Resolving deltas: 100% (170/170), done.
                root@413f2db9a7a6:/magicmirror2/modules# cd MMM-CalendarExt3
                root@413f2db9a7a6:/magicmirror2/modules/MMM-CalendarExt3# npm install
                > mmm-calendarext3@1.8.1 postinstall
                Submodule 'CX3_Shared' (https://github.com/MMRIZE/CX3_Shared) registered for path 'CX3_Shared'
                Cloning into '/magicmirror2/modules/MMM-CalendarExt3/CX3_Shared'...
                Submodule path 'CX3_Shared': checked out '44c7176e2b79a12e76badb78a49455bd7fbb22e3'
                up to date, audited 1 package in 2s
                found 0 vulnerabilities
                npm notice
                npm notice New minor version of npm available! 10.2.3 -> 10.5.0
                npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.5.0
                npm notice Run npm install -g npm@10.5.0 to update!
                npm notice
                root@413f2db9a7a6:/magicmirror2/modules/MMM-CalendarExt3# git submodule update --init --recursive
                EDIT: Github issue: https://github.com/ich777/docker-magicmirror2/issues/4
                • bugsounetB bugsounet referenced this topic on
                • F
                  flemmingss
                  okay, new issue, I have gotten this working, but not with past days. I see events from now and forward, but nothing before, even if I have enabled broadcastPastEvents.
                  /* Magic Mirror Config Sample
                   * MIT Licensed.
                  var config = {
                  	address: "0.0.0.0", // Address to listen on, can be:
                  	port: 8080,
                  	ipWhitelist: [], // Set [] to allow all IP addresses
                  	language: "no",
                  	timeFormat: 24,
                  	units: "metric",
                  	serverOnly:  "true" ,
                  			     // false, default for all  NON-armv6l devices
                  			module: "alert",
                  		//	position: "top_left", 					**Hide this module**
                  				broadcastPastEvents: true,
                  						symbol: "calendar-check",
                  						color: "cyan",
                  						url: "https://calendar.google.com/calendar/ical/xxx%40group.calendar.google.com/private-xxx/basic.ics" //felles
                  						color: "red",
                  			module: "MMM-CalendarExt3",
                  			position: "top_bar",
                  			title: "Kalender",
                  			config:
                  				//mode: "month",
                  				useMarquee: true, //animasjon for å se hele teksten
                  EDIT: Looks like the calendar settings did not refresh until i rebooted my system, working now
                    MMRIZE @flemmingss
                    @flemmingss
                    Set enough ‘maximumEntries’, ‘maximumNumberOfDays’ and ‘pastDaysCount’ of the default calendar.
                    • F
                      flemmingss @MMRIZE
                      @MMRIZE Tested that, and did not work, but when I rebooted the service, it worked. So these settings must need a restart somehow.
                        sdetweil @flemmingss
                        @flemmingss yes, the fetcher is started once, the web page can be refreshed, but the fetcher does not restart.
                        W 1 Reply Last reply
                        • W
                          Welle05 @sdetweil
                          Problem with full day events since summer time in Germany.
                          Full-day events which are part of a series are now spawn over two days. All series were built in winter time. I checked the original (google) Calendar : fine, also the Standard Calendar Module, but when it comes to Ext3 there are shown like this:
                          single full dayevents (not part of a series): fine
                          serial events with start date: also fine
                          Any idea?
                          Best regards
                          Chris
                          • F
                            fedale @Welle05
                            @Welle05 have you found a solution for this? i have the same issue in Sweden.
                            And it´s only for fullday events.
                            S M 2 Replies Last reply
                              sdetweil @fedale
                              @fedale ext3 is expecting full day events to have 00:00 as the time.
                              with some change they come with utc offset
                              02:00
                              or whatever.
                              he could check the full day event flag and ignore the time
                                MMRIZE @fedale
                                @fedale @Welle05
                                See this.
                                https://github.com/MMRIZE/MMM-CalendarExt3/wiki/To-fix-wrong-repeated-fullday-event-displaying-(MM-2.27)
                                • F
                                  fedale @sdetweil
                                  Where can i input the offset?
                                  Can i do that in the default calendar?
                                    sdetweil @fedale
                                    @fedale see the post before yours that gives you the fix
                                      bobbylx
                                      Hello all, so I’ve got MMM-Calendarext3 working just how I want and now working on some personalization. Can anyone advise what to change and where to add some shadow behind the date cells? Kind of like the shadow behind the previous days, I’d like to add some light gray or something to the entire calendar just so it doesn’t get lost in my wallpaper.
                                      Second, anyone know how/where to change the border thickness for the current day?
                                        MMRIZE @bobbylx
                                        @bobbylx
                                        For today cell border; Append this into your css/custom.css
                                        /* css/custom.css */
                                        .CX3 .cell.today {
                                          border: 2px solid #fff; /* default was 1px, so you can change to 2px or whatever */
                                        For shadow behind the cell... Could you tell me more details or example?
                                        B 1 Reply Last reply
                                          bobbylx @MMRIZE
                                          @MMRIZE said in MMM-CalendarExt3:
                                          @bobbylx
                                          .CX3 .cell.today {
                                          Thank you, I’ll give that a try.
                                          For the shadow, maybe not the right term, in my screenshot see how the previous days have a light but transparent white color to them. I’d like all the cells to be shaded like that, i can play with the colors, ie white vs gray etc. but I’m just not sure how to add the background color to all cells then make it transparent. That make sense? I know my terms are not correct…
                                            MMRIZE @bobbylx
                                            @bobbylx
                                            To emphasize this month, I added this to the cells of this month.
                                            .CX3 .thisMonth {
                                              background-color: rgb(255 255 255 / 10%);
                                            rgb(RED GREEN BLUE / TRANSPARENCY); could be what you were searching.
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 34
                                            • 35
                                            • 26 / 35
