    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
    • F
      flemmingss @MMRIZE
      @MMRIZE Tested that, and did not work, but when I rebooted the service, it worked. So these settings must need a restart somehow.
        sdetweil @flemmingss
        @flemmingss yes, the fetcher is started once, the web page can be refreshed, but the fetcher does not restart.
        W 1 Reply Last reply
        • W
          Welle05 @sdetweil
          Problem with full day events since summer time in Germany.
          Full-day events which are part of a series are now spawn over two days. All series were built in winter time. I checked the original (google) Calendar : fine, also the Standard Calendar Module, but when it comes to Ext3 there are shown like this:
          single full dayevents (not part of a series): fine
          serial events with start date: also fine
          Any idea?
          Best regards
          Chris
          F 1 Reply Last reply
          • F
            fedale @Welle05
            @Welle05 have you found a solution for this? i have the same issue in Sweden.
            And it´s only for fullday events.
            S M 2 Replies Last reply
              sdetweil @fedale
              @fedale ext3 is expecting full day events to have 00:00 as the time.
              with some change they come with utc offset
              02:00
              or whatever.
              he could check the full day event flag and ignore the time
                MMRIZE @fedale
                @fedale @Welle05
                See this.
                https://github.com/MMRIZE/MMM-CalendarExt3/wiki/To-fix-wrong-repeated-fullday-event-displaying-(MM-2.27)
                • F
                  fedale @sdetweil
                  Where can i input the offset?
                  Can i do that in the default calendar?
                    sdetweil @fedale
                    @fedale see the post before yours that gives you the fix
                      bobbylx
                      Hello all, so I’ve got MMM-Calendarext3 working just how I want and now working on some personalization. Can anyone advise what to change and where to add some shadow behind the date cells? Kind of like the shadow behind the previous days, I’d like to add some light gray or something to the entire calendar just so it doesn’t get lost in my wallpaper.
                      Second, anyone know how/where to change the border thickness for the current day?
                      M 1 Reply Last reply
                        MMRIZE @bobbylx
                        @bobbylx
                        For today cell border; Append this into your css/custom.css
                        /* css/custom.css */
                        .CX3 .cell.today {
                          border: 2px solid #fff; /* default was 1px, so you can change to 2px or whatever */
                        For shadow behind the cell... Could you tell me more details or example?
                        B 1 Reply Last reply
                          bobbylx @MMRIZE
                          @MMRIZE said in MMM-CalendarExt3:
                          @bobbylx
                          .CX3 .cell.today {
                          Thank you, I’ll give that a try.
                          For the shadow, maybe not the right term, in my screenshot see how the previous days have a light but transparent white color to them. I’d like all the cells to be shaded like that, i can play with the colors, ie white vs gray etc. but I’m just not sure how to add the background color to all cells then make it transparent. That make sense? I know my terms are not correct…
                            MMRIZE @bobbylx
                            @bobbylx
                            To emphasize this month, I added this to the cells of this month.
                            .CX3 .thisMonth {
                              background-color: rgb(255 255 255 / 10%);
                            rgb(RED GREEN BLUE / TRANSPARENCY); could be what you were searching.
                              bobbylx @MMRIZE
                              @bobbylx
                              .CX3 .thisMonth {
                              Thanks again, this did it.
                              • A
                                almightyyoshi
                                I have a Cozi calendar for dinner and the event comes over as “All: Pork Tenderloin”. Is there any way to get rid of the “All:” (with either Transform or preProcessor) and keep the rest?
                                  MMRIZE @almightyyoshi
                                  @almightyyoshi
                                  eventTransformer: (ev) => {
                                    ev.title = ev.title.replace("All:", "")
                                    return ev
                                  A 1 Reply Last reply
                                  • A
                                    almightyyoshi @MMRIZE
                                    @MMRIZE Sigh. I knew it was going to be something easy like that and I was overthinking it. Thanks! Couple more questions:
                                    1. How can I remove the CW? I’ve tried:
                                    .CX3 .cell.cellHeader .cw {
                                            display: none;
                                    .CX3 .cell .cellHeader .cw {
                                            display: none;
                                    .CX3 .cellHeader .cw {
                                            display: none;
                                    and
                                    .CX3 .cell .cw {
                                            display: none;
                                    1. How can I remove the start time in an instance? I’ve tried:
                                    .CX3_currentMonth .event .time.startTime {
                                            display: none;
                                    I got it working with a specific calendar using:
                                    .CX3 .event.calendar_Dinner .time.startTime {
                                            display: none;
                                      @almightyyoshi
                                      For removing calendarWeek number;
                                      https://github.com/MMRIZE/MMM-CalendarExt3/wiki/Examples-%26-Tips
                                        @almightyyoshi
                                        For the second question, I cannot understand. More details for TO-BE and AS-IS be needed. (Show me the example)
                                        • A
                                          @MMRIZE Perfect. Thanks!
                                          • A
                                            @MMRIZE I have two instances of CalExt3: monthly (currentMonth) and weekly (currentWeek). Except for one calendar (Dinner), they both currently shows events with the event time like this:
                                            What I’d like is for only the currentMonth instance to show events without the event time like this:
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 34
                                            • 35
                                            • 26 / 35
