    MMM-CalendarExt3
    689 Posts 82 Posters 3.3m Views 86 Watching
    • karsten13K
      karsten13 @flemmingss
      @flemmingss said in MMM-CalendarExt3:
      The “CX3_Shared” folder is empty
      this is the problem which is caused by the strange installation procedure in the used docker image.
      The module installation is done via
      npm init -y
      npm install request --save
      You have to ask the author of this script why he is doing this.
      With this construction the postinstall/postupgrade scripts defined in the package,json of MMM-CalendarExt3 are never called so the CX3_Shared folder is empty.
      F 1 Reply Last reply
      • F
        flemmingss @karsten13
        @karsten13
        Looks like your right, I did the install procedure manual inside the docker container and it is working like it should :D
        Thanks for your help, I will inform the container developer about this issue.
        root@413f2db9a7a6:/tmp# cd ..
        root@413f2db9a7a6:/# cd magicmirror2/modules
        root@413f2db9a7a6:/magicmirror2/modules# git clone https://github.com/MMRIZE/MMM-CalendarExt3
        Cloning into 'MMM-CalendarExt3'...
        remote: Enumerating objects: 301, done.
        remote: Counting objects: 100% (117/117), done.
        remote: Compressing objects: 100% (62/62), done.
        remote: Total 301 (delta 65), reused 81 (delta 54), pack-reused 184
        Receiving objects: 100% (301/301), 119.61 KiB | 1.21 MiB/s, done.
        Resolving deltas: 100% (170/170), done.
        root@413f2db9a7a6:/magicmirror2/modules# cd MMM-CalendarExt3
        root@413f2db9a7a6:/magicmirror2/modules/MMM-CalendarExt3# npm install
        > mmm-calendarext3@1.8.1 postinstall
        > git submodule update --init --recursive
        Submodule 'CX3_Shared' (https://github.com/MMRIZE/CX3_Shared) registered for path 'CX3_Shared'
        Cloning into '/magicmirror2/modules/MMM-CalendarExt3/CX3_Shared'...
        Submodule path 'CX3_Shared': checked out '44c7176e2b79a12e76badb78a49455bd7fbb22e3'
        up to date, audited 1 package in 2s
        found 0 vulnerabilities
        npm notice
        npm notice New minor version of npm available! 10.2.3 -> 10.5.0
        npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.5.0
        npm notice Run npm install -g npm@10.5.0 to update!
        npm notice
        root@413f2db9a7a6:/magicmirror2/modules/MMM-CalendarExt3# git submodule update --init --recursive
        EDIT: Github issue: https://github.com/ich777/docker-magicmirror2/issues/4
        • bugsounetB bugsounet referenced this topic on
        • F
          flemmingss
          okay, new issue, I have gotten this working, but not with past days. I see events from now and forward, but nothing before, even if I have enabled broadcastPastEvents.
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	address: "0.0.0.0", // Address to listen on, can be:
          	port: 8080,
          	ipWhitelist: [], // Set [] to allow all IP addresses
          	language: "no",
          	timeFormat: 24,
          	units: "metric",
          	serverOnly:  "true" ,
          			     // false, default for all  NON-armv6l devices
          			module: "alert",
          		//	position: "top_left", 					**Hide this module**
          				broadcastPastEvents: true,
          						symbol: "calendar-check",
          						color: "cyan",
          						url: "https://calendar.google.com/calendar/ical/xxx%40group.calendar.google.com/private-xxx/basic.ics" //felles
          						color: "red",
          			module: "MMM-CalendarExt3",
          			position: "top_bar",
          			title: "Kalender",
          			config:
          				//mode: "month",
          				useMarquee: true, //animasjon for å se hele teksten
          EDIT: Looks like the calendar settings did not refresh until i rebooted my system, working now
          M 1 Reply Last reply
            MMRIZE @flemmingss
            @flemmingss
            Set enough ‘maximumEntries’, ‘maximumNumberOfDays’ and ‘pastDaysCount’ of the default calendar.
            • F
              flemmingss @MMRIZE
              @MMRIZE Tested that, and did not work, but when I rebooted the service, it worked. So these settings must need a restart somehow.
                sdetweil @flemmingss
                @flemmingss yes, the fetcher is started once, the web page can be refreshed, but the fetcher does not restart.
                W 1 Reply Last reply
                • W
                  Welle05 @sdetweil
                  Problem with full day events since summer time in Germany.
                  Full-day events which are part of a series are now spawn over two days. All series were built in winter time. I checked the original (google) Calendar : fine, also the Standard Calendar Module, but when it comes to Ext3 there are shown like this:
                  single full dayevents (not part of a series): fine
                  serial events with start date: also fine
                  Any idea?
                  Best regards
                  Chris
                  • F
                    fedale @Welle05
                    @Welle05 have you found a solution for this? i have the same issue in Sweden.
                    And it´s only for fullday events.
                    S M 2 Replies Last reply
                      sdetweil @fedale
                      @fedale ext3 is expecting full day events to have 00:00 as the time.
                      with some change they come with utc offset
                      02:00
                      or whatever.
                      he could check the full day event flag and ignore the time
                        MMRIZE @fedale
                        @fedale @Welle05
                        See this.
                        https://github.com/MMRIZE/MMM-CalendarExt3/wiki/To-fix-wrong-repeated-fullday-event-displaying-(MM-2.27)
                        • F
                          fedale @sdetweil
                          Where can i input the offset?
                          Can i do that in the default calendar?
                            sdetweil @fedale
                            @fedale see the post before yours that gives you the fix
                              bobbylx
                              Hello all, so I’ve got MMM-Calendarext3 working just how I want and now working on some personalization. Can anyone advise what to change and where to add some shadow behind the date cells? Kind of like the shadow behind the previous days, I’d like to add some light gray or something to the entire calendar just so it doesn’t get lost in my wallpaper.
                              Second, anyone know how/where to change the border thickness for the current day?
                                MMRIZE @bobbylx
                                @bobbylx
                                For today cell border; Append this into your css/custom.css
                                /* css/custom.css */
                                .CX3 .cell.today {
                                  border: 2px solid #fff; /* default was 1px, so you can change to 2px or whatever */
                                For shadow behind the cell... Could you tell me more details or example?
                                B 1 Reply Last reply
                                  bobbylx @MMRIZE
                                  @MMRIZE said in MMM-CalendarExt3:
                                  @bobbylx
                                  .CX3 .cell.today {
                                  Thank you, I’ll give that a try.
                                  For the shadow, maybe not the right term, in my screenshot see how the previous days have a light but transparent white color to them. I’d like all the cells to be shaded like that, i can play with the colors, ie white vs gray etc. but I’m just not sure how to add the background color to all cells then make it transparent. That make sense? I know my terms are not correct…
                                    MMRIZE @bobbylx
                                    @bobbylx
                                    To emphasize this month, I added this to the cells of this month.
                                    .CX3 .thisMonth {
                                      background-color: rgb(255 255 255 / 10%);
                                    rgb(RED GREEN BLUE / TRANSPARENCY); could be what you were searching.
                                      bobbylx @MMRIZE
                                      @bobbylx
                                      .CX3 .thisMonth {
                                      Thanks again, this did it.
                                      • A
                                        almightyyoshi
                                        I have a Cozi calendar for dinner and the event comes over as “All: Pork Tenderloin”. Is there any way to get rid of the “All:” (with either Transform or preProcessor) and keep the rest?
                                          MMRIZE @almightyyoshi
                                          @almightyyoshi
                                          eventTransformer: (ev) => {
                                            ev.title = ev.title.replace("All:", "")
                                            return ev
                                          A 1 Reply Last reply
                                          • A
                                            almightyyoshi @MMRIZE
                                            @MMRIZE Sigh. I knew it was going to be something easy like that and I was overthinking it. Thanks! Couple more questions:
                                            1. How can I remove the CW? I’ve tried:
                                            .CX3 .cell.cellHeader .cw {
                                                    display: none;
                                            .CX3 .cell .cellHeader .cw {
                                                    display: none;
                                            .CX3 .cellHeader .cw {
                                                    display: none;
                                            and
                                            .CX3 .cell .cw {
                                                    display: none;
                                            1. How can I remove the start time in an instance? I’ve tried:
                                            .CX3_currentMonth .event .time.startTime {
                                                    display: none;
                                            I got it working with a specific calendar using:
                                            .CX3 .event.calendar_Dinner .time.startTime {
                                                    display: none;
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 34
                                            • 35
                                            • 26 / 35
