    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
    • F Offline
      flemmingss @MMRIZE
      @MMRIZE
      The “CX3_Shared” folder is empty, maybe that one is missing somthing?
      Yo can try this: https://nextcloud.flemmingss.top/s/QBE24rBABaao7ci
      • karsten13K Online
        karsten13 @flemmingss
        @flemmingss said in MMM-CalendarExt3:
        this is the problem which is caused by the strange installation procedure in the used docker image.
        The module installation is done via
        npm init -y
        npm install request --save
        You have to ask the author of this script why he is doing this.
        With this construction the postinstall/postupgrade scripts defined in the package,json of MMM-CalendarExt3 are never called so the CX3_Shared folder is empty.
        • F Offline
          flemmingss @karsten13
          @karsten13
          Looks like your right, I did the install procedure manual inside the docker container and it is working like it should :D
          Thanks for your help, I will inform the container developer about this issue.
          root@413f2db9a7a6:/tmp# cd ..
          root@413f2db9a7a6:/# cd magicmirror2/modules
          root@413f2db9a7a6:/magicmirror2/modules# git clone https://github.com/MMRIZE/MMM-CalendarExt3
          Cloning into 'MMM-CalendarExt3'...
          remote: Enumerating objects: 301, done.
          remote: Counting objects: 100% (117/117), done.
          remote: Compressing objects: 100% (62/62), done.
          remote: Total 301 (delta 65), reused 81 (delta 54), pack-reused 184
          Receiving objects: 100% (301/301), 119.61 KiB | 1.21 MiB/s, done.
          Resolving deltas: 100% (170/170), done.
          root@413f2db9a7a6:/magicmirror2/modules# cd MMM-CalendarExt3
          root@413f2db9a7a6:/magicmirror2/modules/MMM-CalendarExt3# npm install
          > mmm-calendarext3@1.8.1 postinstall
          > git submodule update --init --recursive
          Submodule 'CX3_Shared' (https://github.com/MMRIZE/CX3_Shared) registered for path 'CX3_Shared'
          Cloning into '/magicmirror2/modules/MMM-CalendarExt3/CX3_Shared'...
          Submodule path 'CX3_Shared': checked out '44c7176e2b79a12e76badb78a49455bd7fbb22e3'
          up to date, audited 1 package in 2s
          found 0 vulnerabilities
          npm notice
          npm notice New minor version of npm available! 10.2.3 -> 10.5.0
          npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.5.0
          npm notice Run npm install -g npm@10.5.0 to update!
          npm notice
          root@413f2db9a7a6:/magicmirror2/modules/MMM-CalendarExt3# git submodule update --init --recursive
          EDIT: Github issue: https://github.com/ich777/docker-magicmirror2/issues/4
          • bugsounetB bugsounet referenced this topic on
          • F Offline
            flemmingss
            okay, new issue, I have gotten this working, but not with past days. I see events from now and forward, but nothing before, even if I have enabled broadcastPastEvents.
            /* Magic Mirror Config Sample
             * MIT Licensed.
            var config = {
            	address: "0.0.0.0", // Address to listen on, can be:
            	port: 8080,
            	ipWhitelist: [], // Set [] to allow all IP addresses
            	language: "no",
            	timeFormat: 24,
            	units: "metric",
            	serverOnly:  "true" ,
            			     // false, default for all  NON-armv6l devices
            			module: "alert",
            		//	position: "top_left", 					**Hide this module**
            				broadcastPastEvents: true,
            						symbol: "calendar-check",
            						color: "cyan",
            						url: "https://calendar.google.com/calendar/ical/xxx%40group.calendar.google.com/private-xxx/basic.ics" //felles
            						color: "red",
            			module: "MMM-CalendarExt3",
            			position: "top_bar",
            			title: "Kalender",
            			config:
            				//mode: "month",
            				useMarquee: true, //animasjon for å se hele teksten
            EDIT: Looks like the calendar settings did not refresh until i rebooted my system, working now
              MMRIZE @flemmingss
              @flemmingss
              Set enough ‘maximumEntries’, ‘maximumNumberOfDays’ and ‘pastDaysCount’ of the default calendar.
              • F Offline
                flemmingss @MMRIZE
                @MMRIZE Tested that, and did not work, but when I rebooted the service, it worked. So these settings must need a restart somehow.
                  sdetweil @flemmingss
                  @flemmingss yes, the fetcher is started once, the web page can be refreshed, but the fetcher does not restart.
                  • W Offline
                    Welle05 @sdetweil
                    Problem with full day events since summer time in Germany.
                    Full-day events which are part of a series are now spawn over two days. All series were built in winter time. I checked the original (google) Calendar : fine, also the Standard Calendar Module, but when it comes to Ext3 there are shown like this:
                    single full dayevents (not part of a series): fine
                    serial events with start date: also fine
                    Any idea?
                    Best regards
                    Chris
                    • F Offline
                      fedale @Welle05
                      @Welle05 have you found a solution for this? i have the same issue in Sweden.
                      And it´s only for fullday events.
                        sdetweil @fedale
                        @fedale ext3 is expecting full day events to have 00:00 as the time.
                        with some change they come with utc offset
                        02:00
                        or whatever.
                        he could check the full day event flag and ignore the time
                          MMRIZE @fedale
                          @fedale @Welle05
                          See this.
                          https://github.com/MMRIZE/MMM-CalendarExt3/wiki/To-fix-wrong-repeated-fullday-event-displaying-(MM-2.27)
                          • F Offline
                            fedale @sdetweil
                            Where can i input the offset?
                            Can i do that in the default calendar?
                              sdetweil @fedale
                              @fedale see the post before yours that gives you the fix
                                bobbylx
                                Hello all, so I’ve got MMM-Calendarext3 working just how I want and now working on some personalization. Can anyone advise what to change and where to add some shadow behind the date cells? Kind of like the shadow behind the previous days, I’d like to add some light gray or something to the entire calendar just so it doesn’t get lost in my wallpaper.
                                Second, anyone know how/where to change the border thickness for the current day?
                                  MMRIZE @bobbylx
                                  @bobbylx
                                  For today cell border; Append this into your css/custom.css
                                  /* css/custom.css */
                                  .CX3 .cell.today {
                                    border: 2px solid #fff; /* default was 1px, so you can change to 2px or whatever */
                                  For shadow behind the cell... Could you tell me more details or example?
                                    bobbylx @MMRIZE
                                    @MMRIZE said in MMM-CalendarExt3:
                                    @bobbylx
                                    .CX3 .cell.today {
                                    Thank you, I’ll give that a try.
                                    For the shadow, maybe not the right term, in my screenshot see how the previous days have a light but transparent white color to them. I’d like all the cells to be shaded like that, i can play with the colors, ie white vs gray etc. but I’m just not sure how to add the background color to all cells then make it transparent. That make sense? I know my terms are not correct…
                                      MMRIZE @bobbylx
                                      @bobbylx
                                      To emphasize this month, I added this to the cells of this month.
                                      .CX3 .thisMonth {
                                        background-color: rgb(255 255 255 / 10%);
                                      rgb(RED GREEN BLUE / TRANSPARENCY); could be what you were searching.
                                        bobbylx @MMRIZE
                                        @bobbylx
                                        .CX3 .thisMonth {
                                        Thanks again, this did it.
                                          almightyyoshi
                                          I have a Cozi calendar for dinner and the event comes over as “All: Pork Tenderloin”. Is there any way to get rid of the “All:” (with either Transform or preProcessor) and keep the rest?
                                            MMRIZE @almightyyoshi
                                            @almightyyoshi
                                            eventTransformer: (ev) => {
                                              ev.title = ev.title.replace("All:", "")
                                              return ev
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 34
                                            • 35
                                            • 26 / 35
