    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
      MMRIZE @fedale
      @fedale @Welle05
      See this.
      https://github.com/MMRIZE/MMM-CalendarExt3/wiki/To-fix-wrong-repeated-fullday-event-displaying-(MM-2.27)
      • F
        fedale @sdetweil
        Where can i input the offset?
        Can i do that in the default calendar?
          sdetweil @fedale
          @fedale see the post before yours that gives you the fix
            bobbylx
            Hello all, so I’ve got MMM-Calendarext3 working just how I want and now working on some personalization. Can anyone advise what to change and where to add some shadow behind the date cells? Kind of like the shadow behind the previous days, I’d like to add some light gray or something to the entire calendar just so it doesn’t get lost in my wallpaper.
            Second, anyone know how/where to change the border thickness for the current day?
              MMRIZE @bobbylx
              @bobbylx
              For today cell border; Append this into your css/custom.css
              /* css/custom.css */
              .CX3 .cell.today {
                border: 2px solid #fff; /* default was 1px, so you can change to 2px or whatever */
              For shadow behind the cell... Could you tell me more details or example?
                bobbylx @MMRIZE
                @MMRIZE said in MMM-CalendarExt3:
                @bobbylx
                .CX3 .cell.today {
                Thank you, I’ll give that a try.
                For the shadow, maybe not the right term, in my screenshot see how the previous days have a light but transparent white color to them. I’d like all the cells to be shaded like that, i can play with the colors, ie white vs gray etc. but I’m just not sure how to add the background color to all cells then make it transparent. That make sense? I know my terms are not correct…
                  MMRIZE @bobbylx
                  @bobbylx
                  To emphasize this month, I added this to the cells of this month.
                  .CX3 .thisMonth {
                    background-color: rgb(255 255 255 / 10%);
                  rgb(RED GREEN BLUE / TRANSPARENCY); could be what you were searching.
                    bobbylx @MMRIZE
                    @bobbylx
                    .CX3 .thisMonth {
                    Thanks again, this did it.
                    • A
                      almightyyoshi
                      I have a Cozi calendar for dinner and the event comes over as “All: Pork Tenderloin”. Is there any way to get rid of the “All:” (with either Transform or preProcessor) and keep the rest?
                        MMRIZE @almightyyoshi
                        @almightyyoshi
                        eventTransformer: (ev) => {
                          ev.title = ev.title.replace("All:", "")
                          return ev
                        • A
                          almightyyoshi @MMRIZE
                          @MMRIZE Sigh. I knew it was going to be something easy like that and I was overthinking it. Thanks! Couple more questions:
                          1. How can I remove the CW? I’ve tried:
                          .CX3 .cell.cellHeader .cw {
                                  display: none;
                          .CX3 .cell .cellHeader .cw {
                                  display: none;
                          .CX3 .cellHeader .cw {
                                  display: none;
                          and
                          .CX3 .cell .cw {
                                  display: none;
                          1. How can I remove the start time in an instance? I’ve tried:
                          .CX3_currentMonth .event .time.startTime {
                                  display: none;
                          I got it working with a specific calendar using:
                          .CX3 .event.calendar_Dinner .time.startTime {
                                  display: none;
                            @almightyyoshi
                            For removing calendarWeek number;
                            https://github.com/MMRIZE/MMM-CalendarExt3/wiki/Examples-%26-Tips
                              @almightyyoshi
                              For the second question, I cannot understand. More details for TO-BE and AS-IS be needed. (Show me the example)
                              • A
                                @MMRIZE Perfect. Thanks!
                                • A
                                  @MMRIZE I have two instances of CalExt3: monthly (currentMonth) and weekly (currentWeek). Except for one calendar (Dinner), they both currently shows events with the event time like this:
                                  What I’d like is for only the currentMonth instance to show events without the event time like this:
                                    @almightyyoshi
                                    .CX3_currentMonth .event.singleday .headline .time {
                                      display: none;
                                    Before
                                    After
                                    • A
                                      @MMRIZE That worked…after I figured out I spelled instanceId incorrectly (I had instanceID). Thanks!
                                        moosespectacles
                                        Anyone know of a config that looks identical/similar to the skylight calendar layout? I’m trying to emulate that look and those features, as a starting point, but I’m having trouble with getting the calendar to even display one week or 3 days, only. At the moment I see a week, with another week right next to it, instead of underneath it, as well as week numbers being show. I haven’t been able to figure out how to get rid of the extra days, nor the week numbers.
                                          sdetweil @moosespectacles
                                          @moosespectacles well the skylight view is one week
                                          so
                                          mode:‘week’,
                                          weeksInView:1,
                                          then you have to use css to remove the weeknumber
                                            MMRIZE @moosespectacles
                                            @moosespectacles
                                            I think what you want is MMM-CalendarExtJournal, not this module.
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 34
                                            • 35
                                            • 26 / 35
