    MMM-CalendarExt3 BST Timezone issue
    26 Posts 4 Posters 9.2k Views 4 Watching
      shall_
      I currently have an issue with MMM-CalendarEXT3 where since we have switched to british summer time (BST) Timezone, now all my all and multi day calendar events roll into the following day, i had the same issue last year, my only resolution was to switch back to DST timezone.
      I have trawled through the internet looking for a solution but i can’t find one. I have check my calendar timezone matches the Pi timezone. Plus tried various updates.
      a lot of the “solutions” I have seen required hiding the end date, which isn’t really a fix and wouldn’t work for my situation.
      Has anyone had this issue and found a good solution to this?
        shall_ @shall_
        I have managed to fix my issue, it seems the event transformer I was using (to colour mt events) may have been contradicting the fix.
        I removed the following from my event transformer which fixed the issue!
          e.startDate = new Date(e.start?.date || e.start?.dateTime).valueOf()
          e.endDate = new Date(e.end?.date || e.end?.dateTime).valueOf()
          sdetweil @shall_
          @shall_ i have not heard of this problem before.
          can you provide the tinezone and a calendar entry from the ics file
          to get the ics file take yiur calendar_url and do
          curl -sL calendar_url >xxx.ics
          then edit xxx.ics (its just text)
          and find a BEGIN:VEVENT… END:VEVENT
          That has the matching date/time info
          xxx out any private data, but dont change anything else
          post back here
            shall_ @sdetweil
            @sdetweil said in MMM-CalendarExt3 BST Timezone issue:
            Thanks for the reply. I am having trouble getting the ics file.
            i have ran the command in the terminal, all it does is return to the empty command line. is this supposed to open something?
            then efit xxx.ics (its just text)
            I am not sure what you mean by this? Apologies i am still fairly green on this side of things.
              sdetweil @shall_
              @shall_ sorry efit was edit, new phone and thumb havent become friends yet
              by default most linux commands produce NO output when successful. they were designed back
              in the teletype terminal world, where every character took a long time.
              so, this means the ics file was downloaded as requested
                shall_ @sdetweil
                Ok that makes sense. I have found the generated ics file, however it has a 0 file size and when I open it with text editor it is just an empty file. The file type is listed as “Outlook.File.ics.15”
                I am using google calendar urls, not sure if that makes any difference? i have tried 3 different urls that I use with the module.
                  sdetweil @shall_
                  @shall_ weird. are using the same url in mm config?
                  you might also try it in a browser on your pc. it should download the ics (downloads folder)
                    shall_ @sdetweil
                    @sdetweil yes i copied each url straight from my config file.
                    I tried opening them in the browser, it downloaded as described but is still an empty file.
                    I found a work around by just downloading the ics right from google calendar, this is an example of one of the events. with the timezone tied in.
                    RPi timezone is set to GMT +1 Europe/London (BST)
                    BEGIN:VCALENDAR
                    PRODID:-//Google Inc//Google Calendar 70.9054//EN
                    VERSION:2.0
                    CALSCALE:GREGORIAN
                    METHOD:PUBLISH
                    X-WR-CALNAME:Work
                    X-WR-TIMEZONE:Europe/London
                    BEGIN:VEVENT
                    DTSTART;VALUE=DATE:20170626
                    DTEND;VALUE=DATE:20170701
                    RRULE:FREQ=WEEKLY;WKST=MO;UNTIL=20190331T235959Z;INTERVAL=2;BYDAY=MO
                    DTSTAMP:20240403T224236Z
                    UID:15dcXXXXXXujb@google.com
                    CREATED:20171216T163405Z
                    LAST-MODIFIED:20190330T214112Z
                    SEQUENCE:0
                    STATUS:CONFIRMED
                    SUMMARY:Earlies
                    TRANSP:TRANSPARENT
                    END:VEVENT
                    S S 2 Replies Last reply Reply Quote 0
                      shall_ @sdetweil
                      @sdetweil this is another entry added this week with the issue.
                      BEGIN:VEVENT
                      DTSTART;VALUE=DATE:20240402
                      DTEND;VALUE=DATE:20240403
                      UID:70rjap1gXXXXX6oo68db56o@google.com
                      CREATED:20240402T105500Z
                      LAST-MODIFIED:20240402T105500Z
                      SEQUENCE:0
                      STATUS:CONFIRMED
                      SUMMARY:12 hours
                      TRANSP:OPAQUE
                      END:VEVENT
                        sdetweil @shall_
                        @shall_ ok. weird. anyhow
                        we dont process anything other than vevents. so the garbage at the top which has the x-wr timezone, we dont see.
                        so the calendar will be processed in the current system timezone.
                        if you want to see the debug of processing, add the ,“DEBUG” to the end of the logLevel property in config.js
                        and then start mm like this
                        npm start >somefile.txt 2>&1
                        wait til the cal is up, then ctrl-q quit mm and examine the somefile.txt
                          sdetweil @shall_
                          @shall_ because there is no timezone specified on the entry, it will be processed in the current system timezone
                            shall_ @shall_
                            I will have to pick this up again tomorrow. i will run the debug when i get home from work.
                            is there anything I am looking for in particular?
                              sdetweil @shall_
                              @shall_ because there is a rrule
                              the string
                              dates: …
                              documents the dates returned from the rrule.between function… yesterday plus 1 year
                              is the window we create to get recurring events
                                MMRIZE
                                @shall_
                                CX3 doesn’t parse ics file directly, so probably the default calendar app (or any event provider) must have responsibility.
                                But for an instant solution, you can use preProcessor or event payload to make a hotfix by force.
                                BEFORE
                                /* in your CX3 module config */
                                preProcessor: (event) => {
                                	if (["SomeCalendarName", "AnotherCalendarName"].includes(event.calendarName)) {
                                		event.startDate = Number(event.startDate) - 1000 * 60 * 60
                                		event.endDate = Number(event.endDate) - 1000 * 60 * 60
                                	return event
                                AFTER
                                If all your calendar has that issue, you can omit if statement.
                                	return event
                                  shall_ @MMRIZE
                                  @MMRIZE Thanks for your reply.
                                  The timed calendar events with a start/finish time show the correct time with no issue.
                                  The issue solely lies with all-day and multi-day events.
                                  All of these events during DST showed correctly, as soon as the timezone changed to BST. They now all rollover into the following day, so my 5 day events are now 6 days, 2 days are now 3, single days 2.
                                    MMRIZE @shall_
                                    @shall_
                                    Can you send me the ics file? (eouia0819@gmail.com)
                                      shall_ @MMRIZE
                                      @MMRIZE i have emailed it over
                                        alaric10000
                                        Is MagicMirror installed directly to your Pi, or are you running it inside a Docker or other container? I originally had a similar problem with my MM configs all set properly, and my system time set properly, but for some reason I needed to also force the Docker container to the correct timezone with environment variables in the docker-compose file:
                                        environment:
                                        - TZ=America/Los Angeles
                                        - SET_CONTAINER_TIMEZONE=true
                                        - CONTAINER_TIMEZONE=America/Los_Angeles
                                        Obviously you’d want a different timezone, and you’re probably running MM on your Pi without using Docker, but maybe it’ll help.
                                          MMRIZE
                                          @shall_ @alaric10000
                                          It happens when the event is regarded as FulldayEvent but not to start at 0 O’clock. I updated the module to fix it.
                                          https://github.com/MMRIZE/MMM-CalendarExt3/pull/141
                                          Update the module and check it.
                                            MMRIZE
                                            Finally I found what was wrong.
                                            The issue lies in the wrong parsing logic from the default calendar module about repeated full-day events with TimeZone by RRULE.
                                            If you have installed CX3 v1.8.2, Reinstall again or back to 1.8.1 (I rolled back again to 1.8.1)
                                            Then see this;
                                            https://github.com/MMRIZE/MMM-CalendarExt3/wiki/To-fix-wrong-repeated-fullday-event-displaying-(MM-2.27)
                                              sdetweil @MMRIZE
                                              @MMRIZE but… for full day, you ignore the time… or reset it to 00:00:00
