    MMM-CalendarExt3 BST Timezone issue
    26 Posts 4 Posters 9.5k Views 4 Watching
      sdetweil @shall_
      @shall_ sorry efit was edit, new phone and thumb havent become friends yet
      by default most linux commands produce NO output when successful. they were designed back
      in the teletype terminal world, where every character took a long time.
      so, this means the ics file was downloaded as requested
        shall_ @sdetweil
        Ok that makes sense. I have found the generated ics file, however it has a 0 file size and when I open it with text editor it is just an empty file. The file type is listed as “Outlook.File.ics.15”
        I am using google calendar urls, not sure if that makes any difference? i have tried 3 different urls that I use with the module.
          sdetweil @shall_
          @shall_ weird. are using the same url in mm config?
          you might also try it in a browser on your pc. it should download the ics (downloads folder)
          S 2 Replies Last reply
            shall_ @sdetweil
            @sdetweil yes i copied each url straight from my config file.
            I tried opening them in the browser, it downloaded as described but is still an empty file.
            I found a work around by just downloading the ics right from google calendar, this is an example of one of the events. with the timezone tied in.
            RPi timezone is set to GMT +1 Europe/London (BST)
            BEGIN:VCALENDAR
            PRODID:-//Google Inc//Google Calendar 70.9054//EN
            VERSION:2.0
            CALSCALE:GREGORIAN
            METHOD:PUBLISH
            X-WR-CALNAME:Work
            X-WR-TIMEZONE:Europe/London
            BEGIN:VEVENT
            DTSTART;VALUE=DATE:20170626
            DTEND;VALUE=DATE:20170701
            RRULE:FREQ=WEEKLY;WKST=MO;UNTIL=20190331T235959Z;INTERVAL=2;BYDAY=MO
            DTSTAMP:20240403T224236Z
            UID:15dcXXXXXXujb@google.com
            CREATED:20171216T163405Z
            LAST-MODIFIED:20190330T214112Z
            SEQUENCE:0
            STATUS:CONFIRMED
            SUMMARY:Earlies
            TRANSP:TRANSPARENT
            END:VEVENT
            S S 2 Replies Last reply
              shall_ @sdetweil
              @sdetweil this is another entry added this week with the issue.
              BEGIN:VEVENT
              DTSTART;VALUE=DATE:20240402
              DTEND;VALUE=DATE:20240403
              UID:70rjap1gXXXXX6oo68db56o@google.com
              CREATED:20240402T105500Z
              LAST-MODIFIED:20240402T105500Z
              SEQUENCE:0
              STATUS:CONFIRMED
              SUMMARY:12 hours
              TRANSP:OPAQUE
              END:VEVENT
                sdetweil @shall_
                @shall_ ok. weird. anyhow
                we dont process anything other than vevents. so the garbage at the top which has the x-wr timezone, we dont see.
                so the calendar will be processed in the current system timezone.
                if you want to see the debug of processing, add the ,“DEBUG” to the end of the logLevel property in config.js
                and then start mm like this
                npm start >somefile.txt 2>&1
                wait til the cal is up, then ctrl-q quit mm and examine the somefile.txt
                  sdetweil @shall_
                  @shall_ because there is no timezone specified on the entry, it will be processed in the current system timezone
                    shall_ @shall_
                    I will have to pick this up again tomorrow. i will run the debug when i get home from work.
                    is there anything I am looking for in particular?
                      sdetweil @shall_
                      @shall_ because there is a rrule
                      the string
                      dates: …
                      documents the dates returned from the rrule.between function… yesterday plus 1 year
                      is the window we create to get recurring events
                        MMRIZE
                        @shall_
                        CX3 doesn’t parse ics file directly, so probably the default calendar app (or any event provider) must have responsibility.
                        But for an instant solution, you can use preProcessor or event payload to make a hotfix by force.
                        BEFORE
                        /* in your CX3 module config */
                        preProcessor: (event) => {
                        	if (["SomeCalendarName", "AnotherCalendarName"].includes(event.calendarName)) {
                        		event.startDate = Number(event.startDate) - 1000 * 60 * 60
                        		event.endDate = Number(event.endDate) - 1000 * 60 * 60
                        	return event
                        AFTER
                        If all your calendar has that issue, you can omit if statement.
                        	return event
                          shall_ @MMRIZE
                          @MMRIZE Thanks for your reply.
                          The timed calendar events with a start/finish time show the correct time with no issue.
                          The issue solely lies with all-day and multi-day events.
                          All of these events during DST showed correctly, as soon as the timezone changed to BST. They now all rollover into the following day, so my 5 day events are now 6 days, 2 days are now 3, single days 2.
                          M 1 Reply Last reply
                            MMRIZE @shall_
                            @shall_
                            Can you send me the ics file? (eouia0819@gmail.com)
                              shall_ @MMRIZE
                              @MMRIZE i have emailed it over
                              • A
                                alaric10000
                                Is MagicMirror installed directly to your Pi, or are you running it inside a Docker or other container? I originally had a similar problem with my MM configs all set properly, and my system time set properly, but for some reason I needed to also force the Docker container to the correct timezone with environment variables in the docker-compose file:
                                environment:
                                - TZ=America/Los Angeles
                                - SET_CONTAINER_TIMEZONE=true
                                - CONTAINER_TIMEZONE=America/Los_Angeles
                                Obviously you’d want a different timezone, and you’re probably running MM on your Pi without using Docker, but maybe it’ll help.
                                  MMRIZE
                                  @shall_ @alaric10000
                                  It happens when the event is regarded as FulldayEvent but not to start at 0 O’clock. I updated the module to fix it.
                                  https://github.com/MMRIZE/MMM-CalendarExt3/pull/141
                                  Update the module and check it.
                                    MMRIZE
                                    Finally I found what was wrong.
                                    The issue lies in the wrong parsing logic from the default calendar module about repeated full-day events with TimeZone by RRULE.
                                    If you have installed CX3 v1.8.2, Reinstall again or back to 1.8.1 (I rolled back again to 1.8.1)
                                    Then see this;
                                    https://github.com/MMRIZE/MMM-CalendarExt3/wiki/To-fix-wrong-repeated-fullday-event-displaying-(MM-2.27)
                                      sdetweil @MMRIZE
                                      @MMRIZE but… for full day, you ignore the time… or reset it to 00:00:00
                                        MMRIZE @sdetweil
                                        Of course I can. I have already provided that manual method to my CX3 users. (https://github.com/MMRIZE/MMM-CalendarExt3/wiki/To-fix-wrong-repeated-fullday-event-displaying-(MM-2.27))
                                        However, the value of notification should be trustable or consistent. All other kinds of events, like In-A-Day single events, Multiday-but-not-fullday-event, and even Repeated-Not-Fullday-event, could deliver the proper time, but only Repeated-Fullday events delivered the wrong value. That is out of common sense.
                                        At least, it should have been guided as an intentional design. (I wasted several hours trying to guess what happened. Who could imagine the notification value was wrong?)
                                        PS. Ah, I forgot there was another case; imperial units on broadcasted weather information. :)
                                          sdetweil @MMRIZE
                                          @MMRIZE yes, we have had other users making updates.
                                            shall_ @MMRIZE
                                            @MMRIZE Apologies for the delayed reply, i have been busy and then couldn’t log in to the forum.
                                            I have tried updating, installing, and reinstalling. then adding the code into my config file but i still can’t get it to correct. I think i put the code in correctly but i have attached that so you can check. my config file isn’t throwing up any errors?
                                            how do i check what version of CX3 i am running? i did delete the whole folder and redo the git pull/install so i should have whatever is on github?
                                            			module: "MMM-CalendarExt3",
                                            			position: "bottom_bar",
                                            			title: "",
                                            			mode: "week", //week or month view
                                            			weeksInView: 5,
                                            			weekIndex: 0, //-1 start last week, 0 this week, 1 next week.
                                            			instanceId: "basicCalendar",
                                            			locale: 'en-GB',
                                            			maxEventLines: 4,
                                            			firstDayOfWeek: 1,
                                            			useWeather: true,
                                            			weatherLocationName: 'xxxx',
                                            			eventPayload: (payload) => {
                                            				for (let ev of payload) {
                                            				  if (ev.fullDayEvent) {
                                            					let gap = +ev.endDate - +ev.startDate
                                            					if (gap % (1000 * 60 * 60 * 24) === 0) {
                                            					  ev.startDate = new Date(+ev.startDate).setHours(0, 0, 0, 0)
                                            					  ev.endDate = new Date(+ev.startDate + gap).setMilliseconds(-1)
                                            				return payload
                                            			eventTransformer: (e) => {
                                              e.startDate = new Date(e.start?.date || e.start?.dateTime).valueOf()
                                              e.endDate = new Date(e.end?.date || e.end?.dateTime).valueOf()
                                              e.title = e.summary
                                              e.fullDayEvent = (e.start?.date) ? true : false
                                              //return e
                                            	if (e.title.search('Lates') > -1) e.color = 'mediumvioletred'
                                            	if (e.title.search('Earlies') > -1) e.color = 'yellow'
                                            	if (e.title.search('12 hours') > -1) e.color = 'blue'
                                            	if (e.title.search('12 Hours') > -1) e.color = 'blue'
                                            	if (e.title.search('12 hrs') > -1) e.color = 'blue'
                                            	if (e.title.search('Vacation') > -1) e.color = 'blue'
                                            	if (e.title.search('vacation') > -1) e.color = 'blue'
                                            	if (e.title.search('Shutdown') > -1) e.color = 'goldenrod'
                                            	if (e.title.search('My weekend') > -1) e.color = 'deepskyblue'
                                              return e
                                            M S 2 Replies Last reply
