    MMM-CalendarExt3 BST Timezone issue
    26 Posts 4 Posters 7.3k Views 4 Watching
      sdetweil @shall_
      @shall_ i have not heard of this problem before.
      can you provide the tinezone and a calendar entry from the ics file
      to get the ics file take yiur calendar_url and do
      curl -sL calendar_url >xxx.ics
      then edit xxx.ics (its just text)
      and find a BEGIN:VEVENT… END:VEVENT
      That has the matching date/time info
      xxx out any private data, but dont change anything else
      post back here
        shall_ @sdetweil
        @sdetweil said in MMM-CalendarExt3 BST Timezone issue:
        Thanks for the reply. I am having trouble getting the ics file.
        i have ran the command in the terminal, all it does is return to the empty command line. is this supposed to open something?
        then efit xxx.ics (its just text)
        I am not sure what you mean by this? Apologies i am still fairly green on this side of things.
          sdetweil @shall_
          @shall_ sorry efit was edit, new phone and thumb havent become friends yet
          by default most linux commands produce NO output when successful. they were designed back
          in the teletype terminal world, where every character took a long time.
          so, this means the ics file was downloaded as requested
            shall_ @sdetweil
            Ok that makes sense. I have found the generated ics file, however it has a 0 file size and when I open it with text editor it is just an empty file. The file type is listed as “Outlook.File.ics.15”
            I am using google calendar urls, not sure if that makes any difference? i have tried 3 different urls that I use with the module.
              sdetweil @shall_
              @shall_ weird. are using the same url in mm config?
              you might also try it in a browser on your pc. it should download the ics (downloads folder)
                shall_ @sdetweil
                @sdetweil yes i copied each url straight from my config file.
                I tried opening them in the browser, it downloaded as described but is still an empty file.
                I found a work around by just downloading the ics right from google calendar, this is an example of one of the events. with the timezone tied in.
                RPi timezone is set to GMT +1 Europe/London (BST)
                BEGIN:VCALENDAR
                PRODID:-//Google Inc//Google Calendar 70.9054//EN
                VERSION:2.0
                CALSCALE:GREGORIAN
                METHOD:PUBLISH
                X-WR-CALNAME:Work
                X-WR-TIMEZONE:Europe/London
                BEGIN:VEVENT
                DTSTART;VALUE=DATE:20170626
                DTEND;VALUE=DATE:20170701
                RRULE:FREQ=WEEKLY;WKST=MO;UNTIL=20190331T235959Z;INTERVAL=2;BYDAY=MO
                DTSTAMP:20240403T224236Z
                UID:15dcXXXXXXujb@google.com
                CREATED:20171216T163405Z
                LAST-MODIFIED:20190330T214112Z
                SEQUENCE:0
                STATUS:CONFIRMED
                SUMMARY:Earlies
                TRANSP:TRANSPARENT
                END:VEVENT
                S S 2 Replies Last reply Reply Quote 0
                  shall_ @sdetweil
                  @sdetweil this is another entry added this week with the issue.
                  BEGIN:VEVENT
                  DTSTART;VALUE=DATE:20240402
                  DTEND;VALUE=DATE:20240403
                  UID:70rjap1gXXXXX6oo68db56o@google.com
                  CREATED:20240402T105500Z
                  LAST-MODIFIED:20240402T105500Z
                  SEQUENCE:0
                  STATUS:CONFIRMED
                  SUMMARY:12 hours
                  TRANSP:OPAQUE
                  END:VEVENT
                    sdetweil @shall_
                    @shall_ ok. weird. anyhow
                    we dont process anything other than vevents. so the garbage at the top which has the x-wr timezone, we dont see.
                    so the calendar will be processed in the current system timezone.
                    if you want to see the debug of processing, add the ,“DEBUG” to the end of the logLevel property in config.js
                    and then start mm like this
                    npm start >somefile.txt 2>&1
                    wait til the cal is up, then ctrl-q quit mm and examine the somefile.txt
                      sdetweil @shall_
                      @shall_ because there is no timezone specified on the entry, it will be processed in the current system timezone
                        shall_ @shall_
                        I will have to pick this up again tomorrow. i will run the debug when i get home from work.
                        is there anything I am looking for in particular?
