    MMM-NewsAPI
    103 Posts 10 Posters 89.5k Views 8 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @DarrenHill
      @darrenhill Ah, perfect. Yes, MMM-News and MMM-NewsApi will not work together. You can only use either or at a time. However, I am glad you managed to get things working.
      swvalentiS 1 Reply Last reply Reply Quote 0
      • swvalentiS Offline
        swvalenti Project Sponsor @mumblebaj
        The bottom right of where the news was sourced from is always 1 day ago is that accurate to they way it should be?
          mumblebaj Module Developer @swvalenti
          @swvalenti Hi. That is correct. All the articles returned are from 1 day ago and thus the Luxon DateTime.toRelative() returns 1 day ago. That is how I coded it. If you would like a different format please raise a request on the GitHub page and I can look at it.
            @mumblebaj nope all good was just making sure I wasn’t missing current news.
              swvalenti Project Sponsor @swvalenti
              The news source footer, how do I make that display in the bottom right in css?
                @swvalenti You can try this:
                #NEWSAPI .footer {
                    text-align: left;
                  DarrenHill @mumblebaj
                  @mumblebaj I’m trying to do something similar, but can’t quite get it to work.
                  I’ve got the module running in the centre bottom, and want to run it vertically rather than horizontally (so it’s more a block than a footer).
                  It’s almost there, except I can’t get the title to look right. Sometimes it’s OK (goes horizontally in a single line) but other times I get the text either going one word per line stacked vertically, or a block of the first few words like that and then the rest below in a correctly oriented line.
                  Is there anything I can adjust to make it work better and look right (all the title text going horizontally, line wrapped if it’s too long to fit)?
                  My config currently looks like this:
                              module: "MMM-NewsAPI",
                              header: "News",
                              position: "bottom_center",
                                      apiKey: "#########################",
                                      type: "vertical",
                                      choice: "everything",
                                      pageSize: 20,
                                      sortBy: "publishedAt",
                                      drawInterval: 1000*30,
                                      templateFile: "template.html",
                                      fetchInterval: 1000*60*60,
                                      query: {
                                          country: "",
                                          category: "",
                                          q: "",
                                          qInTitle: "",
                                          sources: "",
                                          domains: "bbc.co.uk",
                                          excludeDomains: "",
                                          language: ""
                  and custom.css:
                  #NEWSAPI.vertical .header .title .content .footer {
                      text-align: center;
                  Still it’s nice to have this module working in the UK again! :)
                  mumblebajM 3 Replies Last reply Reply Quote 0
                    @DarrenHill Thanks for bringing this to my attention. Seems like the QR code is the culprit. Will advise once I get a chance to have a look and push a fix for it.
                      @DarrenHill Have made some changes now.
                      Here with QACode:
                      And now without QRCODE
                      Will push the changes shortly
                        @DarrenHill Changes have been pushed. You can update the module now.
                        D 2 Replies Last reply Reply Quote 1
                          @mumblebaj - Thanks for the very fast response.
                          Will update and test.
                            @mumblebaj said in MMM-NewsAPI:
                            All up and running - that’s a fix from my side :D
                            Thanks again for that.
                            Might have a play with the layout as the pics etc are a bit small (and there’s space to expand things around them in my layout), but I can handle that.
                              dondula @mumblebaj
                              @mumblebaj
                              Hi, I have been running your MMM-News module for a couple years now. As of Sunday when my mirror restarted the module no longer shows up anymore. I tried to reinstall it and checked my sources in the config and nothing was altered.
                              Can you help me try and troubleshoot what could be happening? Let me know what I would need to provide to help. I’m not super savvy with this stuff, the mirror was actually built for me.
                              Thank you in advance.
                                sdetweil @dondula
                                @dondula said in MMM-NewsAPI:
                                . As of Sunday when my mirror refreshed
                                what does that mean? we don’t have auto update as part of MagicMirror
                                  dondula @sdetweil
                                  Sorry let me rephrase, I have the mirror auto restart every Sunday and I noticed that’s when the module disappeared. This is for the MMM-News module not sure if this thread is talking about a different one.
                                  I’ve checked my API key which still seems to be valid when testing in a browser. I also deleted all my sources except 1, so I’m not really sure what happened?
                                  S mumblebajM 2 Replies Last reply Reply Quote 0
                                    sdetweil @dondula
                                    @dondula ok, can you look at the logs?
                                    pm2 logs --lines=100
                                    100 is any number, its the last xxxx lines. it defaults to 15…
                                    so as its tuesday there could be a lot of info there…
                                    could try to clear the logs and restart … to get just the newest
                                    pm2 flush
                                    pm2 restart MagicMirror
                                    wait
                                    then
                                    pm2 logs --lines=50
                                      dondula @sdetweil
                                      Here are the logs, I do see this one error regarding an expired certificate but I wasn’t sure what that meant.
                                      0|MagicMir | [16.04.2024 10:46.13.203] [LOG] [NEWS] Error : https://newsapi.org/v2/top-headlines?sources=the-verge&pageSize=20&apiKey=a5a6d37d5e934351b7e8dbac65312e82 FetchError: request to https://newsapi.org/v2/top-headlines?sources=the-verge&pageSize=20&apiKey=a5a6d37d5e934351b7e8dbac65312e82 failed, reason: certificate has expired
                                      0|MagicMir | at ClientRequest. (/home/pi/MagicMirror/modules/MMM-News/node_modules/node-fetch/lib/index.js:1491:11)
                                      0|MagicMir | at ClientRequest.emit (events.js:315:20)
                                      0|MagicMir | at TLSSocket.socketErrorListener (_http_client.js:426:9)
                                        mumblebaj Module Developer @dondula
                                        MMM-News
                                        Hi. My module is MMM-NewsAPI. Are you referring to my module? I have not released any updates and since you have not refreshed the module I am unsure why. As Sam advised, if you could send us any errors in the logs we can then browse over that and see.
                                          dondula @mumblebaj
                                          @mumblebaj
                                          Hi there, thanks for the response. When I went to reinstall this module it was pulling from your git repository, so I assumed it was yours as well.
                                          If I am wrong please let me know. I had posted my log errors above and wasn’t sure what was going on.
                                            Unfortunately this shows MMM-News and not MMM-NewsAPI. Can you show me the module detail in the ~/MagicMirror/config/config.js? Everything except your API key.
                                            • 4 / 6
