    MMM-NewsAPI
    103 Posts 10 Posters 92.5k Views 8 Watching
    • mumblebajM
      mumblebaj Module Developer @DarrenHill
      @darrenhill Don’t filter by MMM-NewsApi.
      D 2 Replies Last reply
        DarrenHill @mumblebaj
        @mumblebaj I’m not seeing anything like that. There are some errors for other modules (DigiClock and weather) but none for NewsAPI but no payload either
        mumblebajM 1 Reply Last reply
          @mumblebaj OK my mistake - I commented out the debugging after the earlier test. Sorry for the confusion!
          Adding it back in and now I see the payload in the console.
          Still nothing is being actually added in the display though.
          I’ve also re-enabled MMM-News, and that isn’t displaying anything either.
          • mumblebajM
            @darrenhill That is strange. You should see the payload received by the main js. Can you deactivate all the other modules and start the mirror with only the NewsApi module?
            D 1 Reply Last reply
              @mumblebaj OK there it works.
              Partitioning time…
              • mumblebajM
                @darrenhill If it works while you disabled the other modules then there must be a clash with one of them. Best to see which one and let me know. I can then try and see why it is clashing.
                D 3 Replies Last reply
                  @mumblebaj It’s disagreeing with MMM-Gmailfeed
                  Commenting that out and the text and graphic appears, restore it and nothing.
                  Out of interest, what would be the recommended config for MMM-News to get the same (BBC content only, all items)?
                  I can’t get that to work either, even when MMM-NewsAPI is showing stuff? If possible I would prefer to use MMM-News, as that formatted things better for my mirror layout (as it’s an info-screen I like it vertical and bottom-centre layout).
                    @mumblebaj OK from some testing, there is a bad interaction with MMM-News, MMM-NewsAPI and MMM-Gmailfeed.
                    If I have Gmailfeed active, neither of the news modules work.
                    If I disable Gmailfeed, NewsAPI works but News doesn’t.
                    If I disable Gmailfeed and NewsAPI, News works.
                    So for now I’ve disabled Gmailfeed and removed NewsAPI, as MMM-News fits my needs better. But I would be interested to know what is going wrong, as I would ideally like both MMM-News and MMM-Gmailfeed running, like I used to have up to sometime last week (when MMM-News stopped displaying anything)…
                    I appreciate this is now moved from MMM-NewsAPI to MMM-News, so if you’d prefer to troubleshoot that in a different thread (is there one for MMM-News?) I’m happy to switch.
                      @mumblebaj OK went into MMM-GmailFeed and updated it with git pull. Looks like it has been having some issues with at least one other module from its thread here.
                      Anyway updated to the latest version and restored it’s config and now both are happily playing together.
                      Thanks for all the help in getting this sorted out - my mirror is now back fully up and running with MMM-News and MMM-GmailFeed playing nicely together again!
                      • mumblebajM
                        @darrenhill Ah, perfect. Yes, MMM-News and MMM-NewsApi will not work together. You can only use either or at a time. However, I am glad you managed to get things working.
                        swvalentiS 1 Reply Last reply
                        • swvalentiS
                          swvalenti Project Sponsor @mumblebaj
                          The bottom right of where the news was sourced from is always 1 day ago is that accurate to they way it should be?
                          • mumblebajM
                            mumblebaj Module Developer @swvalenti
                            @swvalenti Hi. That is correct. All the articles returned are from 1 day ago and thus the Luxon DateTime.toRelative() returns 1 day ago. That is how I coded it. If you would like a different format please raise a request on the GitHub page and I can look at it.
                            • swvalentiS
                              @mumblebaj nope all good was just making sure I wasn’t missing current news.
                              • swvalentiS
                                swvalenti Project Sponsor @swvalenti
                                The news source footer, how do I make that display in the bottom right in css?
                                • mumblebajM
                                  @swvalenti You can try this:
                                  #NEWSAPI .footer {
                                      text-align: left;
                                    @mumblebaj I’m trying to do something similar, but can’t quite get it to work.
                                    I’ve got the module running in the centre bottom, and want to run it vertically rather than horizontally (so it’s more a block than a footer).
                                    It’s almost there, except I can’t get the title to look right. Sometimes it’s OK (goes horizontally in a single line) but other times I get the text either going one word per line stacked vertically, or a block of the first few words like that and then the rest below in a correctly oriented line.
                                    Is there anything I can adjust to make it work better and look right (all the title text going horizontally, line wrapped if it’s too long to fit)?
                                    My config currently looks like this:
                                                module: "MMM-NewsAPI",
                                                header: "News",
                                                position: "bottom_center",
                                                        apiKey: "#########################",
                                                        type: "vertical",
                                                        choice: "everything",
                                                        pageSize: 20,
                                                        sortBy: "publishedAt",
                                                        drawInterval: 1000*30,
                                                        templateFile: "template.html",
                                                        fetchInterval: 1000*60*60,
                                                        query: {
                                                            country: "",
                                                            category: "",
                                                            q: "",
                                                            qInTitle: "",
                                                            sources: "",
                                                            domains: "bbc.co.uk",
                                                            excludeDomains: "",
                                                            language: ""
                                    and custom.css:
                                    #NEWSAPI.vertical .header .title .content .footer {
                                        text-align: center;
                                    Still it’s nice to have this module working in the UK again! :)
                                    mumblebajM 3 Replies Last reply
                                    • mumblebajM
                                      @DarrenHill Thanks for bringing this to my attention. Seems like the QR code is the culprit. Will advise once I get a chance to have a look and push a fix for it.
                                      • mumblebajM
                                        @DarrenHill Have made some changes now.
                                        Here with QACode:
                                        And now without QRCODE
                                        Will push the changes shortly
                                        • mumblebajM
                                          @DarrenHill Changes have been pushed. You can update the module now.
                                            @mumblebaj - Thanks for the very fast response.
                                            Will update and test.
                                            • 4 / 6
