    27" Kitchen Dashboard
    15 Posts 9 Posters 12.2k Views 10 Watching
      jconno03
      My first MagicMirror is a family dashboard for our kitchen area. I used a Samsung 27” monitor which has a thin profile and fits easily into a wooden frame. The frame is cut from maple to fit the monitor.
      The Dashboard is powered with an Alexa-enabled smart outlet installed in a recessed box, attached to the wall with a French cleat.
      We are thrilled with the results.
      Modules used:
      • clock
      • compliments
      • MMM-Remote-Control
      • MMM-ModuleScheduler
      • MMM-AlexaControl
      • MMM-Pir
      • MMM-Worldclock
      • MMM-GoogleCalendar
      • MMM-Sonos
      • MMM-GooglePhotos
      • MMM-OpenWeatherMapForecast
      • MMM-NewsAPI
      • MMM-SystemMonitor
      • MMM-WiFiPassword (not shown)
      Hardware:
      • Raspberry Pi 4
      • Samsung 27" T35F monitor
      • HC-SR501 PIR Infrared Sensor
      • DAOKI Light Sensor
      • ELEGRP USB Outlet Receptacle, 3-Port USB C Wall Outlet
      • Arlington DVFR1W-1 Recessed Electrical/Outlet Mounting Box
      Features
      • 27 -inch monitor
      • PIR sensor to turn off the screen when the room is empty
      • Alexa integration to turn mirror on/off, using MMM-Remote-Control to shutdown the Raspberry Pi and then the smart outlet to turn off the monitor.
      • Rotates wallpaper thru personal photos
      • Light sensor runs as separate from the Magic Mirror framework with a custom Python script to dim the monitor in the evening
      The Build
      The wall with a french cleat
      The Dashboard
      S I R S 4 Replies Last reply Reply Quote 17
        sdetweil @jconno03
        @jconno03 fabulous!!!
        • I Offline
          IPfreely @jconno03
          @jconno03 This is fantastic! I am about to get started building a screen for our family kitchen. I hadn’t thought of putting a frame around the screen, but that would be a nice touch to match our cabinets.
          Thanks for listing the materials and modules. I just discovered MM this week so am eager to get started!
            rts58 @jconno03
            @jconno03 Awesome!
              JeanMichelC
              This is really cool, great work. Any chance you can post the code. I can’t get AlexaControl to work for some reason.
              S J 2 Replies Last reply Reply Quote 0
                sdetweil @JeanMichelC
                @JeanMichelC said in 27" Kitchen Dashboard:
                can u look at the messages at MM startup, it should give you messages about listening on ports for the AlexaControl devices…
                and SOME alexas cannot find the AC devices… my echo 1 can, my echo show 5(v1) cannot
                  JeanMichelC @sdetweil
                  @sdetweil Thanks for the tip, I’ll check
                    @JeanMichelC we should take this to a new topic
                    what features do you have enabled in AC?
                      cyberphox
                      this is how it’s done! nice job!
                        jconno03 @JeanMichelC
                        @JeanMichelC
                        Here is my Alexa configuration. I am have an Echo Show 5 and an Echo Input. My feeling is that verbally asking Alexa to scan for new devices works better than attempting to scan from the app. Works flawlessly for me.
                        		module: 'MMM-AlexaControl',
                        		position: 'middle_center',
                        		config:{
                        			image: false,
                        			deviceName: "Mirror",
                        			pm2ProcessName: "MagicMirror",
                        			vcgencmd: "wlr-randr",
                          r3zi3lr
                          Awesome MagicMirror setup.
                          Any chance of looking at the config.js, please?
                            rmonkey
                            Aboslutely outstanding!
                            I did a similar build (down to the recessed outlet and french cleat).
                            I used a PiZero2 to keep things as thin as possible, but I see your build uses a full-sized Pi and looks great – the thickness looks prportionate.
                            I bet your guests say ‘whoa!’ everytime they see it.
                              sheptastic @jconno03
                              @jconno03, Nice build? How did you get the Worldclock times to align in a row (horizontally) instead of the default vertical orientation?
                                jconno03 @sheptastic
                                @sheptastic
                                Custom CSS which I think I took from another person’s post in this forum. Here are my entries…
                                /* Worldclock **/
                                Arrange clocks horizontally /
                                .MMM-Worldclock .worldtime {
                                display: flex;
                                flex-direction: row;
                                .MMM-Worldclock .world{
                                width: 140px;
                                .MMM-Worldclock .world-0{ /
                                1st clock = UTC clock */
                                width: 140px;
                                font-size:100%;
                                /* Time title font color and size */
                                .MMM-Worldclock .zone {
                                font-size: calc(var(–font-size) - 6px);
                                color: var(–color-text-bright);
                                /* Hide time difference to UTC */
                                MMM-Worldclock .gap {
                                font-size: 1px;
                                color: transparent;
                                  jconno03 @r3zi3lr
                                  @r3zi3lr If there is something specific you are looking for please let me know. I have added more features and the config is large
