    Face Recognition with inferred light
    52 Posts 5 Posters 59.6k Views 4 Watching
      paviro @KirAsh4
      @KirAsh4 why apt-get remove --purge shouldn’t apt-get purge do the same?
      – The Doctor
      • K
        KirAsh4 Moderator
        remove - Packages installed are removed (Does NOT include configuration files)
        purge - Purge is identical to remove except that packages are removed and purged. Purge meaning that any configuration files are deleted too.
        • K
          KirAsh4 Moderator
          Generally, I follow that with 'apt-get autoremove' as well. Often when you remove one package, there are other dependencies that aren’t needed anymore. The 'autoremove' takes care of that.
          • K
            KirAsh4 Moderator
            And yes, I suppose simply 'purge' would get the job done, but there are times I only want to remove the binaries, but leave my config files in place. I prefer forcing myself to actually add the '--purge' bit each time … sort of a mental check.
            • F
              feuerball
              Im just trying to reinstall things, hoping the shit works :D
              maybe i can upload my config here for some correctioN?
                paviro
                Sure thing :)
                – The Doctor
                • F
                  feuerball
                  @paviro
                  Here it is
                  0_1464191008459_config.js
                  P 1 Reply Last reply
                    paviro @feuerball
                    Can’t see any mistake there. Does it work this way? Any errors in the console or the web inspector?
                    I just moved this into a new thread because it has nothing todo with the original training file problem, please open a separate thread for different problems in the future as well :)
                    – The Doctor
                    • F
                      feuerball
                      @paviro
                      It’s still the same error like above :(
                      Didn’t try so much in the last week, but i don’t know whats the problem in here anyway
                        paviro
                        I am really not sure what this error is about…
                        @MichMich what is module.data.classes supposed to be? Since it isn’t defined apparently in this case…
                        – The Doctor
                        MichMichM 1 Reply Last reply
                        • MichMichM
                          MichMich @paviro
                          module.data.classes should contain the classes set in your config file. (If I remember correctly.)
                            paviro
                            Strange I still have no clue how this error could be reproduced…
                            – The Doctor
                              POIMann
                              Had the same issue.
                              Removing the module “localtransport” solved it for me.
                                paviro @POIMann
                                @POIMann really? That’s interesting! So it works without problems now?
                                – The Doctor
                                  POIMann
                                  The use of this.data in localtransport.js conflicts with this.data-object from the module instance properties.
                                  I patched it by replacing “this.data;” with “this.response;” in all its occurrences in localtransport.js.
                                  #enjoy
                                  • K
                                    KirAsh4 Moderator
                                    That … would make sense. It’s helpful for module writers to check the documentation on the wiki to see what method, classes, or other naming conventions are being used to avoid conflicts.
                                      paviro
                                      Thank you a lot for figuring that out! :)
                                      – The Doctor
                                      • F
                                        feuerball
                                        gonna try it later, thanks
                                        • 3 / 3
