    Face Recognition with inferred light
    52 Posts 5 Posters 57.7k Views 4 Watching
    • K Offline
      KirAsh4 Moderator
      If it was installed using apt-get, you can remove it the same way, 'apt-get remove --purge <package-name>'. If you compiled the binaries yourself, you can simply do it again and overwrite the previous ones.
      However, a better question is, why do you want to do that?
        paviro @KirAsh4
        @KirAsh4 why apt-get remove --purge shouldn’t apt-get purge do the same?
        – The Doctor
        • K Offline
          KirAsh4 Moderator
          remove - Packages installed are removed (Does NOT include configuration files)
          purge - Purge is identical to remove except that packages are removed and purged. Purge meaning that any configuration files are deleted too.
          • K Offline
            KirAsh4 Moderator
            Generally, I follow that with 'apt-get autoremove' as well. Often when you remove one package, there are other dependencies that aren’t needed anymore. The 'autoremove' takes care of that.
            • K Offline
              KirAsh4 Moderator
              And yes, I suppose simply 'purge' would get the job done, but there are times I only want to remove the binaries, but leave my config files in place. I prefer forcing myself to actually add the '--purge' bit each time … sort of a mental check.
              • F Offline
                feuerball
                Im just trying to reinstall things, hoping the shit works :D
                maybe i can upload my config here for some correctioN?
                  paviro
                  Sure thing :)
                  – The Doctor
                  • F Offline
                    feuerball
                    @paviro
                    Here it is
                    0_1464191008459_config.js
                      paviro @feuerball
                      Can’t see any mistake there. Does it work this way? Any errors in the console or the web inspector?
                      I just moved this into a new thread because it has nothing todo with the original training file problem, please open a separate thread for different problems in the future as well :)
                      – The Doctor
                      • F Offline
                        feuerball
                        @paviro
                        It’s still the same error like above :(
                        Didn’t try so much in the last week, but i don’t know whats the problem in here anyway
                          paviro
                          I am really not sure what this error is about…
                          @MichMich what is module.data.classes supposed to be? Since it isn’t defined apparently in this case…
                          – The Doctor
                          MichMichM 1 Reply Last reply Reply Quote 0
                          • MichMichM Offline
                            MichMich @paviro
                            module.data.classes should contain the classes set in your config file. (If I remember correctly.)
                              paviro
                              Strange I still have no clue how this error could be reproduced…
                              – The Doctor
                                POIMann
                                Had the same issue.
                                Removing the module “localtransport” solved it for me.
                                  paviro @POIMann
                                  @POIMann really? That’s interesting! So it works without problems now?
                                  – The Doctor
                                    POIMann
                                    The use of this.data in localtransport.js conflicts with this.data-object from the module instance properties.
                                    I patched it by replacing “this.data;” with “this.response;” in all its occurrences in localtransport.js.
                                    #enjoy
                                    • K Offline
                                      KirAsh4 Moderator
                                      That … would make sense. It’s helpful for module writers to check the documentation on the wiki to see what method, classes, or other naming conventions are being used to avoid conflicts.
                                        paviro
                                        Thank you a lot for figuring that out! :)
                                        – The Doctor
                                        • F Offline
                                          feuerball
                                          gonna try it later, thanks
                                          • 3 / 3
