    Face Recognition with inferred light
    52 Posts 5 Posters 57.7k Views 4 Watching
    • F Offline
      feuerball
      Did some debugging. I’m not an expert in Java at the moment, but isn’t there missing the class Marvin @
      module.data.classes ?
      • K Offline
        KirAsh4 Moderator
        Javascript … not Java. Two different beasts. But yes, it’s being looked into …
        • MichMichM Offline
          MichMich
          I did some tests:
          MM.getModules().withClass('a_non_existing_class') // No issue.
          MM.getModules().withClass('') // No issue.
          MM.getModules().withClass()// No issue.
          So no idea what is causing that problem.
          • F Offline
            feuerball @MichMich
            @MichMich hmm how Can i deinstall and reinstall opencv?
            • MichMichM Offline
              MichMich
              Sorry, I don’t have any experience with openCV
                paviro @feuerball
                @feuerball why do you want to reinstall it?
                – The Doctor
                • K Offline
                  KirAsh4 Moderator
                  If it was installed using apt-get, you can remove it the same way, 'apt-get remove --purge <package-name>'. If you compiled the binaries yourself, you can simply do it again and overwrite the previous ones.
                  However, a better question is, why do you want to do that?
                    paviro @KirAsh4
                    @KirAsh4 why apt-get remove --purge shouldn’t apt-get purge do the same?
                    – The Doctor
                    • K Offline
                      KirAsh4 Moderator
                      remove - Packages installed are removed (Does NOT include configuration files)
                      purge - Purge is identical to remove except that packages are removed and purged. Purge meaning that any configuration files are deleted too.
                      • K Offline
                        KirAsh4 Moderator
                        Generally, I follow that with 'apt-get autoremove' as well. Often when you remove one package, there are other dependencies that aren’t needed anymore. The 'autoremove' takes care of that.
                        • K Offline
                          KirAsh4 Moderator
                          And yes, I suppose simply 'purge' would get the job done, but there are times I only want to remove the binaries, but leave my config files in place. I prefer forcing myself to actually add the '--purge' bit each time … sort of a mental check.
                          • F Offline
                            feuerball
                            Im just trying to reinstall things, hoping the shit works :D
                            maybe i can upload my config here for some correctioN?
                              paviro
                              Sure thing :)
                              – The Doctor
                              • F Offline
                                feuerball
                                @paviro
                                Here it is
                                0_1464191008459_config.js
                                  paviro @feuerball
                                  Can’t see any mistake there. Does it work this way? Any errors in the console or the web inspector?
                                  I just moved this into a new thread because it has nothing todo with the original training file problem, please open a separate thread for different problems in the future as well :)
                                  – The Doctor
                                  • F Offline
                                    feuerball
                                    @paviro
                                    It’s still the same error like above :(
                                    Didn’t try so much in the last week, but i don’t know whats the problem in here anyway
                                      paviro
                                      I am really not sure what this error is about…
                                      @MichMich what is module.data.classes supposed to be? Since it isn’t defined apparently in this case…
                                      – The Doctor
                                      MichMichM 1 Reply Last reply Reply Quote 0
                                      • MichMichM Offline
                                        MichMich @paviro
                                        module.data.classes should contain the classes set in your config file. (If I remember correctly.)
                                          paviro
                                          Strange I still have no clue how this error could be reproduced…
                                          – The Doctor
                                            POIMann
                                            Had the same issue.
                                            Removing the module “localtransport” solved it for me.
                                            • 2 / 3
