Face Recognition with inferred light
so still the problem with not logging in correctly :(
Is there any log in the Web inspector?
How can I see the web inspector?
@feuerball try
altcmdI -
Gonna give this a try when I’m back@home
@feuerball please press on
main.json the right so we can see on what it tries to execute the lower case thing. -
Uhm @MichMich could it be that the module fading fails if no module has the class you are trying to fade?
Did some debugging. I’m not an expert in Java at the moment, but isn’t there missing the class Marvin @
module.data.classes ?
Javascript … not Java. Two different beasts. But yes, it’s being looked into …
I did some tests:
MM.getModules().withClass('a_non_existing_class') // No issue. MM.getModules().withClass('') // No issue. MM.getModules().withClass()// No issue.So no idea what is causing that problem.
@MichMich hmm how Can i deinstall and reinstall opencv?
Sorry, I don’t have any experience with openCV
@feuerball why do you want to reinstall it?
If it was installed using apt-get, you can remove it the same way,
'apt-get remove --purge <package-name>'. If you compiled the binaries yourself, you can simply do it again and overwrite the previous ones.However, a better question is, why do you want to do that?
@KirAsh4 why
apt-get remove --purgeshouldn’tapt-get purgedo the same? -
remove - Packages installed are removed (Does NOT include configuration files)
purge - Purge is identical to remove except that packages are removed and purged. Purge meaning that any configuration files are deleted too. -
Generally, I follow that with
'apt-get autoremove'as well. Often when you remove one package, there are other dependencies that aren’t needed anymore. The'autoremove'takes care of that. -
And yes, I suppose simply
'purge'would get the job done, but there are times I only want to remove the binaries, but leave my config files in place. I prefer forcing myself to actually add the'--purge'bit each time … sort of a mental check.
