    Face Recognition with inferred light
    52 Posts 5 Posters 53.9k Views 4 Watching
    • F Offline
      feuerball
      • paviroP Offline
        paviro
        Uhm @MichMich could it be that the module fading fails if no module has the class you are trying to fade?
        – The Doctor
        • F Offline
          feuerball
          Did some debugging. I’m not an expert in Java at the moment, but isn’t there missing the class Marvin @
          module.data.classes ?
          • KirAsh4K Offline
            KirAsh4 Moderator
            Javascript … not Java. Two different beasts. But yes, it’s being looked into …
            • MichMichM Offline
              MichMich
              I did some tests:
              MM.getModules().withClass('a_non_existing_class') // No issue.
              MM.getModules().withClass('') // No issue.
              MM.getModules().withClass()// No issue.
              So no idea what is causing that problem.
              • F Offline
                feuerball @MichMich
                @MichMich hmm how Can i deinstall and reinstall opencv?
                paviroP 1 Reply Last reply Reply Quote 0
                • MichMichM Offline
                  MichMich
                  Sorry, I don’t have any experience with openCV
                  • paviroP Offline
                    paviro @feuerball
                    @feuerball why do you want to reinstall it?
                    – The Doctor
                    • KirAsh4K Offline
                      KirAsh4 Moderator
                      If it was installed using apt-get, you can remove it the same way, 'apt-get remove --purge <package-name>'. If you compiled the binaries yourself, you can simply do it again and overwrite the previous ones.
                      However, a better question is, why do you want to do that?
                      • paviroP Offline
                        paviro @KirAsh4
                        @KirAsh4 why apt-get remove --purge shouldn’t apt-get purge do the same?
                        – The Doctor
                        • 3 / 6
