    Face Recognition with inferred light
    52 Posts 5 Posters 58.7k Views 4 Watching
    • K
      KirAsh4 Moderator
      A small hole next to the large one, enough for light to go through, should work. Usually it’s a tiny pinhole, but that’s also assuming the sensor is literally right up against the pinhole.
      • F
        feuerball
        so still the problem with not logging in correctly :(
          paviro
          Is there any log in the Web inspector?
          – The Doctor
          • F
            feuerball
            How can I see the web inspector?
              paviro @feuerball
              @feuerball try alt cmd I
              – The Doctor
              • F
                feuerball
                Gonna give this a try when I’m back@home
                • F
                  feuerball
                  @paviro
                    paviro @feuerball
                    @feuerball please press on main.js on the right so we can see on what it tries to execute the lower case thing.
                    – The Doctor
                    • F
                      feuerball
                        paviro
                        Uhm @MichMich could it be that the module fading fails if no module has the class you are trying to fade?
                        – The Doctor
                        • F
                          feuerball
                          Did some debugging. I’m not an expert in Java at the moment, but isn’t there missing the class Marvin @
                          module.data.classes ?
                          • K
                            KirAsh4 Moderator
                            Javascript … not Java. Two different beasts. But yes, it’s being looked into …
                            • MichMichM
                              MichMich
                              I did some tests:
                              MM.getModules().withClass('a_non_existing_class') // No issue.
                              MM.getModules().withClass('') // No issue.
                              MM.getModules().withClass()// No issue.
                              So no idea what is causing that problem.
                              • F
                                feuerball @MichMich
                                @MichMich hmm how Can i deinstall and reinstall opencv?
                                • MichMichM
                                  MichMich
                                  Sorry, I don’t have any experience with openCV
                                    paviro @feuerball
                                    @feuerball why do you want to reinstall it?
                                    – The Doctor
                                    • K
                                      KirAsh4 Moderator
                                      If it was installed using apt-get, you can remove it the same way, 'apt-get remove --purge <package-name>'. If you compiled the binaries yourself, you can simply do it again and overwrite the previous ones.
                                      However, a better question is, why do you want to do that?
                                        paviro @KirAsh4
                                        @KirAsh4 why apt-get remove --purge shouldn’t apt-get purge do the same?
                                        – The Doctor
                                        • K
                                          KirAsh4 Moderator
                                          remove - Packages installed are removed (Does NOT include configuration files)
                                          purge - Purge is identical to remove except that packages are removed and purged. Purge meaning that any configuration files are deleted too.
                                          • K
                                            KirAsh4 Moderator
                                            Generally, I follow that with 'apt-get autoremove' as well. Often when you remove one package, there are other dependencies that aren’t needed anymore. The 'autoremove' takes care of that.
                                            • 2 / 3
