    Face Recognition with inferred light
    52 Posts 5 Posters 57.7k Views 4 Watching
    • F Offline
      feuerball
      How can I see the web inspector?
        paviro @feuerball
        @feuerball try alt cmd I
        – The Doctor
        • F Offline
          feuerball
          Gonna give this a try when I’m back@home
          • F Offline
            feuerball
            @paviro
              paviro @feuerball
              @feuerball please press on main.js on the right so we can see on what it tries to execute the lower case thing.
              – The Doctor
              • F Offline
                feuerball
                  paviro
                  Uhm @MichMich could it be that the module fading fails if no module has the class you are trying to fade?
                  – The Doctor
                  • F Offline
                    feuerball
                    Did some debugging. I’m not an expert in Java at the moment, but isn’t there missing the class Marvin @
                    module.data.classes ?
                    • K Offline
                      KirAsh4 Moderator
                      Javascript … not Java. Two different beasts. But yes, it’s being looked into …
                      • MichMichM Offline
                        MichMich
                        I did some tests:
                        MM.getModules().withClass('a_non_existing_class') // No issue.
                        MM.getModules().withClass('') // No issue.
                        MM.getModules().withClass()// No issue.
                        So no idea what is causing that problem.
                        • F Offline
                          feuerball @MichMich
                          @MichMich hmm how Can i deinstall and reinstall opencv?
                          • MichMichM Offline
                            MichMich
                            Sorry, I don’t have any experience with openCV
                              paviro @feuerball
                              @feuerball why do you want to reinstall it?
                              – The Doctor
                              • K Offline
                                KirAsh4 Moderator
                                If it was installed using apt-get, you can remove it the same way, 'apt-get remove --purge <package-name>'. If you compiled the binaries yourself, you can simply do it again and overwrite the previous ones.
                                However, a better question is, why do you want to do that?
                                  paviro @KirAsh4
                                  @KirAsh4 why apt-get remove --purge shouldn’t apt-get purge do the same?
                                  – The Doctor
                                  • K Offline
                                    KirAsh4 Moderator
                                    remove - Packages installed are removed (Does NOT include configuration files)
                                    purge - Purge is identical to remove except that packages are removed and purged. Purge meaning that any configuration files are deleted too.
                                    • K Offline
                                      KirAsh4 Moderator
                                      Generally, I follow that with 'apt-get autoremove' as well. Often when you remove one package, there are other dependencies that aren’t needed anymore. The 'autoremove' takes care of that.
                                      • K Offline
                                        KirAsh4 Moderator
                                        And yes, I suppose simply 'purge' would get the job done, but there are times I only want to remove the binaries, but leave my config files in place. I prefer forcing myself to actually add the '--purge' bit each time … sort of a mental check.
                                        • F Offline
                                          feuerball
                                          Im just trying to reinstall things, hoping the shit works :D
                                          maybe i can upload my config here for some correctioN?
                                            paviro
                                            Sure thing :)
                                            – The Doctor
                                            • 2 / 3
